    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
      @frederiqueD
      What was the final fix that worked ?
        shamsabbas Newcomers
        why is this happening ? can i get some help pls
        Rich O BrienR TIGT 2 Replies Last reply
          Rich O Brien Moderator @shamsabbas
          @shamsabbas Please follow the steps in the alert.
          Delete signature file at C:\Users\SomeName\AppData\Local\SCF Licenses restart SketchUp and activate license.
            TIG Moderator @shamsabbas
            @shamsabbas
            Carefully read the error message.
            There is a mismatch in your computer-name and the name in the license record.
            [Perhaps you have renamed the computer or moved the license from another computer ?
            If you have given your user or computer a name that doesn't follow Microsoft's rules that can also created unexpected issues...]
            The error message advises you to erase the Signature file and the re-validate the license.
            To do this click the Yes button and the folder containing the Signature file will open.
            Delete that file [even though it's name says not to !].
            This resets your licenses on that computer.
            Now restart SketchUp, reopen the licensing dialog and this time the license validation should work.
            W 2 Replies Last reply
            • W
              wharfedale1976 @TIG
              @TIG
              @fredo6
              The same problem just happened to me.
              While other licensed Fredo plugins ran, two plugins (joint push-pull and round-corner plugins) gave errors.
              I didn't change the computer name or move the license files.
              The interesting thing is that other Fredo plugins work.
              How should I go about fixing this problem?
              Thanks and Regards
              alt text
              alt text
              alt text
              alt text
              TIGT 1 Reply Last reply
              • W
                wharfedale1976 @TIG
                @TIG
                @fredo6
                Thanks and Regards
                fredo plugins licence.png lisans hatası.png joint push pull.png round corner.png
                  Rich O Brien Moderator @wharfedale1976
                  @wharfedale1976
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  • W
                    wharfedale1976 @Rich O Brien
                    @Rich-O-Brien
                    Fredo6 Plugins Information on 2024-03-23 23:29:13 +0300
                    • Platform: x64-mswin64_140 - Ruby: 2.7.7
                    • Sketchup: 23.1.340
                    • LibFredo6: v14.2a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.3.1
                    • SCFLicense: v6.1a - 72
                    • Fredo6 Plugins
                      Curviloft v1.9b
                      Curvizard v2.4b
                      FredoPortrait v2.8a
                      FredoScale v3.5a
                      FredoSketch v1.3a
                      FredoSpline v2.5a
                      FredoTools v4.4a
                      JointPushPull v4.7a
                      MoveAlignMe v1.2a
                      RoundCorner v3.3a
                      ToolsOnSurface v2.5a
                      TopoShaper v2.6a
                      VisuHole v1.4b
                      Signature File: 2024-01-27 16:19:01 +0300
                      Curviloft: 2024-01-27 16:19:12 +0300
                      Curvizard: 2024-01-27 16:20:12 +0300
                      FredoScale: 2024-01-27 16:20:42 +0300
                      FredoSpline: 2024-01-27 16:21:06 +0300
                      ToolsOnSurface: 2024-01-27 16:21:51 +0300
                      TopoShaper: 2024-01-27 16:22:07 +0300
                      VisuHole: 2024-01-27 16:22:18 +0300
                      "Add help menu!"
                      "create new"
                      (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                    "created"
                    • W
                      @Rich-O-Brien
                      I deleted the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file located in the \SCF Licenses folder. And when I reinstalled the licenses of the two plugins that gave the license error, the problem was solved.
                      Thank you
                        TIG Moderator @wharfedale1976
                        @wharfedale1976
                        Do you have the latest versions downloaded and installed for those Extensions, LibFredo6 and the latest SketchUcation Tools [for the licensing] ?
                        Please post the errors that you got.
                        If it says to delete the Signature file have you done that ??
                        Have you then tried re-validating the licenses etc ?
                          wharfedale1976 said in [Plugin][$] JointPushPull Interactive - v4.4e - 02 Jun 19:
                          @TIG I believe he rectified the issue by deleting the signature as prompted.
                          • fredo6F
                            NEW RELEASE: JointPushPull Interactive v4.8a - 30 Mar 24
                            JointPushPull Interactive 4.8a is a major release including:
                            • adjustments for future compatibility
                            IMPORTANT: JointPushPull 4.8a requires LibFredo6 14.3 or above
                            See plugin home page of JointPushPull for Download of JointPushPull.
                            Main Post of the JointPushPull thread on this forum
                              Dandelliones
                              hellow!!! i have the same problem, i reinstalled the sketchup in my pc and i cant RELEASE SEATS of the jointpushpull too
                              TIGT D Rich O BrienR 3 Replies Last reply
                                TIG Moderator @Dandelliones
                                @Dandelliones
                                Have you installed the latest versions of the SketchUcation toolset [v4.4.0], LibFredo and the Fredo extension itself ?
                                These have been updated for the latest SketchUp version etc...
                                Have you restarted SketchUp afterwards ?
                                Have you then tried managing your licenses yourself with the menu item
                                Extensions/SketchUcation/SCFLicense: My Licenses at SketchUcation...
                                • G
                                  g.petinati @fredo6
                                  @fredo6 Hi Fredo.
                                  I purchased a license of Joint Push Pull Interactive and installed it, but I can't make it work.
                                  I even tried to replicate the videos, but to no avail.
                                  I select the faces via JPP, but when I move the mouse away from the model, to access the toolbar, all faces are unselected. Also, the icon to apply the changes never turns green...
                                  Any idea of what I may be doing wrong?
                                  By the way, all your plugins are awesome.
                                    Dandelliones @Dandelliones
                                    @Dandelliones Yes, i do... but in my licenses managing it does not let me release the seats
                                      @Dandelliones
                                      OK I'll try to get someone else to resolve this...
                                      @Rich-O-Brien
                                        Rich O Brien Moderator @Dandelliones
                                        @Dandelliones Device ID SQ.... which you activated on 01/04/24 must be using an old version of Sketchucation Tools. Please upgrade to newest version
                                        Sketchucation Tools | SketchUcation
                                        (sketchucation.com)
                                        Once you update and restart SketchUp go to Tools > Fredo Collection > JPP > License and click the Seats button.
                                        Then visit https://sketchucation.com/webshop/my-licences.php and the release checkbox will be available
                                        H 1 Reply Last reply
                                          Medness
                                          This post is deleted!
                                            Medness
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 30 / 31
