    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
    • I Offline
      ideas_arte @fredo6
      @fredo6
      Extension Errors Report
      SketchUp: 24.0.484
      OS: Windows 10
      Ruby: 3.2.2
      Extension: Fredo6 LibFredo6 (14.8a - 26 Nov 24)
      Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in block in super_flatten'
      c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in super_flatten'
      c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:860:in load_from_config' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins'
      c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins'
      c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
      C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
      fredo6F 1 Reply Last reply Reply Quote 0
      • fredo6F Offline
        fredo6 @ideas_arte
        @ideas_arte
        Can you check the version of Animator you have in your enviroment.
        The best is to invoke the menu Window > LibFredo6 Settngs > Fredo6 Plugin information for Sketchucation Support.
        I 1 Reply Last reply Reply Quote 0
        • I Offline
          ideas_arte @fredo6
          @fredo6
          Fredo6 Plugins Information on 2024-12-05 14:25:10 -0600
          • Sketchup: 24.0.484
          • LibFredo6: v14.8a
          • LibFredo6 Binary loaded
          • Sketchucation ExtensionStore: 4.4.1
          • SCFLicense: v6.4a - 74
          • Fredo6 Plugins
            FredoTools v4.5c
            ThruPaint v2.8a
            TopoShaper v2.7a
            Signature File: absent
          • I Offline
            ideas_arte @ideas_arte
            @ideas_arte
            I had to desable the Animator:
            • fredo6F Offline
              fredo6 @ideas_arte
              @ideas_arte
              Do you know what version of Animator you had. You may try with installing its latest version.
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
                LibFredo6 14.9a is a major release. It includes changes related to:
                • FredoBatch v1.2a
                • Bug Fixing
                  Kevin Reza Arnanda Newcomers
                  THANK YOU
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v15.0a - 31 Dec 24
                    LibFredo6 15.0a is a major release. It includes changes related to:
                    • FredoBatch v1.3a
                    • Bug Fixing
                      kngpw
                      I cannot install the latest libredo6 15.0a on my new computer.
                      I have tried to reinstall the plugin + Sketchup many times. It keeps giving me the same results.
                      SketchUp: 24.0.594
                      OS: Windows 11
                      Ruby: 3.2.2
                      Extension: Fredo6 LibFredo6 (15.0a - 31 Dec 24)
                      Error: ArgumentError (invalid byte sequence in UTF-8)
                      c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                      c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                      c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                      c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                      c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                      C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                      C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                      • fredo6F Offline
                        Do you have a Windows computername with non-roman characters?
                        K 1 Reply Last reply Reply Quote 0
                          kngpw @fredo6
                          @fredo6
                          I do! I only change the real Windows computername posting here for privacy reason.
                          TIGT 1 Reply Last reply Reply Quote 0
                            TIG Moderator @kngpw
                            @kngpw said in [Plugin Library] LibFredo6 - v15.0a - 31 Dec 24:
                            @fredo6
                            Non-ASCII characters in a computer-name is against Windows requirements and can break things like licensing !
                              Juca Ross
                              Excelente, funciona de maravilla
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v15.1a - 22 Feb 25
                                LibFredo6 15.1a is a major release. It includes changes related to:
                                • Animator v4.2a
                                • Compatiility SU2025
                                • Bug Fixing
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v15.2a - 12 Mar 25
                                  LibFredo6 15.2a is a major release. It includes changes related to:
                                  • Animator v4.3a
                                  • Bug Fixing (random failure of menu loading)
                                    GavinG
                                    Good evening, I recently upgraded to SKP 2025 and have migrated all the plugins; I am trying to use them but while they are on the ribbon, they do not open or function; I have licences for them; please assist
                                    • fredo6F Offline
                                      Could you open the Ruby Console before launching the tools, in order to track possible errors.
                                        GavinG
                                        Good day, I have upgraded to SKP 25 and migrated the plugins; as indicated I also downloaded the bugfix, but am struggling to get the plugins to function at all. I keep getting warning messages and while the window loads for the function, it doesn't work.
                                        I use predominantly Curviloft / Joint push pull / FredoCorner
                                          @GavinG
                                          When you say you 'migrated' the plugins, did you install them from scratch using the ExtensionStore³ dialog, or from RBZs downloaded from the PluginStore ?
                                          What are the 'warning messages' ? Knowing these would be most helpful...
                                          PS: Don't give your email address in a public forum, some spam-bot may have already scraped it up. I've obfuscated it a bit, but you might want to do it yourself.
                                          Conversations through forum posts are the most effective, Chats [PMs] can be used if you are providing confidential stuff, emails are a last resort - for licensing problems etc...
                                          • fredo6F Offline
                                            fredo6 @GavinG
                                            @GavinG
                                            It would be good that you show the warning messages.
                                            Anyway, could you invoke the menu Window > LibFredo6 Settings... > Fredo6 Plugins information for Sketchucation Support.
                                            This will list my plugins installed and their status. Just copy / paste the text and post it here.
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 111
                                            • 112
                                            • 105 / 112
