[Plugin][$] JointPushPull Interactive - v4.8a - 30 Mar 24
@wharfedale1976
Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply. -
Fredo6 Plugins Information on 2024-03-23 23:29:13 +0300
- Platform: x64-mswin64_140 - Ruby: 2.7.7
- Sketchup: 23.1.340
- LibFredo6: v14.2a
- LibFredo6 Binary loaded
- Sketchucation ExtensionStore: 4.3.1
- SCFLicense: v6.1a - 72
- Fredo6 Plugins
Curviloft v1.9b
Curvizard v2.4b
FredoPortrait v2.8a
FredoScale v3.5a
FredoSketch v1.3a
FredoSpline v2.5a
FredoTools v4.4a
JointPushPull v4.7a
MoveAlignMe v1.2a
RoundCorner v3.3a
ToolsOnSurface v2.5a
TopoShaper v2.6a
VisuHole v1.4b - SCFLicense directory present
Signature File: 2024-01-27 16:19:01 +0300
Curviloft: 2024-01-27 16:19:12 +0300
Curvizard: 2024-01-27 16:20:12 +0300
FredoScale: 2024-01-27 16:20:42 +0300
FredoSpline: 2024-01-27 16:21:06 +0300
ToolsOnSurface: 2024-01-27 16:21:51 +0300
TopoShaper: 2024-01-27 16:22:07 +0300
VisuHole: 2024-01-27 16:22:18 +0300
"Add help menu!"
"create new"
(eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
"created"
#Sketchup::Menu:0x000002b1bf9540e8 -
I deleted the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file located in the \SCF Licenses folder. And when I reinstalled the licenses of the two plugins that gave the license error, the problem was solved.
Thank you
@wharfedale1976
Do you have the latest versions downloaded and installed for those Extensions, LibFredo6 and the latest SketchUcation Tools [for the licensing] ?
Please post the errors that you got.
If it says to delete the Signature file have you done that ??
Have you then tried re-validating the licenses etc ? -
wharfedale1976 said in [Plugin][$] JointPushPull Interactive - v4.4e - 02 Jun 19:
@TIG I believe he rectified the issue by deleting the signature as prompted.
NEW RELEASE: JointPushPull Interactive v4.8a - 30 Mar 24
JointPushPull Interactive 4.8a is a major release including:
- adjustments for future compatibility
IMPORTANT: JointPushPull 4.8a requires LibFredo6 14.3 or above
See plugin home page of JointPushPull for Download of JointPushPull.
hellow!!! i have the same problem, i reinstalled the sketchup in my pc and i cant RELEASE SEATS of the jointpushpull too
@Dandelliones
Have you installed the latest versions of the SketchUcation toolset [v4.4.0], LibFredo and the Fredo extension itself ?
These have been updated for the latest SketchUp version etc...
Have you restarted SketchUp afterwards ?
Have you then tried managing your licenses yourself with the menu itemExtensions/SketchUcation/SCFLicense: My Licenses at SketchUcation...
@fredo6 Hi Fredo.
I purchased a license of Joint Push Pull Interactive and installed it, but I can't make it work.
I even tried to replicate the videos, but to no avail.I select the faces via JPP, but when I move the mouse away from the model, to access the toolbar, all faces are unselected. Also, the icon to apply the changes never turns green...
Any idea of what I may be doing wrong?
By the way, all your plugins are awesome.
@Dandelliones Yes, i do... but in my licenses managing it does not let me release the seats
@Dandelliones
OK I'll try to get someone else to resolve this...
@Rich-O-Brien -
@Dandelliones Device ID SQ.... which you activated on 01/04/24 must be using an old version of Sketchucation Tools. Please upgrade to newest version
https://sketchucation.com/plugin/696-sketchucationtools
Once you update and restart SketchUp go to Tools > Fredo Collection > JPP > License and click the Seats button.
Then visit https://sketchucation.com/webshop/my-licences.php and the release checkbox will be available
This post is deleted! -
Hi, I have purchased licenses of JointPushPull, Curviloft and TopoShaper. When I install these plugins, the activation of Curviloft and TopoShaper goes fine, but JointPushPull gets an error:
When I check my SketchUcation v4.4.0 licenses:
I don't even have it listed -
@Medness You have multiple account and purchased JPP on another account.
Login to that account and release seats
@Rich-O-Brien said in [Plugin][$] JointPushPull Interactive - v4.8a - 30 Mar 24:
Login to that account and release seatsI registered all plugins to the same email address. Where can I see for which account I got the JPP plugin? Can the accounts be merged?
@Medness Asking where to email license files is not the same as logging into a separate account and puchasing.
I can purchase licenses and ask to send them any email address for convenience. But the license files have to be associated to a user account.
In your instance you have multiple accounts so login to Medness1000 and you'll see JPP there
Merging is not possible.
Actually, the name part of the email address was registered in full lowercase for JointPushPull (versus first letter capitalized for TopoShaper and Curviloft).
I guess the system should be case insensitive to email adress...
@Rich-O-Brien I have also same issue but the problem is the seats that doesnt have check box for releasing are PC is already been dispose. Is there a way where we can force to release this seats? There's a lot on my licensing that are like this please help. Thank you .
