    Rayscaper New Releases
    rayscaperrender
    466 Posts 12 Posters 207.0k Views 13 Watching
    • KrassK Offline
      Krass
      Hello, Pixelcruncher,
      I'have installed RS 9.6.9
      I'm testing it. When I hide a SU tag it stays visible. The only way seems to Hide a group so that it will not be visible. So: we can't use Hide/reveal Tags?
      Krass
        Going cold turkey, sketchup is completely uninstalled for a while.
        • KrassK Offline
          Krass
          This time I have a scene that is a bit heavy, I copied an entire apartment in duplicate and when I open RS, it is active but the window does not want to enlarge and remains stuck in the taskbar. We can see in the thumbnail that it is working on the project, it is rendering... but I also did not have a Rayscaper loading window
          Krass
          • KrassK Offline
            Krass
            The latest version is broken for me... I installed it and I don't think I restarted SU and it worked. But now the window is stuck in the taskbar;
            I'm going to reinstall 9.6.4 to test.
            Krass
            • KrassK Offline
              Krass
              Ok, rayscaper is back if I use 9.6.4
              Krass
                Need a revert version button.
                  sashapepperspray @pixelcruncher
                  @pixelcruncher any update on when the material inheritance is going to be fixed?
                  • KrassK Offline
                    Krass
                    Hello, pictures of another apartment I would like to buy, I prefer this one. the exterior is made up, it's the hdri map. but the view is really nice in truth. Rayscaper render Magnfic Upscale
                    Krass
                      Can someone post the .9.6.4 build please, da nada here.
                        OK, hover the cursor over the sketchup icon on the task bar, right click on the Rayscaper window and maximise. The render window will not open elsewise.
                          Mike Amos @Mike Amos
                          Running the .69 build. EVERY new model loaded will require the steps above. right click on the render window on the task bar and select maximise. When this is done once per new model, session, each new start of Rayscaper will occur as per normal.5 1000s 2196 x 1071 GPU 2020016 tri 54s.png
                          • KrassK Offline
                            Krass
                            Thanks Mike, I'will test your tip. here is the 9.6.4 version, tell me when your download is ok, I will delete the file:
                            https://www.swisstransfer.com/d/698b91bc-e0e6-4fc5-8434-9b06ef0571f7
                            Krass
                              Done, I thank you Sir.
                                Hey folks,
                                Sorry for the late replies. It was a bad weekend to go on a trip. πŸ˜• β€” I assumed that the build I posted fixed the crash just before I left. Will post an updated build here ASAP.
                                Will try to do that in the release after this one. The next one will be a hotfix for the crashes users encountered.
                                Agreed, but it's not that simple to do with a SketchUp extension. I will make downloads of older releases available on the Rayscaper website. Stay tuned.
                                Thanks for the workaround. I will fix it.
                                Cheers,
                                Thomas
                                S 1 Reply Last reply πŸ™ Reply Quote 2
                                • KrassK Offline
                                  Krass
                                  Thanks PixC. Good luck
                                  Krass
                                    I never doubted you would. My first thought was the Diffusion update seeing as that was the last thing to happen prior to the issue presenting.
                                    Conflict with Diffusion?
                                      Just so you know Mr Cruncher, Sir.
                                      When you get the chance to get away from the rat race, ANY weekend is a good time to do so. You Sir, are worth it. In a very poor paraphrasing of the advertisement.
                                        @pixelcruncher thank you
                                          Hey, Rayscaper users!
                                          Rayscaper 0.9.72 Beta is available. You can get it via the SketchUcation store.
                                          I recommend upgrading to the latest version.
                                          What Changed?
                                          • Rayscaper now supports direct integration with the Skatter plugin. Render-only Skatter data can now be ingested directly from Skatter, bypassing the
                                            SketchUp viewport. This offloads complex instancing and geometry handling to Rayscaper, keeping SketchUp responsive and lightweight during rendering.
                                            Perfect for large vegetation or scattering setups β€” just hit render and let Rayscaper handle the heavy lifting. (@ntxdave Thanks for connecting me with the Skatter people).
                                          • Bugfix: push/pull geometry would not properly propagate to Rayscaper.
                                          • Fix Rayscaper for SketchUp 2024, caused by a breaking change in the SketchUp SDK. Note: Going forward, Rayscaper will only support the latest three
                                            SketchUp releases because now that it's for sure that the SDK is not backwards compatible, it's too much overhead for me to maintain more versions. The
                                            current version supports: SketchUp 2026, SketchUp 2025 & SketchUp 2024.
                                          • Make materials assigned to a SketchUp group or component instance work again. cc: @sashapepperspray
                                          Here's a screenshot of a simple forest I created using Skatter:
                                          Help Me Build the Community πŸ‘
                                          If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
                                          to new users.
                                          Follow me on https://x.com/rayscaper3d.
                                          Happy Rendering!
                                          Thomas
                                            @Krass said in Rayscaper New Releases:
                                            Visibility should work with tags and tag folders. Maybe you hit a bug, can you provide me with a screen recording, or a scene where I can reproduce this behavior?
                                            SketchUp_6mMdsz4irP.mp4
                                            • 11
                                            • 12
                                            • 13
                                            • 23
                                            • 24
                                            • 11 / 24
