    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
      Rachel23
      I'm disappointed. I downloaded it and it said its expired. So i bought your extension for 15 dollars and then redownloaded it and it still says expired and I've relogged in many times.
        Rich O Brien Moderator @Rachel23
        @Rachel23 Licenses need to be activated per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
        • N
          Nicolla
          Hi guys.
          I downloaded recent update but it messed something up with Joint Push Pull
          I can't make shell and thicken the most simplest shapes, like the cube with 3 faces removed
          Have you noticed this too and how can I solve it? Thanks πŸ™‚
          TIGT 1 Reply Last reply
            TIG Moderator @Nicolla
            @Nicolla
            If you try it with the Ruby Console [Extensions > Developer submenu] open do you see any error messages, or do you get any other error message dialogs when trying it ?
            If you attach a simple SKP, with the problems you are experiencing, and a step by step of instructions, it would help us understand your problems...
            • I
              ideas_arte @fredo6
              @fredo6
              Extension Errors Report
              SketchUp: 24.0.484
              OS: Windows 10
              Ruby: 3.2.2
              Extension: Fredo6 LibFredo6 (14.8a - 26 Nov 24)
              Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in block in super_flatten'
              c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in super_flatten'
              c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:860:in load_from_config' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins'
              c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins'
              c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
              C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
              fredo6F 1 Reply Last reply
              • fredo6F
                fredo6 @ideas_arte
                @ideas_arte
                Can you check the version of Animator you have in your enviroment.
                The best is to invoke the menu Window > LibFredo6 Settngs > Fredo6 Plugin information for Sketchucation Support.
                I 1 Reply Last reply
                • I
                  ideas_arte @fredo6
                  @fredo6
                  Fredo6 Plugins Information on 2024-12-05 14:25:10 -0600
                  • Sketchup: 24.0.484
                  • LibFredo6: v14.8a
                  • LibFredo6 Binary loaded
                  • Sketchucation ExtensionStore: 4.4.1
                  • SCFLicense: v6.4a - 74
                  • Fredo6 Plugins
                    FredoTools v4.5c
                    ThruPaint v2.8a
                    TopoShaper v2.7a
                    Signature File: absent
                  • I
                    ideas_arte @ideas_arte
                    @ideas_arte
                    I had to desable the Animator:
                    • fredo6F
                      fredo6 @ideas_arte
                      @ideas_arte
                      Do you know what version of Animator you had. You may try with installing its latest version.
                      • fredo6F
                        NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
                        LibFredo6 14.9a is a major release. It includes changes related to:
                        • FredoBatch v1.2a
                        • Bug Fixing
                        • K
                          Kevin Reza Arnanda Newcomers
                          THANK YOU
                          • fredo6F
                            NEW RELEASE: LibFredo6 v15.0a - 31 Dec 24
                            LibFredo6 15.0a is a major release. It includes changes related to:
                            • FredoBatch v1.3a
                            • Bug Fixing
                            • K
                              kngpw
                              I cannot install the latest libredo6 15.0a on my new computer.
                              I have tried to reinstall the plugin + Sketchup many times. It keeps giving me the same results.
                              SketchUp: 24.0.594
                              OS: Windows 11
                              Ruby: 3.2.2
                              Extension: Fredo6 LibFredo6 (15.0a - 31 Dec 24)
                              Error: ArgumentError (invalid byte sequence in UTF-8)
                              c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                              c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                              c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                              c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                              c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                              C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                              C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                              • fredo6F
                                Do you have a Windows computername with non-roman characters?
                                K 1 Reply Last reply
                                • K
                                  kngpw @fredo6
                                  @fredo6
                                  I do! I only change the real Windows computername posting here for privacy reason.
                                    TIG Moderator @kngpw
                                    @kngpw said in [Plugin Library] LibFredo6 - v15.0a - 31 Dec 24:
                                    @fredo6
                                    Non-ASCII characters in a computer-name is against Windows requirements and can break things like licensing !
                                      Juca Ross
                                      Excelente, funciona de maravilla
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v15.1a - 22 Feb 25
                                        LibFredo6 15.1a is a major release. It includes changes related to:
                                        • Animator v4.2a
                                        • Compatiility SU2025
                                        • Bug Fixing
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v15.2a - 12 Mar 25
                                          LibFredo6 15.2a is a major release. It includes changes related to:
                                          • Animator v4.3a
                                          • Bug Fixing (random failure of menu loading)
                                          • G
                                            GavinG
                                            Good evening, I recently upgraded to SKP 2025 and have migrated all the plugins; I am trying to use them but while they are on the ribbon, they do not open or function; I have licences for them; please assist
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 113
                                            • 114
                                            • 105 / 114
