Rayscaper New Releases
@Krass Great renders! Glad you found a workaround. That computer screen looks believable to me.
Image | Krea
Generate AI images with Flux, ChatGPT, Imagen, Ideogram, and more. Upload references and choose styles — the best text-to-image models in one place.
Krea (www.krea.ai)
You render it grainy in a low res, and then let it upscale? Or do you enhance the images in other ways with AI?
BTW, I found the issue, will post a fix shortly. The crash occurs when you load too many thumbnails in the asset browser.
Cheers,
Thomas -
I use AI Upscale to get a sharper render and correct details, characters, it improves materials, wood, etc.
Hey, Rayscaper users!
Another release!
Rayscaper 0.9.69 Beta is available in the SketchUcation store. As
always, I recommend upgrading to the latest version.What Changed?
- Fix a crash when scrolling the asset browser. - @Krass can you let me know if this version behaves better for you?
Help Me Build the Community
If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
and helps me showcase its capabilities to new users.Follow me on Twitter.
Happy Rendering!
Oh well, that lasted a long time did it not.
I cannot run Rayscaper, it is installed but, when I start the app the !render! window will not open.
All this happened post a diffusion update.
Report below.
Extension Errors Report
SketchUp: 24.0.594
OS: Windows 11
Ruby: 3.2.2Extension: SketchUp Diffusion (1.2025.09.28)
Error: LoadError (127: The specified procedure could not be found. - C:/Users/mike1/AppData/Local/Temp/SketchUpDiffusion.so)
<internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:inrequire'
c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:28:in<module:SketchUpDiffusion>' c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:1:in<main>'
C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:ineval' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:inrequire'
C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:inload' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:inregister_extension'
C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in<module:SketchUpDiffusion>' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:5:in<top (required)>' -
Hello, Pixelcruncher,
I'have installed RS 9.6.9
I'm testing it. When I hide a SU tag it stays visible. The only way seems to Hide a group so that it will not be visible. So: we can't use Hide/reveal Tags? -
Going cold turkey, sketchup is completely uninstalled for a while.
This time I have a scene that is a bit heavy, I copied an entire apartment in duplicate and when I open RS, it is active but the window does not want to enlarge and remains stuck in the taskbar. We can see in the thumbnail that it is working on the project, it is rendering... but I also did not have a Rayscaper loading window -
The latest version is broken for me... I installed it and I don't think I restarted SU and it worked. But now the window is stuck in the taskbar;
I'm going to reinstall 9.6.4 to test. -
Ok, rayscaper is back if I use 9.6.4
Need a revert version button.
@pixelcruncher any update on when the material inheritance is going to be fixed?
Hello, pictures of another apartment I would like to buy, I prefer this one. the exterior is made up, it's the hdri map. but the view is really nice in truth. Rayscaper render Magnfic Upscale
Can someone post the .9.6.4 build please, da nada here.
OK, hover the cursor over the sketchup icon on the task bar, right click on the Rayscaper window and maximise. The render window will not open elsewise.
Running the .69 build. EVERY new model loaded will require the steps above. right click on the render window on the task bar and select maximise. When this is done once per new model, session, each new start of Rayscaper will occur as per normal.
Thanks Mike, I'will test your tip. here is the 9.6.4 version, tell me when your download is ok, I will delete the file:
https://www.swisstransfer.com/d/698b91bc-e0e6-4fc5-8434-9b06ef0571f7 -
Done, I thank you Sir.
Hey folks,
Sorry for the late replies. It was a bad weekend to go on a trip.
— I assumed that the build I posted fixed the crash just before I left. Will post an updated build here ASAP.@pixelcruncher any update on when the material inheritance is going to be fixed?
Will try to do that in the release after this one. The next one will be a hotfix for the crashes users encountered.
Agreed, but it's not that simple to do with a SketchUp extension. I will make downloads of older releases available on the Rayscaper website. Stay tuned.
Thanks for the workaround. I will fix it.
Cheers,
Thomas -
Thanks PixC. Good luck
I never doubted you would. My first thought was the Diffusion update seeing as that was the last thing to happen prior to the issue presenting.
Conflict with Diffusion?
