    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
    • KrassK
      Krass
      for the record, all the furniture is really at my house, but I tried to see in these images what I could fit into this apartment that I could buy....
      the character is not contractual, I have a shaved head!
      Krass
      • pixelcruncherP
        pixelcruncher Extension Creator @Mike Amos
        @Mike-Amos Very nice render!
        • pixelcruncherP
          @Krass Great renders! Glad you found a workaround. That computer screen looks believable to me.
          Image | KREA
          Generate AI images with Flux, ChatGPT, Imagen, Ideogram, and more. Upload references and choose styles — the best text-to-image models in one place.
          Krea (www.krea.ai)
          You render it grainy in a low res, and then let it upscale? Or do you enhance the images in other ways with AI?
          BTW, I found the issue, will post a fix shortly. The crash occurs when you load too many thumbnails in the asset browser.
          Cheers,
          Thomas
          • KrassK
            Krass
            I use AI Upscale to get a sharper render and correct details, characters, it improves materials, wood, etc.
            Krass
            Reply Quote 2
            • pixelcruncherP
              Hey, Rayscaper users!
              Another release!
              Rayscaper 0.9.69 Beta is available in the SketchUcation store. As
              always, I recommend upgrading to the latest version.
              What Changed?
              • Fix a crash when scrolling the asset browser. - @Krass can you let me know if this version behaves better for you?
              Help Me Build the Community 👍
              If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
              and helps me showcase its capabilities to new users.
              Follow me on Twitter.
              Happy Rendering!
              Mike AmosM 1 Reply Last reply
                Mike Amos @pixelcruncher
                @pixelcruncher
                Oh well, that lasted a long time did it not.
                I cannot run Rayscaper, it is installed but, when I start the app the !render! window will not open.
                All this happened post a diffusion update.
                Report below.
                Extension Errors Report
                SketchUp: 24.0.594
                OS: Windows 11
                Ruby: 3.2.2
                Extension: SketchUp Diffusion (1.2025.09.28)
                Error: LoadError (127: The specified procedure could not be found. - C:/Users/mike1/AppData/Local/Temp/SketchUpDiffusion.so)
                <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:28:in <module:SketchUpDiffusion>' c:/users/mike1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_diffusion/su_loader.rbe:1:in <main>'
                C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require'
                C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in register_extension'
                C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:21:in <module:SketchUpDiffusion>' C:/Users/mike1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/su_diffusion.rb:5:in <top (required)>'
                • KrassK
                  Krass
                  Hello, Pixelcruncher,
                  I'have installed RS 9.6.9
                  I'm testing it. When I hide a SU tag it stays visible. The only way seems to Hide a group so that it will not be visible. So: we can't use Hide/reveal Tags?
                  Krass
                    Going cold turkey, sketchup is completely uninstalled for a while.
                    • KrassK
                      Krass
                      This time I have a scene that is a bit heavy, I copied an entire apartment in duplicate and when I open RS, it is active but the window does not want to enlarge and remains stuck in the taskbar. We can see in the thumbnail that it is working on the project, it is rendering... but I also did not have a Rayscaper loading window
                      Krass
                      • KrassK
                        Krass
                        The latest version is broken for me... I installed it and I don't think I restarted SU and it worked. But now the window is stuck in the taskbar;
                        I'm going to reinstall 9.6.4 to test.
                        Krass
                        • KrassK
                          Krass
                          Ok, rayscaper is back if I use 9.6.4
                          Krass
                            Need a revert version button.
                              sashapepperspray @pixelcruncher
                              @pixelcruncher any update on when the material inheritance is going to be fixed?
                              • KrassK
                                Krass
                                Hello, pictures of another apartment I would like to buy, I prefer this one. the exterior is made up, it's the hdri map. but the view is really nice in truth. Rayscaper render Magnfic Upscale
                                Krass
                                Reply Quote 2
                                  Can someone post the .9.6.4 build please, da nada here.
                                    OK, hover the cursor over the sketchup icon on the task bar, right click on the Rayscaper window and maximise. The render window will not open elsewise.
                                      Mike Amos @Mike Amos
                                      Running the .69 build. EVERY new model loaded will require the steps above. right click on the render window on the task bar and select maximise. When this is done once per new model, session, each new start of Rayscaper will occur as per normal.5 1000s 2196 x 1071 GPU 2020016 tri 54s.png
                                      • KrassK
                                        Krass
                                        Thanks Mike, I'will test your tip. here is the 9.6.4 version, tell me when your download is ok, I will delete the file:
                                        https://www.swisstransfer.com/d/698b91bc-e0e6-4fc5-8434-9b06ef0571f7
                                        Krass
                                          Done, I thank you Sir.
                                          • pixelcruncherP
                                            Hey folks,
                                            Sorry for the late replies. It was a bad weekend to go on a trip. 😕 — I assumed that the build I posted fixed the crash just before I left. Will post an updated build here ASAP.
                                            Will try to do that in the release after this one. The next one will be a hotfix for the crashes users encountered.
                                            Agreed, but it's not that simple to do with a SketchUp extension. I will make downloads of older releases available on the Rayscaper website. Stay tuned.
                                            Thanks for the workaround. I will fix it.
                                            Cheers,
                                            Thomas
                                            S 1 Reply Last reply 🙏
                                            Reply Quote 2
                                            • 11
                                            • 12
                                            • 13
                                            • 26
                                            • 27
                                            • 11 / 27
