    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • P
      phoebemaylim
      First time downloading Curviloft and RoundCorner and it says license is expired. Never used the extension before. We suppose to get the trial for 30 days right? Rather no need to mention free trial if there's no intention to give free trial.
        Did you download and install the required Sketchucation Extension Store tool before downloading Curviloft and RoundCorner and then use it to install the extensions?
          DCDP
          Helo Fredo
          Thanks for your amazing tool. It helps me a lot to create special surfaces.
          Sometimes when I use skinning tool, Curviloft seems blocked and does not create the surface. the control panel appears and stays at 0%.
          Do you know why ?
          Thanks for your help.
          • fredo6F
            Do you know why ?
            Difficult to know without the model.
            Also, could you open the Ruby Console before launching Curviloft. There may be some errors displayed.
              DCDP
              @fredo6 said:
              Do you know why ?
              "Points are not planar"
              The same kind of surface was created on the opposite side of my model.
              Here is the Ruby message :
              Error: #<ArgumentError: Points are not planar>
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:123:in add_face' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:123:in geometry_link_flat'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:148:in geometry_link_bz' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:263:in step_geometry'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:37:in block in execute_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:381:in block in launch_execution'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:369:in step_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:418:in start_execution'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:381:in launch_execution' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:37:in execute_geometry'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:736:in execute_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:281:in execute_validate'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:269:in execute_from_palette' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:217:in notify_from_palette'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in call' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in block in init_palette'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4076:in execute_button' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3830:in onLButtonUp'
              /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:503:in onLButtonUp' "
              • E
                Einstein
                Hello,
                I feel like I need some clarification here.
                Am I thinking right that Curviloft 1.8a is the last version that can be used for free without any time limit?
                  TIG's ExtrudeTools extensions are similar to CurviLoft if you want a free alternative.
                  SketchUp Plugins | PluginStore | SketchUcation
                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                  (sketchucation.com)
                    Astrid Findreng
                    I would like to purchase curviloft after free trial expired.
                    But how do I do it.
                    Cannot find any buy option. should the donate button be used instead?
                    Help!
                    Astrid
                      SketchUcation | List of Plugin Licences
                      (sketchucation.com)
                      • P
                        Pat58
                        Hi Fredo6,
                        I have a problem with the currently release of Curviloft and associated products, the tool palette has disappeared I only get part of the toolbar.
                        Please see attached image.
                        I using Sketchup Pro 2022 on a MAC
                        Fredo6 Libfredo6 version 13.6a 29 Nov
                        Curviloft 1.9a
                        I look forward to hearing from you
                        regards
                        • Gus RG
                          Gus R
                          I can't seem to be able to Loft by Spline between two simple arcs. What could I be doing wrong?
                          www.instagram.com/gusrobatto/
                          www.facebook.com/gusrobatto
                          • Gus RG
                            Gus R
                            It suddenly started working again. 😲
                              It works for me in SU2022. Share your .skp file so we can see what you have set up.
                              • Gus RG
                                Gus R
                                Thanks Dave. I don't know what happened. Was working in the past but then this morning it wasn't working. I cleared my temp directory and then it started working right again. Was just between to simple arcs for a brick arch texture set-up. This is what it looked like when it wasn't working. Between Windows and potential plug-in conflicts there's no telling what could have caused it.
                                • fredo6F
                                  Could you upgrade to LibFredo6 v13.6a. It should solve the problem.
                                  • Gus RG
                                    Gus R
                                    I got it up and running again but suddenly it stopped working today. I uninstalled LibFredo and reinstalled it but it still won't work. I tested it with a simple default arc that I offset and it won't work.
                                    • Gus RG
                                      Gus R
                                      This is from the Ruby Console.
                                      Coord pt ( --2147483648', --2147483648', --2147483648') = nil Error: #<NoMethodError: undefined methodz=' for nil:NilClass>
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1476:in coords_2d' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in block (2 levels) in link_compute_2D_footprint'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in collect' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in block in link_compute_2D_footprint'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in collect' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in link_compute_2D_footprint'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1262:in link_compute_polygons' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1424:in junction_construct'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:334:in activate'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
                                      c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:53:in action__mapping' C:/Users/Z590-E/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in call'`
                                      • Gus RG
                                        Gus R
                                        It's just doing it with arcs. Otherwise, Curviloft is still working.
                                        • fredo6F
                                          It is ost likely related to the zooming. Part of the profile and surface is probably outside of the visible viewport.
                                          • Gus RG
                                            Gus R
                                            It just stopped working again.
