    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 938.0k Views 155 Watching
    • F
      frederiqueD
      Hi, thank you very much, it works finally after 2 days of trying....
        @frederiqueD
        What was the final fix that worked ?
          shamsabbas Newcomers
          why is this happening ? can i get some help pls
          Rich O BrienR TIGT 2 Replies Last reply
            Rich O Brien Moderator @shamsabbas
            @shamsabbas Please follow the steps in the alert.
            Delete signature file at C:\Users\SomeName\AppData\Local\SCF Licenses restart SketchUp and activate license.
              TIG Moderator @shamsabbas
              @shamsabbas
              Carefully read the error message.
              There is a mismatch in your computer-name and the name in the license record.
              [Perhaps you have renamed the computer or moved the license from another computer ?
              If you have given your user or computer a name that doesn't follow Microsoft's rules that can also created unexpected issues...]
              The error message advises you to erase the Signature file and the re-validate the license.
              To do this click the Yes button and the folder containing the Signature file will open.
              Delete that file [even though it's name says not to !].
              This resets your licenses on that computer.
              Now restart SketchUp, reopen the licensing dialog and this time the license validation should work.
              W 2 Replies Last reply
              • W
                wharfedale1976 @TIG
                @TIG
                @fredo6
                The same problem just happened to me.
                While other licensed Fredo plugins ran, two plugins (joint push-pull and round-corner plugins) gave errors.
                I didn't change the computer name or move the license files.
                The interesting thing is that other Fredo plugins work.
                How should I go about fixing this problem?
                Thanks and Regards
                alt text
                alt text
                alt text
                alt text
                TIGT 1 Reply Last reply
                • W
                  wharfedale1976 @TIG
                  @TIG
                  @fredo6
                  Thanks and Regards
                  fredo plugins licence.png lisans hatası.png joint push pull.png round corner.png
                    Rich O Brien Moderator @wharfedale1976
                    @wharfedale1976
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    • W
                      wharfedale1976 @Rich O Brien
                      @Rich-O-Brien
                      Fredo6 Plugins Information on 2024-03-23 23:29:13 +0300
                      • Platform: x64-mswin64_140 - Ruby: 2.7.7
                      • Sketchup: 23.1.340
                      • LibFredo6: v14.2a
                      • LibFredo6 Binary loaded
                      • Sketchucation ExtensionStore: 4.3.1
                      • SCFLicense: v6.1a - 72
                      • Fredo6 Plugins
                        Curviloft v1.9b
                        Curvizard v2.4b
                        FredoPortrait v2.8a
                        FredoScale v3.5a
                        FredoSketch v1.3a
                        FredoSpline v2.5a
                        FredoTools v4.4a
                        JointPushPull v4.7a
                        MoveAlignMe v1.2a
                        RoundCorner v3.3a
                        ToolsOnSurface v2.5a
                        TopoShaper v2.6a
                        VisuHole v1.4b
                        Signature File: 2024-01-27 16:19:01 +0300
                        Curviloft: 2024-01-27 16:19:12 +0300
                        Curvizard: 2024-01-27 16:20:12 +0300
                        FredoScale: 2024-01-27 16:20:42 +0300
                        FredoSpline: 2024-01-27 16:21:06 +0300
                        ToolsOnSurface: 2024-01-27 16:21:51 +0300
                        TopoShaper: 2024-01-27 16:22:07 +0300
                        VisuHole: 2024-01-27 16:22:18 +0300
                        "Add help menu!"
                        "create new"
                        (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                      "created"
                      • W
                        @Rich-O-Brien
                        I deleted the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file located in the \SCF Licenses folder. And when I reinstalled the licenses of the two plugins that gave the license error, the problem was solved.
                        Thank you
                          TIG Moderator @wharfedale1976
                          @wharfedale1976
                          Do you have the latest versions downloaded and installed for those Extensions, LibFredo6 and the latest SketchUcation Tools [for the licensing] ?
                          Please post the errors that you got.
                          If it says to delete the Signature file have you done that ??
                          Have you then tried re-validating the licenses etc ?
                            wharfedale1976 said in [Plugin][$] JointPushPull Interactive - v4.4e - 02 Jun 19:
                            @TIG I believe he rectified the issue by deleting the signature as prompted.
                            • fredo6F
                              NEW RELEASE: JointPushPull Interactive v4.8a - 30 Mar 24
                              JointPushPull Interactive 4.8a is a major release including:
                              • adjustments for future compatibility
                              IMPORTANT: JointPushPull 4.8a requires LibFredo6 14.3 or above
                              See plugin home page of JointPushPull for Download of JointPushPull.
                              Main Post of the JointPushPull thread on this forum
                                Dandelliones
                                hellow!!! i have the same problem, i reinstalled the sketchup in my pc and i cant RELEASE SEATS of the jointpushpull too
                                TIGT D Rich O BrienR 3 Replies Last reply
                                  TIG Moderator @Dandelliones
                                  @Dandelliones
                                  Have you installed the latest versions of the SketchUcation toolset [v4.4.0], LibFredo and the Fredo extension itself ?
                                  These have been updated for the latest SketchUp version etc...
                                  Have you restarted SketchUp afterwards ?
                                  Have you then tried managing your licenses yourself with the menu item
                                  Extensions/SketchUcation/SCFLicense: My Licenses at SketchUcation...
                                  • G
                                    g.petinati @fredo6
                                    @fredo6 Hi Fredo.
                                    I purchased a license of Joint Push Pull Interactive and installed it, but I can't make it work.
                                    I even tried to replicate the videos, but to no avail.
                                    I select the faces via JPP, but when I move the mouse away from the model, to access the toolbar, all faces are unselected. Also, the icon to apply the changes never turns green...
                                    Any idea of what I may be doing wrong?
                                    By the way, all your plugins are awesome.
                                      Dandelliones @Dandelliones
                                      @Dandelliones Yes, i do... but in my licenses managing it does not let me release the seats
                                        @Dandelliones
                                        OK I'll try to get someone else to resolve this...
                                        @Rich-O-Brien
                                          Rich O Brien Moderator @Dandelliones
                                          @Dandelliones Device ID SQ.... which you activated on 01/04/24 must be using an old version of Sketchucation Tools. Please upgrade to newest version
                                          Sketchucation Tools | SketchUcation
                                          (sketchucation.com)
                                          Once you update and restart SketchUp go to Tools > Fredo Collection > JPP > License and click the Seats button.
                                          Then visit https://sketchucation.com/webshop/my-licences.php and the release checkbox will be available
                                          H 1 Reply Last reply
                                            Medness
                                            This post is deleted!
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 30 / 31
