    [Plugin Library] LibFredo6 - v16.4a - 11 Nov 26
    2.3k Posts 593 Posters 14.0m Views 595 Watching
    • N
      natas_ha @TIG
      @TIG FredoCorner_v2.7a this extension and I bought the Perpetual licence. I installed the rbz file and nothing is happening. It gives me constantly this:Screenshot 2024-11-08 150415.jpg
      Dave RD 1 Reply Last reply
        Dave R @natas_ha
        @natas_ha are you sure you bought the license for FredoCorner and not RoundCorner? Many people have gotten confused and tried to use the license for one on the other. They are different extensions and require different licenses.
        Did you install LibFredo6 using the Sketchucation ExtensionStore and then restart SketchUp?
        • fredo6F
          NEW RELEASE: LibFredo6 v14.7a - 09 Nov 24
          LibFredo6 14.7a is a major release. It includes changes related to:
          • ThruPaint v2.8a
          • New plugins
          • Future compatibility
          • Bug Fixing
          F 1 Reply Last reply
          • F
            FlorinAp @fredo6
            @fredo6 This one has at least one bug - doesn't allow Lord of the Toolbars to add/remove icons, neither in the toolbars and neither in palettes.!
            Edit: For SU 2023.!
            fredo6F 1 Reply Last reply
            • fredo6F
              fredo6 @FlorinAp
              @FlorinAp
              You are correct. I simply forgot to publish LOTT to adjust with necessary changes in LibFredo6.
              LOTT is now published as v2.8a.
                a4jp.com
                Can you make it so we can add time to the clock? I opened the clock on old projects but I want to add the time I have worked on those files before.
                • fredo6F
                  NEW RELEASE: LibFredo6 v14.8a - 26 Nov 24
                  LibFredo6 14.8a is a major release. It includes changes related to:
                  • FredoBatch v1.1a
                  • Bug Fixing
                  I 1 Reply Last reply
                    Rachel23
                    I'm disappointed. I downloaded it and it said its expired. So i bought your extension for 15 dollars and then redownloaded it and it still says expired and I've relogged in many times.
                      Rich O Brien Moderator @Rachel23
                      @Rachel23 Licenses need to be activated per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                      • N
                        Nicolla
                        Hi guys.
                        I downloaded recent update but it messed something up with Joint Push Pull
                        I can't make shell and thicken the most simplest shapes, like the cube with 3 faces removed
                        Have you noticed this too and how can I solve it? Thanks πŸ™‚
                        TIGT 1 Reply Last reply
                          TIG Moderator @Nicolla
                          @Nicolla
                          If you try it with the Ruby Console [Extensions > Developer submenu] open do you see any error messages, or do you get any other error message dialogs when trying it ?
                          If you attach a simple SKP, with the problems you are experiencing, and a step by step of instructions, it would help us understand your problems...
                          • I
                            ideas_arte @fredo6
                            @fredo6
                            Extension Errors Report
                            SketchUp: 24.0.484
                            OS: Windows 10
                            Ruby: 3.2.2
                            Extension: Fredo6 LibFredo6 (14.8a - 26 Nov 24)
                            Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in block in super_flatten'
                            c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in super_flatten'
                            c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:860:in load_from_config' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins'
                            c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins'
                            c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
                            C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                            • fredo6F
                              fredo6 @ideas_arte
                              @ideas_arte
                              Can you check the version of Animator you have in your enviroment.
                              The best is to invoke the menu Window > LibFredo6 Settngs > Fredo6 Plugin information for Sketchucation Support.
                              • I
                                ideas_arte @fredo6
                                @fredo6
                                Fredo6 Plugins Information on 2024-12-05 14:25:10 -0600
                                • Sketchup: 24.0.484
                                • LibFredo6: v14.8a
                                • LibFredo6 Binary loaded
                                • Sketchucation ExtensionStore: 4.4.1
                                • SCFLicense: v6.4a - 74
                                • Fredo6 Plugins
                                  FredoTools v4.5c
                                  ThruPaint v2.8a
                                  TopoShaper v2.7a
                                  Signature File: absent
                                • I
                                  ideas_arte @ideas_arte
                                  @ideas_arte
                                  I had to desable the Animator:
                                  • fredo6F
                                    fredo6 @ideas_arte
                                    @ideas_arte
                                    Do you know what version of Animator you had. You may try with installing its latest version.
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
                                      LibFredo6 14.9a is a major release. It includes changes related to:
                                      • FredoBatch v1.2a
                                      • Bug Fixing
                                      • K
                                        Kevin Reza Arnanda Newcomers
                                        THANK YOU
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v15.0a - 31 Dec 24
                                          LibFredo6 15.0a is a major release. It includes changes related to:
                                          • FredoBatch v1.3a
                                          • Bug Fixing
                                          • K
                                            kngpw
                                            I cannot install the latest libredo6 15.0a on my new computer.
                                            I have tried to reinstall the plugin + Sketchup many times. It keeps giving me the same results.
                                            SketchUp: 24.0.594
                                            OS: Windows 11
                                            Ruby: 3.2.2
                                            Extension: Fredo6 LibFredo6 (15.0a - 31 Dec 24)
                                            Error: ArgumentError (invalid byte sequence in UTF-8)
                                            c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                                            c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                                            c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                                            c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                                            c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                                            C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                            C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 115
                                            • 116
                                            • 105 / 116
