    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • I
      ideas_arte @ideas_arte
      @ideas_arte
      I had to desable the Animator:
      fredo6F 1 Reply Last reply
      • fredo6F
        fredo6 @ideas_arte
        @ideas_arte
        Do you know what version of Animator you had. You may try with installing its latest version.
        • fredo6F
          NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
          LibFredo6 14.9a is a major release. It includes changes related to:
          • FredoBatch v1.2a
          • Bug Fixing
          • K
            Kevin Reza Arnanda Newcomers
            THANK YOU
            • fredo6F
              NEW RELEASE: LibFredo6 v15.0a - 31 Dec 24
              LibFredo6 15.0a is a major release. It includes changes related to:
              • FredoBatch v1.3a
              • Bug Fixing
              • K
                kngpw
                I cannot install the latest libredo6 15.0a on my new computer.
                I have tried to reinstall the plugin + Sketchup many times. It keeps giving me the same results.
                Extension Errors Report
                SketchUp: 24.0.594
                OS: Windows 11
                Ruby: 3.2.2
                Extension: Fredo6 LibFredo6 (15.0a - 31 Dec 24)
                Error: ArgumentError (invalid byte sequence in UTF-8)
                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                • fredo6F
                  Do you have a Windows computername with non-roman characters?
                  K 1 Reply Last reply
                  • K
                    kngpw @fredo6
                    @fredo6
                    I do! I only change the real Windows computername posting here for privacy reason.
                    TIGT 1 Reply Last reply
                      TIG Moderator @kngpw
                      @kngpw said in [Plugin Library] LibFredo6 - v15.0a - 31 Dec 24:
                      @fredo6
                      Non-ASCII characters in a computer-name is against Windows requirements and can break things like licensing !
                        Juca Ross
                        Excelente, funciona de maravilla
                        • fredo6F
                          NEW RELEASE: LibFredo6 v15.1a - 22 Feb 25
                          LibFredo6 15.1a is a major release. It includes changes related to:
                          • Animator v4.2a
                          • Compatiility SU2025
                          • Bug Fixing
                          • fredo6F
                            NEW RELEASE: LibFredo6 v15.2a - 12 Mar 25
                            LibFredo6 15.2a is a major release. It includes changes related to:
                            • Animator v4.3a
                            • Bug Fixing (random failure of menu loading)
                            • G
                              GavinG
                              Good evening, I recently upgraded to SKP 2025 and have migrated all the plugins; I am trying to use them but while they are on the ribbon, they do not open or function; I have licences for them; please assist
                              • fredo6F
                                Could you open the Ruby Console before launching the tools, in order to track possible errors.
                                • G
                                  GavinG
                                  Good day, I have upgraded to SKP 25 and migrated the plugins; as indicated I also downloaded the bugfix, but am struggling to get the plugins to function at all. I keep getting warning messages and while the window loads for the function, it doesn't work.
                                  I use predominantly Curviloft / Joint push pull / FredoCorner
                                    @GavinG
                                    When you say you 'migrated' the plugins, did you install them from scratch using the ExtensionStore³ dialog, or from RBZs downloaded from the PluginStore ?
                                    What are the 'warning messages' ? Knowing these would be most helpful...
                                    PS: Don't give your email address in a public forum, some spam-bot may have already scraped it up. I've obfuscated it a bit, but you might want to do it yourself.
                                    Conversations through forum posts are the most effective, Chats [PMs] can be used if you are providing confidential stuff, emails are a last resort - for licensing problems etc...
                                    • fredo6F
                                      fredo6 @GavinG
                                      @GavinG
                                      It would be good that you show the warning messages.
                                      Anyway, could you invoke the menu Window > LibFredo6 Settings... > Fredo6 Plugins information for Sketchucation Support.
                                      This will list my plugins installed and their status. Just copy / paste the text and post it here.
                                      • G
                                        gkont1983 Newcomers @fredo6
                                        @fredo6 said in [Plugin Library] LibFredo6 - v15.2a - 12 Mar 25:
                                        IMPORTANT: from now on, LibFredo6 and all my plugins are ONLY maintained for SU2017 and above. If you run a legacy version of Sketchup (up to SU2016), you can find the frozen legacy versions of LibFredo6 and my plugins here.
                                        The information on LibFredo6 is maintained on the Plugin Home Page of LibFredo6. This is also where you can download the RBZ file.
                                        • Sketchup version: SU2017 and above (for Mac M1, SU2021 and above)
                                        • Usage: Free
                                        If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video:
                                        LibFredo6 is a shared plugin library used by most of my plugins. LibFredo6 takes care, among others, of enriching my plugins with a few capabilities such as default parameters, language translation, Check Plugins for Update, Trace logging, etc.
                                        It is NOT a standalone plugin. It must be installed once and updated as needed when new versions are published.
                                        LibFredo6 User Manual - English - v5.2.pdf
                                        I have Sketchup 2025 and the plugin cannot be installed whatever I do.
                                          @gkont1983
                                          How have you tried to install Libredo6 ?
                                          The two ways are:
                                          Download its RBZ from the PluginStore, then use the Extension manager to Install it. After that restart SketchUp to sync everything.
                                          Or use the SketchUcation toolset ExtensionStore dialog to find it, click to auto-install it - sidestepping the RBZ download. After that restart SketchUp to sync everything.
                                          You need the SketchUcation toolset installed for the SCF licensing etc - especially of many of Fredo's extensions.
                                          So I recommend you download its RBZ from the PluginStore, then use the Extension manager to Install it. After that restart SketchUp to sync everything.
                                          After that always use the ExtensionStore dialog to install future extensions - it's vital for licensing, but it offers lots of other perks too...
                                            JDzign Newcomers
                                            I just downloaded LibFredo6 rbz file then went to extension warehouse in Sketch Up to install and enable it, then restarted Sketch Up, but I don't see the extension in my tools palette where all the other extensions are? What am I doing wrong?
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 115
                                            • 116
                                            • 105 / 116
