    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 457.1k Views 109 Watching
    • samuel_tS Offline
      samuel_t @sashapepperspray
      @sashapepperspray This error message indicates that the bug occurs when a polygon reduction is requested, in the SU viewport, with the plugin toolbar... but I don't know why.
      Have you succeeded in this operation with other 3D models? Or this operation fails everytime, whatever the 3D model?
      S 1 Reply Last reply Reply Quote 0
        sashapepperspray @samuel_t
        @samuel_t It happens anytime I try any model, and also when I try importing models, I get this error
        samuel_tS 1 Reply Last reply Reply Quote 0
        • samuel_tS Offline
          @sashapepperspray Do you have Windows 10 or Windows 11? Are you Administrator of your OS?
          S S 2 Replies Last reply Reply Quote 0
            @samuel_t I am the administrator, and I have windows 11
            • samuel_tS Offline
              @sashapepperspray
              Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
              Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system πŸ€”
                @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
                • samuel_tS Offline
                  @sashapepperspray
                  The security software is just a clue, I don't know if that's the issue.
                  Using the Windows File Explorer, can you please access this folder:
                  C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
                  Run assimp.exe and then report to this thread any errors you see.
                    @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
                      cuagn
                      Hello,
                      I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
                      I try to use it today and I face this error, even after a reinstall of UI 1.2.6
                      alt text
                      I'm running
                      Windows 11 Professionnel
                        shagrat @samuel_t
                        Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                        Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                        Really hope you can help as it takes forever to draw them from scratch.
                        Many thanks.
                        TIGT 1 Reply Last reply Reply Quote 0
                          TIG Moderator @shagrat
                          @shagrat
                          I'm sure samuel will chip in...
                          In the meanwhile...
                          The error message refers to v1.2.4 - there is a newer version v1.2.6
                          Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                          It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                          Meanwhile install the newest version of the extension...
                            shagrat @TIG
                            @TIG I've downloaded the latest version and get the following message:
                            The file I'm trying to import is this:
                            Hope someone can help as I have 40 of these components to import (or I have to draw them from scratch in SketchUp ☹
                            Cheers
                            TIGT samuel_tS 2 Replies Last reply Reply Quote 0
                              @shagrat
                              At least you're getting new errors !!
                              Hopefully @samuel_t can comment asap...
                              • V Offline
                                vadhome
                                Hi! The extension does not work on MacOS Ventura M2 . How to install it correctly?!error.jpg
                                  sashapepperspray @sashapepperspray
                                  @sashapepperspray
                                  I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
                                  do you have any ideas?
                                  • E Offline
                                    esthery Newcomers
                                    getting this error.. any solution?
                                    • samuel_tS Offline
                                      samuel_t @shagrat
                                      @shagrat Sorry, I didn't see your posts. I think it's too late now...
                                      This issue could be related to importing a model from a remote server (here \\fileserver).
                                      • samuel_tS Offline
                                        samuel_t @vadhome
                                        @vadhome Hi! Someone else reported an issue importing CAD files (such as STEP) on macOS with Universal Importer. I plan to rent a Mac to investigate...
                                        • samuel_tS Offline
                                          @sashapepperspray, @esthery Can you please send me (in private if you prefer) the source model you're trying to import?
                                            @samuel_t Any model I try doesn't work, but here is onejuggler.obj
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
