    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
      RLGL
      I tried the Universal Importer using a 3D step file from McMaster Carr of a bolt and nut. The bolt was 3/4" long. The import brought it in over 100" long.. Am I asking too much to have it come in at the correct scale?
      samuel_tS 1 Reply Last reply
      • samuel_tS
        samuel_t @RLGL
        @RLGL No but can I ask you for a coffee in exchange? I need more blood in my veins to fix the wrong scale problem πŸ˜…
        MikeG73M 1 Reply Last reply
        • MikeG73M
          MikeG73 @samuel_t
          @samuel_t Hello Sam, this is a great extension, thank you. But it does not seem to support .blend files, very well. Is there a fix?
          Cheers!
          • samuel_tS
            samuel_t
            Hello everyone πŸ™‚
            The 1.2.6 version:
            • Allows you to specify the source model units (millimeters, centimeters, etc). Most probable units, for the model you are importing, are preselected to accelerate the workflow. However, be still attentive with unitless formats such as OBJ, real scale depends on specifications.
            • Automatically fixes, on SketchUp 2018 and newer versions, bad texture coordinates of some glTF models and "unexpected face count after polygon reduction" issue. If you are a SketchUp 2017 user, you will find a manual solution in the Troubleshooting FAQ of the plugin.
            • Handles polygon reduction of STEP/IGES/BREP models during the import.
            • Automatically fixes orientation of STEP/IGES/BREP models for last time? πŸ˜…
            Download latest Universal Importer plugin from SketchUcation PluginStore.
            • samuel_tS
              samuel_t
              @RLGL
              I think it's fine now. I imported with the Universal Importer v1.2.6 many STEP and IGES files from McMaster Carr and their scale is everytime correct in SketchUp. Be sure to let millimiters as "Source model units" when importing...
              • samuel_tS
                samuel_t @MikeG73
                Hello @MikeG73
                Thanks πŸ˜‰
                Indeed, BLEND format support in this extension is limited to older .blend files and one must claim then map the textures manually...
                I hope to improve that in the future πŸ˜‡
                Cheers!
                  RLGL
                  I have the latest DL. Thank you for the update. The scale is now correctly imported.
                  Dave
                    sashapepperspray
                    I have just updated the plugin and tried using it, and I get the following error:
                    Universal Importer Error: Command failed: cd /d "C:/Users/tenen/AppData/Local/Temp/Universal Importer" && "C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Assimp/Win/assimp.exe" export "export.dae" "export.obj" -tri
                    I tried going to a previous version of sketchup, where I have an older version of the plugin, and I have the same error
                    Do you know what this error is, and how I could fix it?
                      sashapepperspray @sashapepperspray
                      This is the complete error:
                      C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
                      Universal Importer Version: 1.2.6
                      I have tried uninstalling and reinstalling microsoft visual runtime, and I still have the problem.
                      @samuel_t do you have any ideas about this? thank you
                      • samuel_tS
                        samuel_t @sashapepperspray
                        @sashapepperspray This error message indicates that the bug occurs when a polygon reduction is requested, in the SU viewport, with the plugin toolbar... but I don't know why.
                        Have you succeeded in this operation with other 3D models? Or this operation fails everytime, whatever the 3D model?
                          sashapepperspray @samuel_t
                          @samuel_t It happens anytime I try any model, and also when I try importing models, I get this error
                          • samuel_tS
                            @sashapepperspray Do you have Windows 10 or Windows 11? Are you Administrator of your OS?
                            S S 2 Replies Last reply
                              @samuel_t I am the administrator, and I have windows 11
                              • samuel_tS
                                @sashapepperspray
                                Can you please confirm that the latest Visual C++ Redistributable x64 is installed on your Windows? Here is a reference screenshot:
                                Hypothesis: You have a security software that blocks the Assimp executable (assimp.exe) when it tries to access the file system πŸ€”
                                  @samuel_t I have the laset visual c++ installed. Do you know how I could fix this security problem?
                                  • samuel_tS
                                    @sashapepperspray
                                    The security software is just a clue, I don't know if that's the issue.
                                    Using the Windows File Explorer, can you please access this folder:
                                    C:\Users\tenen\AppData\Roaming\SketchUp\SketchUp 2024\SketchUp\Plugins\universal_importer\Applications\Assimp\Win
                                    Run assimp.exe and then report to this thread any errors you see.
                                      @samuel_t nothing happens, a screen pops up for half a second, but disappears, and that is it.
                                      • C
                                        cuagn
                                        Hello,
                                        I've installed Universal Importer 1.2.6 llast July in order to use it with SketchUp Make 2017 (I'm not a PRO, just for Hobby).
                                        I try to use it today and I face this error, even after a reinstall of UI 1.2.6
                                        alt text
                                        I'm running
                                        Windows 11 Professionnel
                                          shagrat @samuel_t
                                          Hi, I'm having a similar issue with this extension, I just get an error message (below) when I try to import a step file. This is the first time I've tried using this extension.
                                          Any help would be greatly appreciated. I have a whole bunch of components to import from a customer (I'm designing an assembly machine for him).
                                          Really hope you can help as it takes forever to draw them from scratch.
                                          Many thanks.
                                          TIGT 1 Reply Last reply
                                            TIG Moderator @shagrat
                                            @shagrat
                                            I'm sure samuel will chip in...
                                            In the meanwhile...
                                            The error message refers to v1.2.4 - there is a newer version v1.2.6
                                            Also the error message relates to the import of an STP file as an OBJ file - you say in your text it was a STeP file [AP203/214 an 242 are supported]
                                            It will help samuel if you clarify exactly what file-type you are trying to import and how you are doing it...
                                            Meanwhile install the newest version of the extension...
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
