    1.3k Posts 300 Posters 3.1m Views 298 Watching
    • Gus RG Offline
      Gus R
      @gus r said:
      I can't seem to be able to Loft by Spline between two simple arcs. What could I be doing wrong?
      It suddenly started working again. 😲
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        It works for me in SU2022. Share your .skp file so we can see what you have set up.
        • Gus RG Offline
          Gus R
          Thanks Dave. I don't know what happened. Was working in the past but then this morning it wasn't working. I cleared my temp directory and then it started working right again. Was just between to simple arcs for a brick arch texture set-up. This is what it looked like when it wasn't working. Between Windows and potential plug-in conflicts there's no telling what could have caused it.
          • fredo6F Offline
            Could you upgrade to LibFredo6 v13.6a. It should solve the problem.
            • Gus RG Offline
              Gus R
              I got it up and running again but suddenly it stopped working today. I uninstalled LibFredo and reinstalled it but it still won't work. I tested it with a simple default arc that I offset and it won't work.
              • Gus RG Offline
                Gus R
                This is from the Ruby Console.
                Coord pt ( --2147483648', --2147483648', --2147483648') = nil Error: #<NoMethodError: undefined methodz=' for nil:NilClass>
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1476:in coords_2d' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in block (2 levels) in link_compute_2D_footprint'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in collect' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in block in link_compute_2D_footprint'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in collect' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in link_compute_2D_footprint'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1262:in link_compute_polygons' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1424:in junction_construct'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:334:in activate'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:53:in action__mapping' C:/Users/Z590-E/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in call'`
                • Gus RG Offline
                  Gus R
                  It's just doing it with arcs. Otherwise, Curviloft is still working.
                  • fredo6F Offline
                    It is ost likely related to the zooming. Part of the profile and surface is probably outside of the visible viewport.
                    • Gus RG Offline
                      Gus R
                      It just stopped working again.
                      • N Offline
                        nanni Newcomers
                        i need help about license reply back if you seen.
                        file:///C:/Users/GF63/OneDrive/%E0%B8%A3%E0%B8%B9%E0%B8%9B%E0%B8%A0%E0%B8%B2%E0%B8%9E/%E0%B8%A0%E0%B8%B2%E0%B8%9E%E0%B8%AB%E0%B8%99%E0%B9%89%E0%B8%B2%E0%B8%88%E0%B8%AD/2022-12-30.png
                          Deniscopak
                          hello Sir. Please is it still possible somewhere to download Curviloft that work with Sketchup 2016? thanks 1.9a isnt working for my 2016 with libfredo prioe_su2017
                          thanks
                            This version will work with any version of SketchUp but you'll need the legacy version of LibFredo 6.
                              Rougeee
                              I also have a rather disconcerting and random issue with this plugin on SketchUp Make 2017.
                              This happens most often in the simplest and yet most useful case, that of creating a mesh between 2 contours.
                              Thank you for finding a solution because I obviously have a user license and it is a plugin that I use frequently for the realization of artistic sketches and i really need it !
                              (just in case, windows 10 64 is up to date, as well as the graphics card (nvidia) drivers and of course the latest LibFredo6)
                              Error: #<NoMethodError: undefined methodplates' for nil:NilClass>
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:478:in spline_simple_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:247:in spline_junction_construct'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:334:in activate'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:53:in action__mapping' C:/Users/Alexandre/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in call'
                              C:/Users/Alexandre/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in launch_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:91:in block in startup'
                              Error: #<NoMethodError: undefined method plates' for nil:NilClass> c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:478:in spline_simple_construct'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:247:in spline_junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:617:in notify_edge_picked' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:539:in call'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:539:in notify_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:582:in terminate_current_selection'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:279:in execute_validate' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:269:in execute_from_palette'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:217:in notify_from_palette' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in call'
                              c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in block in init_palette' ...
                              • fredo6F Offline
                                NEW RELEASE: Curviloft v1.9b - 21 Apr 23
                                Curviloft 1.9b is a maintenance release which fixes a potential issue whereby Curviloft will be in error due to previous parameters and would not allow to change the parameters (so ending by blocking Curviloft, as reported in the post just above).
                                See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
                                Main post of this thread
                                  Akavit
                                  The compatibility section needs to be updated. It claims compatibility with Sketchup version 2014 which is not true unless there's some place I haven't found where old versions can be downloaded.
                                    The compatibility section for the main page for Curviloft shows compatibility with SU2014. You need to use the right version of LibFredo6, though.
                                    While on the topic of updating, please update your forum profile.
                                      Magpius
                                      Purchased license, but now getting failed to install
                                      https://imgur.com/a/mCORSK8
                                      Running 2020
                                        Mrkay
                                        Hi, I'm using the paid version of Curviloft. I'm puzzled why sometimes (most of the time) it failed to generate the surfaces? It failed on a simple task like on the offset double arc lines. What is the FOLLOW 40° for. There is PLEASE WAIT... but it doesn't do anything.
                                        Failed loft
                                        Failed loft
                                          Are you using Loft by Spline?
                                          Share an .skp file in which is fails.
                                          • N Offline
                                            ncallen Newcomers
                                            Hi! I recently used Loft By Spline to loft a series of complex curves and it worked beautifully, I came back to the project after a few weeks and am suddenly unable to complete the action. I get the error message "Error in the construction of the Junctions - Try to change the parameters" instead. Has there been an update or something? In the attached file, the image of the object I successfully lofted is next to the one I'm trying to loft. I can upload the actual .skp file if need be.
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 64 / 66
