    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
      a4jp.com
      Can you make it so we can add time to the clock? I opened the clock on old projects but I want to add the time I have worked on those files before.
      • fredo6F
        NEW RELEASE: LibFredo6 v14.8a - 26 Nov 24
        LibFredo6 14.8a is a major release. It includes changes related to:
        • FredoBatch v1.1a
        • Bug Fixing
        I 1 Reply Last reply
          Rachel23
          I'm disappointed. I downloaded it and it said its expired. So i bought your extension for 15 dollars and then redownloaded it and it still says expired and I've relogged in many times.
            Rich O Brien Moderator @Rachel23
            @Rachel23 Licenses need to be activated per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
            • N
              Nicolla
              Hi guys.
              I downloaded recent update but it messed something up with Joint Push Pull
              I can't make shell and thicken the most simplest shapes, like the cube with 3 faces removed
              Have you noticed this too and how can I solve it? Thanks πŸ™‚
              TIGT 1 Reply Last reply
                TIG Moderator @Nicolla
                @Nicolla
                If you try it with the Ruby Console [Extensions > Developer submenu] open do you see any error messages, or do you get any other error message dialogs when trying it ?
                If you attach a simple SKP, with the problems you are experiencing, and a step by step of instructions, it would help us understand your problems...
                • I
                  ideas_arte @fredo6
                  @fredo6
                  Extension Errors Report
                  SketchUp: 24.0.484
                  OS: Windows 10
                  Ruby: 3.2.2
                  Extension: Fredo6 LibFredo6 (14.8a - 26 Nov 24)
                  Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in block in super_flatten'
                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in super_flatten'
                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:860:in load_from_config' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins'
                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins'
                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
                  C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                  fredo6F 1 Reply Last reply
                  • fredo6F
                    fredo6 @ideas_arte
                    @ideas_arte
                    Can you check the version of Animator you have in your enviroment.
                    The best is to invoke the menu Window > LibFredo6 Settngs > Fredo6 Plugin information for Sketchucation Support.
                    • I
                      ideas_arte @fredo6
                      @fredo6
                      Fredo6 Plugins Information on 2024-12-05 14:25:10 -0600
                      • Sketchup: 24.0.484
                      • LibFredo6: v14.8a
                      • LibFredo6 Binary loaded
                      • Sketchucation ExtensionStore: 4.4.1
                      • SCFLicense: v6.4a - 74
                      • Fredo6 Plugins
                        FredoTools v4.5c
                        ThruPaint v2.8a
                        TopoShaper v2.7a
                        Signature File: absent
                      • I
                        ideas_arte @ideas_arte
                        @ideas_arte
                        I had to desable the Animator:
                        • fredo6F
                          fredo6 @ideas_arte
                          @ideas_arte
                          Do you know what version of Animator you had. You may try with installing its latest version.
                          • fredo6F
                            NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
                            LibFredo6 14.9a is a major release. It includes changes related to:
                            • FredoBatch v1.2a
                            • Bug Fixing
                            • K
                              Kevin Reza Arnanda Newcomers
                              THANK YOU
                              • fredo6F
                                NEW RELEASE: LibFredo6 v15.0a - 31 Dec 24
                                LibFredo6 15.0a is a major release. It includes changes related to:
                                • FredoBatch v1.3a
                                • Bug Fixing
                                • K
                                  kngpw
                                  I cannot install the latest libredo6 15.0a on my new computer.
                                  I have tried to reinstall the plugin + Sketchup many times. It keeps giving me the same results.
                                  SketchUp: 24.0.594
                                  OS: Windows 11
                                  Ruby: 3.2.2
                                  Extension: Fredo6 LibFredo6 (15.0a - 31 Dec 24)
                                  Error: ArgumentError (invalid byte sequence in UTF-8)
                                  c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                                  c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                                  c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                                  c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                                  c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                                  C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                  C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                                  • fredo6F
                                    Do you have a Windows computername with non-roman characters?
                                    K 1 Reply Last reply
                                    • K
                                      kngpw @fredo6
                                      @fredo6
                                      I do! I only change the real Windows computername posting here for privacy reason.
                                        TIG Moderator @kngpw
                                        @kngpw said in [Plugin Library] LibFredo6 - v15.0a - 31 Dec 24:
                                        @fredo6
                                        Non-ASCII characters in a computer-name is against Windows requirements and can break things like licensing !
                                          Juca Ross
                                          Excelente, funciona de maravilla
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v15.1a - 22 Feb 25
                                            LibFredo6 15.1a is a major release. It includes changes related to:
                                            • Animator v4.2a
                                            • Compatiility SU2025
                                            • Bug Fixing
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 113
                                            • 114
                                            • 105 / 114
