    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 12.2k Views 7 Watching
      Mike Amos @Bryan K
      @Bryan-K
      Ta mate, feedback always helpful. Building and rendering the scene can lead to missing/ignoring stuff.
      Rich O BrienR P Bryan KB 3 Replies Last reply Reply Quote 0
      • Rich O BrienR Online
        @Mike-Amos If the sun coming in the window is a directional light you should raise the angle values slightly to soften the shadow.
        I sometime mix both HDRIs and Directional Lights to get the light the way I want it.
        HDRs are great but some might offer you the background you want but not the light direction or power. Adding a directional to give you more artistic controls is sometimes a good hack.
        Be mindful of power values and balance it.
        A directional light with zero angle results in crisp clean shadows...
        Increasing it to 2-3 will soften edges....
        massimoM 1 Reply Last reply Reply Quote 1
        • massimoM Offline
          massimo Moderator @Rich O Brien
          Rich's ones are good advices. Even if the best HDRIs, for example P.Guthrie's and CGSource's ones just to name two, don't need any extra sun because produce nice shadows, most of them need a bit of boost.
          Does Rayscaper have something like this however?
          I mean that you can move the sun in the physical sky until it will match the one in the HDRI. Because if not would be really difficult to align the two suns and this could lead to a fake result.
            Rich O Brien Moderator @massimo
            @massimo said in Rayscaper, My trip down the road to adjumacation.:
            No, it's guesswork if you want to align HDR sun and a directional light.
            massimoM Mike AmosM 2 Replies Last reply Reply Quote 1
            • massimoM Offline
              @Rich-O-Brien Ok, maybe a suggestion for the next release then.πŸ˜‰
                Mike Amos @Rich O Brien
                @Rich-O-Brien
                On the subject of artificial lighting, is there a way to introduce a 'glow' to the light unit somehow? Something to essentially, mimic a lightbulb.
                Mike AmosM Rich O BrienR P 3 Replies Last reply Reply Quote 0
                  Mike Amos @Mike Amos
                    @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
                    A couple of versions back there was a way. But at the moment it seems to me there's a bug with having both emissive materials and lights in a scene.
                    I need to test more to see if that is the case.
                    But to your bulb appearance query. I couldn't get any shader to respect how light should behave as it passes through a frosted glass. When I did get close the render times weren't worth the effort. It also crashed a few times during testing so that dampens my enthusiasm a tad.
                    I will try though. Thomas would benefit from seeing where shaders are not doing what is expected from a users point of reference.
                      @Rich-O-Brien
                      I was wondering if a different layer may help but going back to renditioner, which had a similar method, it may make no discernable difference.
                        @Mike-Amos
                        What I have so far, I placed a flat plain just behind the emitter light (Directional) and reduced the opacity a lot. there is some room for improvement with temp etc but a start.
                          @Mike-Amos
                          Here was a test I did yesterday. The bulb has a Glass shader with Roughness and Transparent Shadows.
                          Inside I put a Sphere Light. Its not behaving right though. I still believe that lights and the values needed are off.
                            pixelcruncher Extension Creator @Mike Amos
                            @Mike-Amos The missing skirting board and lights, was that caused by a bug in Rayscaper?
                              @Mike-Amos
                              You can use fake emission. - This will give objects a glowy appearance, but they are not really lights, so they won't shine on the surrounding objects. Using the fake emission option will also reduce render times.
                              In the below image, the left sphere has normal emission and the right sphere has fake emission.
                                pixelcruncher Extension Creator @Rich O Brien
                                @Rich-O-Brien This looks indeed buggy, thanks for the information and I will look into this problem.
                                • Bryan KB Offline
                                  Bryan K @Mike Amos
                                  @Bryan-K
                                  I hear ya. Happens to me all the time. πŸ˜‰
                                  • Bryan KB Offline
                                    Oh that last one is damn good!
                                      Mike Amos @Bryan K
                                      @Bryan-K
                                      I have notioced glitching and pixel loss on the monitor but a pixel fitness test proves the monito is fine and the graphics cards GPU is the culprit, probably one of the issues I have had since I got this pc. A nuisance but that's folks life........
                                        My last post was not at anyone, that bleep thing is a pain. Just a cmooent in the thread about the experience of the process of rendering the model. I can no longer render with Rayscaper probably due to the graphics card/gpu. Soon have the beast off for repair though.
                                          @Mike-Amos
                                          Well, the beast has been received at the treatment centre so I am running the old machine, similar size etc so no surprises it looks and smells the same.
                                          The internal dimensions are 12'square for the main rooms with a 5 foot bathroom and entry downstairs.
                                          Entourage and some tweaks are all for the model I think then get some attention to the lighting!
                                          For some reason when selecting gpu render, this pc reverts from 2748 x 1048 to 1000 x 1000 pixel size.
                                            @Mike-Amos
                                            Well, had a thunk to add a reading light over the desk, balance. I still do not have it yet but, I am looking.
                                            Peace out.
                                            Lightened in Irfanview. The original was blurry dark.
                                            • 3 / 9
