    Sketchucation Tools 5.0...
    176 Posts 30 Posters 70.7k Views 28 Watching
    • fredo6F
      None of my plugins uses DMLanguageHandler either.
      Edson: Could you look at your SU2025 setup and see where this could come from.
      Can you also install Sketchucation 5.0.2 manually (by unzipping the rbz file into your Plugin directory).
        DMLanguageHandler is a file used by Dale Martens in the likes of Profile Builder, Artisan etc
        • gullfoG
          gullfo
          it's this line:
          Sketchup.require(File.join(File.dirname(__FILE__), 'DM_ProfileBuilder3/langhandler'))
          in the DM_ProfileBuilder3.rb
          it's likely that the profile builder folder did not get copied. when i "migrated" my 2025 plugins to 2026, it missed 4 folders from the "required" lines. once the folders were copied over, it all works.
          note on my system the DM_ProfileBuilder3 folder copied, it was other plugin folders which did not.
          Glenn
          http://www.runnel.com
          TIGT 1 Reply Last reply
          • EdsonE
            Edson
            I am not being able to post here
            http://www.mahfuz.arq.br
              Rich O Brien Moderator @Edson
              @Edson said in Sketchucation Tools 5.0.2:
              You just did?
                ARQALBINO Newcomers
                Hi, i can´t load my plugin FredoPic2Shape, i want to try up first, i really like Fredo Plugins on SketchUp 2021
                  Rich O Brien Moderator @ARQALBINO
                  @ARQALBINO said in Sketchucation Tools 5.0.2:
                  It requires Libfredo to function.
                    TIG Moderator @Edson
                    @Edson
                    Can you please cause the error dialog again, this time click the bottom-left button to 'Copy All Errors' to your clipboard.
                    Then paste the full error report into a reply here.
                    It should tell us if DM's code is somehow messing up our files' loading...
                      TIG Moderator @gullfo
                      @gullfo
                      So this file/folder copying was an error with the v2026 extension-migration tool by SketchUp, not copying all DM's files over and causing an error ??
                      It has nothing to do with the SketchUcation extension - except in so far that it breaks it and stops it loading !!
                      gullfoG 1 Reply Last reply
                        Macho3001
                        Hi Dear Rich, Tig ! Firstly, many many thanks for helping us users out at Sketchucation !!
                        I have an error cropping up on my system after installing the latest SketchUcationTools_v5.0.2.rbz update, from the link provided by your good self.
                        I was updating LibFredo6 to the latest version, and thereafter I just installed SketchUcationTools_v5.0.2.rbz on my SU2018 Pro system. It made my previous installation disappear, and after restarting Sketchup it now gives the following error on startup, while many of my purchased Fredo plugins (like Thrupaint etc) have stopped working which now ask me to install sketchucation extensionstore v3.1. Can you please help...? Screenshots of the load errors are attached herein below.... Will be deeply obliged if you could help: -
                        Nitin
                        3DADS
                        'Leadership, by Design'
                        3rd Dimension, Architecture Design Studio
                        • gullfoG
                          gullfo @TIG
                          @TIG yes that is my observation. the missing folders from the 2026 install-first-run migration process cause the errors in the sketchucation startup.
                          Glenn
                            TIG Moderator @Macho3001
                            @Macho3001
                            I'll look into it further...
                            Meanwhile:
                            It looks like you have an Extension loaded which doesn't report a Version in the Extension Manager - if it returns '' it ought to be OK, but with a nil it cause the trip hazard.
                            A known cause is some of Chuck Vali's stuff.
                            But the nil return was trapped for this very reason.
                            Can you check your Extensions and unload any without a Version set, and see it SketchUcation then loads on a restart. And let me know what Extension[s] are the culprits...
                              Macho3001
                              Hi TIG !!
                              Thnks so much for the pointer dear TIG. I unloaded Chuck Vali's Instant Architecture but that did not solve the issue. Also, please pardon my limited knowledge, but could you please guide me how (and where) to check the Version / Version Set of any extension.... Is it where it says "Unsigned" ? I am attaching a screenshot of my SU2018 Pro Extension Manager screen below.
                              Thanks !
                              3DADS
                                Macho3001
                                By the way, the load error only started AFTER I updated LibFredo6 to the latest version !! I don't know if that piece of information helps !!
                                There was absolutely no problem before the LibFredo6 updation...
                                3DADS
                                  @Macho3001
                                  The > on the right end of the extension details, if you click it it expands the entry and shows the Version, or in the case of Instant Architecture == nothing !
                                  The 'unsigned' message appears if an extension hasn't been processed by Trimble/SketchUp, if the extensions is older it's probably not been updated in the last few years, that's OK if it's from a trusted source and your Extension Manager's > Loading Policy is set to Unrestricted, otherwise it's loading is blocked.
                                  I'm preparing an update to the SketchUcation tools to robustly trap for this kind of unexpected problem from poorly structure code by others...
                                    Macho3001
                                    Thank you so much dear TIG... couldn't imagine what the Sketchup world would've been without guys like you, Fredo, Rich and others, whose incredible plugins have lighted up the core SU program. Thanks a ton for the immense service you're doing to the community!
                                    Will await the sketchucation tools update !
                                    3DADS
                                    Reply Quote 2
                                      jackybe67
                                      Extension Errors Report
                                      SketchUp: 25.0.634
                                      OS: Windows 11
                                      Ruby: 3.2.2
                                      Extension: SketchUcation (5.0.2)
                                      Error: NoMethodError (undefined method split' for nil:NilClass) c:/users/jacky/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:784:in block (2 levels) in getMyPlugins'
                                      c:/users/jacky/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:766:in each' c:/users/jacky/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:766:in block in getMyPlugins'
                                      c:/users/jacky/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:764:in each' c:/users/jacky/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:764:in getMyPlugins'
                                      c:/users/jacky/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_loader.rbe:99:in <module:SCF>' c:/users/jacky/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_loader.rbe:13:in <main>'
                                      C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in require'
                                      C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in load' C:/Users/jacky/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:173:in register_extension'
                                      C:/Users/jacky/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:173:in <module:SCF>' C:/Users/jacky/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:17:in <top (required)>'
                                        TIG Moderator @jackybe67
                                        @jackybe67
                                        This has been reported before.
                                        It's probably because you have one of Chuck Vali's extensions loading.
                                        He omitted giving it a Version [check in your Extension Manager for that omission...],.
                                        This means that when we try to find its version so we look for updates it trips us up with a fault.
                                        Our v5.0.3 sidesteps this very problem [amongst others] and should be published very soon...
                                        J 1 Reply Last reply
                                        • Z
                                          zsolarewicz
                                          Hi guys,
                                          Can anybody confirm latest - 5.0.2
                                          to be working in SKP 8?
                                          I know - now is 2025 but..thats last free version
                                          and looks SCF has been described somewhere as v.8 compatible ?
                                          cheers,
                                            Last free version of Sketchup is V17.
                                            Z 1 Reply Last reply
                                            • 4 / 9
