    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v14.8a - 26 Nov 24
      LibFredo6 14.8a is a major release. It includes changes related to:
      • FredoBatch v1.1a
      • Bug Fixing
      I 1 Reply Last reply
        Rachel23
        I'm disappointed. I downloaded it and it said its expired. So i bought your extension for 15 dollars and then redownloaded it and it still says expired and I've relogged in many times.
          Rich O Brien Moderator @Rachel23
          @Rachel23 Licenses need to be activated per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
          • N
            Nicolla
            Hi guys.
            I downloaded recent update but it messed something up with Joint Push Pull
            I can't make shell and thicken the most simplest shapes, like the cube with 3 faces removed
            Have you noticed this too and how can I solve it? Thanks πŸ™‚
            TIGT 1 Reply Last reply
              TIG Moderator @Nicolla
              @Nicolla
              If you try it with the Ruby Console [Extensions > Developer submenu] open do you see any error messages, or do you get any other error message dialogs when trying it ?
              If you attach a simple SKP, with the problems you are experiencing, and a step by step of instructions, it would help us understand your problems...
              • I
                ideas_arte @fredo6
                @fredo6
                Extension Errors Report
                SketchUp: 24.0.484
                OS: Windows 10
                Ruby: 3.2.2
                Extension: Fredo6 LibFredo6 (14.8a - 26 Nov 24)
                Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in block in super_flatten'
                c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in super_flatten'
                c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:860:in load_from_config' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins'
                c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins'
                c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
                C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                fredo6F 1 Reply Last reply
                • fredo6F
                  fredo6 @ideas_arte
                  @ideas_arte
                  Can you check the version of Animator you have in your enviroment.
                  The best is to invoke the menu Window > LibFredo6 Settngs > Fredo6 Plugin information for Sketchucation Support.
                  • I
                    ideas_arte @fredo6
                    @fredo6
                    Fredo6 Plugins Information on 2024-12-05 14:25:10 -0600
                    • Sketchup: 24.0.484
                    • LibFredo6: v14.8a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      FredoTools v4.5c
                      ThruPaint v2.8a
                      TopoShaper v2.7a
                      Signature File: absent
                    • I
                      ideas_arte @ideas_arte
                      @ideas_arte
                      I had to desable the Animator:
                      • fredo6F
                        fredo6 @ideas_arte
                        @ideas_arte
                        Do you know what version of Animator you had. You may try with installing its latest version.
                        • fredo6F
                          NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
                          LibFredo6 14.9a is a major release. It includes changes related to:
                          • FredoBatch v1.2a
                          • Bug Fixing
                          • K
                            Kevin Reza Arnanda Newcomers
                            THANK YOU
                            • fredo6F
                              NEW RELEASE: LibFredo6 v15.0a - 31 Dec 24
                              LibFredo6 15.0a is a major release. It includes changes related to:
                              • FredoBatch v1.3a
                              • Bug Fixing
                              • K
                                kngpw
                                I cannot install the latest libredo6 15.0a on my new computer.
                                I have tried to reinstall the plugin + Sketchup many times. It keeps giving me the same results.
                                SketchUp: 24.0.594
                                OS: Windows 11
                                Ruby: 3.2.2
                                Extension: Fredo6 LibFredo6 (15.0a - 31 Dec 24)
                                Error: ArgumentError (invalid byte sequence in UTF-8)
                                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                                c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                                C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                                • fredo6F
                                  Do you have a Windows computername with non-roman characters?
                                  K 1 Reply Last reply
                                  • K
                                    kngpw @fredo6
                                    @fredo6
                                    I do! I only change the real Windows computername posting here for privacy reason.
                                      TIG Moderator @kngpw
                                      @kngpw said in [Plugin Library] LibFredo6 - v15.0a - 31 Dec 24:
                                      @fredo6
                                      Non-ASCII characters in a computer-name is against Windows requirements and can break things like licensing !
                                        Juca Ross
                                        Excelente, funciona de maravilla
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v15.1a - 22 Feb 25
                                          LibFredo6 15.1a is a major release. It includes changes related to:
                                          • Animator v4.2a
                                          • Compatiility SU2025
                                          • Bug Fixing
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v15.2a - 12 Mar 25
                                            LibFredo6 15.2a is a major release. It includes changes related to:
                                            • Animator v4.3a
                                            • Bug Fixing (random failure of menu loading)
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 113
                                            • 114
                                            • 105 / 114
