    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 29.1k Views 7 Watching
      Mike Amos @Mike Amos
      @Mike-Amos
      What I have so far, I placed a flat plain just behind the emitter light (Directional) and reduced the opacity a lot. there is some room for improvement with temp etc but a start.
        @Mike-Amos
        Here was a test I did yesterday. The bulb has a Glass shader with Roughness and Transparent Shadows.
        Inside I put a Sphere Light. Its not behaving right though. I still believe that lights and the values needed are off.
          pixelcruncher Extension Creator @Mike Amos
          @Mike-Amos The missing skirting board and lights, was that caused by a bug in Rayscaper?
            @Mike-Amos
            You can use fake emission. - This will give objects a glowy appearance, but they are not really lights, so they won't shine on the surrounding objects. Using the fake emission option will also reduce render times.
            In the below image, the left sphere has normal emission and the right sphere has fake emission.
              pixelcruncher Extension Creator @Rich O Brien
              @Rich-O-Brien This looks indeed buggy, thanks for the information and I will look into this problem.
              • Bryan KB Offline
                Bryan K @Mike Amos
                @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
                @Bryan-K
                Ta mate, feedback always helpful. Building and rendering the scene can lead to missing/ignoring stuff.
                I hear ya. Happens to me all the time. πŸ˜‰
                • Bryan KB Offline
                  Oh that last one is damn good!
                    Mike Amos @Bryan K
                    @Bryan-K
                    I have notioced glitching and pixel loss on the monitor but a pixel fitness test proves the monito is fine and the graphics cards GPU is the culprit, probably one of the issues I have had since I got this pc. A nuisance but that's folks life........
                      My last post was not at anyone, that bleep thing is a pain. Just a cmooent in the thread about the experience of the process of rendering the model. I can no longer render with Rayscaper probably due to the graphics card/gpu. Soon have the beast off for repair though.
                        @Mike-Amos
                        Well, the beast has been received at the treatment centre so I am running the old machine, similar size etc so no surprises it looks and smells the same.
                        The internal dimensions are 12'square for the main rooms with a 5 foot bathroom and entry downstairs.
                        Entourage and some tweaks are all for the model I think then get some attention to the lighting!
                        For some reason when selecting gpu render, this pc reverts from 2748 x 1048 to 1000 x 1000 pixel size.
                          @Mike-Amos
                          Well, had a thunk to add a reading light over the desk, balance. I still do not have it yet but, I am looking.
                          Peace out.
                          Lightened in Irfanview. The original was blurry dark.
                            Nice render Mike!
                            Can you reproduce this consistently? Smells like a bug.
                            Well, I had a thunk to add a reading light over the desk, balance. I still do not have it yet but, I am looking.
                            Maybe this is something I can help with? Is the light just not rendering, or are you having trouble configuring the light?
                            Cheers,
                            Thomas
                            Mike AmosM 2 Replies Last reply Reply Quote 0
                              Mike Amos @pixelcruncher
                              @pixelcruncher
                              Well, difficult to say if there is any illumination from the unit, it has a fake emitter and two directional lights which are pointing in the correct direction. Still getting myself oriented with these lights.
                                @pixelcruncher
                                Essentially the balance issues make it difficult for me to see where the illumination level is do I will have to render a scene or two with just the lamps I have made and adjust from there.
                                  @Mike-Amos
                                  Weird this, one spotlight and one directional light along with the fake emitter surface.
                                  I ramped up the directional light alone to 100.00 watts. OK, distance that this illumination appears at needs adjusting. I then reduce the power levels to zero watts and the illumination does not change. I will close Rayscaper and open it again, see what happens.
                                    @Mike-Amos
                                    OK, part of the reasons for a simple black screen rather than a render is that for some reason, there were TWO 'ghost white' textures/colours imported. Only one of which had any reference to 'glass'.
                                    Nice to find that.
                                    Even at 200w the cone of light is not apparent from the now 2 x spotlights.
                                      @Mike-Amos
                                      OK, the properties assigned to materials etc in Rayscaper are not surviving shutdown and restart on this pc. Memory? 32gig and a decent graphics card suggests not.
                                        @Mike-Amos I believe there's issues when there's a mix of emission materials.
                                        There's also some odd behaviour whereby an emission value will decide to not emit light until you reset it.
                                        I'd wait for a fix around lights
                                          Rich O Brien Moderator @Rich O Brien
                                          @Mike-Amos
                                          Here a little scene to see the values I used to light scene:
                                          watchmen-emit-scene_2020.skp
                                          I'd be interested in your render times. This is 30s for me on GPU
                                            Mike Amos @Rich O Brien
                                            @Rich-O-Brien
                                            With Sketchup v2022, instant crash, no bugsplat.
                                            • 3 / 9
