    1.3k Posts 300 Posters 3.3m Views 298 Watching
      DCDP
      @fredo6 said:
      @dcdp said:
      Sometimes when I use skinning tool, Curviloft seems blocked and does not create the surface. the control panel appears and stays at 0%.
      Do you know why ?
      Difficult to know without the model.
      Also, could you open the Ruby Console before launching Curviloft. There may be some errors displayed.
      "Points are not planar"
      The same kind of surface was created on the opposite side of my model.
      Here is the Ruby message :
      Error: #<ArgumentError: Points are not planar>
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:123:in add_face' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:123:in geometry_link_flat'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:148:in geometry_link_bz' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:263:in step_geometry'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:37:in block in execute_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:381:in block in launch_execution'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:369:in step_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:418:in start_execution'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:381:in launch_execution' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:37:in execute_geometry'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:736:in execute_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:281:in execute_validate'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:269:in execute_from_palette' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:217:in notify_from_palette'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in call' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in block in init_palette'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4076:in execute_button' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3830:in onLButtonUp'
      /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:503:in onLButtonUp' "
      • E
        Einstein
        Hello,
        I feel like I need some clarification here.
        Am I thinking right that Curviloft 1.8a is the last version that can be used for free without any time limit?
          TIG's ExtrudeTools extensions are similar to CurviLoft if you want a free alternative.
          SketchUp Plugins | PluginStore | SketchUcation
          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
          (sketchucation.com)
            Astrid Findreng
            I would like to purchase curviloft after free trial expired.
            But how do I do it.
            Cannot find any buy option. should the donate button be used instead?
            Help!
            Astrid
              SketchUcation | List of Plugin Licences
              (sketchucation.com)
              • P
                Pat58
                Hi Fredo6,
                I have a problem with the currently release of Curviloft and associated products, the tool palette has disappeared I only get part of the toolbar.
                Please see attached image.
                I using Sketchup Pro 2022 on a MAC
                Fredo6 Libfredo6 version 13.6a 29 Nov
                Curviloft 1.9a
                I look forward to hearing from you
                regards
                • Gus RG
                  Gus R
                  I can't seem to be able to Loft by Spline between two simple arcs. What could I be doing wrong?
                  www.instagram.com/gusrobatto/
                  www.facebook.com/gusrobatto
                  • Gus RG
                    Gus R
                    It suddenly started working again. 😲
                      It works for me in SU2022. Share your .skp file so we can see what you have set up.
                      • Gus RG
                        Gus R
                        Thanks Dave. I don't know what happened. Was working in the past but then this morning it wasn't working. I cleared my temp directory and then it started working right again. Was just between to simple arcs for a brick arch texture set-up. This is what it looked like when it wasn't working. Between Windows and potential plug-in conflicts there's no telling what could have caused it.
                        • fredo6F
                          Could you upgrade to LibFredo6 v13.6a. It should solve the problem.
                          • Gus RG
                            Gus R
                            I got it up and running again but suddenly it stopped working today. I uninstalled LibFredo and reinstalled it but it still won't work. I tested it with a simple default arc that I offset and it won't work.
                            • Gus RG
                              Gus R
                              This is from the Ruby Console.
                              Coord pt ( --2147483648', --2147483648', --2147483648') = nil Error: #<NoMethodError: undefined methodz=' for nil:NilClass>
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1476:in coords_2d' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in block (2 levels) in link_compute_2D_footprint'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in collect' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in block in link_compute_2D_footprint'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in collect' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1322:in link_compute_2D_footprint'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1262:in link_compute_polygons' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1424:in junction_construct'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:334:in activate'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
                              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:53:in action__mapping' C:/Users/Z590-E/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in call'`
                              • Gus RG
                                Gus R
                                It's just doing it with arcs. Otherwise, Curviloft is still working.
                                • fredo6F
                                  It is ost likely related to the zooming. Part of the profile and surface is probably outside of the visible viewport.
                                  • Gus RG
                                    Gus R
                                    It just stopped working again.
                                    • N
                                      nanni Newcomers
                                      i need help about license reply back if you seen.
                                      file:///C:/Users/GF63/OneDrive/%E0%B8%A3%E0%B8%B9%E0%B8%9B%E0%B8%A0%E0%B8%B2%E0%B8%9E/%E0%B8%A0%E0%B8%B2%E0%B8%9E%E0%B8%AB%E0%B8%99%E0%B9%89%E0%B8%B2%E0%B8%88%E0%B8%AD/2022-12-30.png
                                        Deniscopak
                                        hello Sir. Please is it still possible somewhere to download Curviloft that work with Sketchup 2016? thanks 1.9a isnt working for my 2016 with libfredo prioe_su2017
                                        thanks
                                          This version will work with any version of SketchUp but you'll need the legacy version of LibFredo 6.
                                            Rougeee
                                            I also have a rather disconcerting and random issue with this plugin on SketchUp Make 2017.
                                            This happens most often in the simplest and yet most useful case, that of creating a mesh between 2 contours.
                                            Thank you for finding a solution because I obviously have a user license and it is a plugin that I use frequently for the realization of artistic sketches and i really need it !
                                            (just in case, windows 10 64 is up to date, as well as the graphics card (nvidia) drivers and of course the latest LibFredo6)
                                            Error: #<NoMethodError: undefined methodplates' for nil:NilClass>
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:478:in spline_simple_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:247:in spline_junction_construct'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:334:in activate'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:53:in action__mapping' C:/Users/Alexandre/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in call'
                                            C:/Users/Alexandre/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in launch_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:91:in block in startup'
                                            Error: #<NoMethodError: undefined method plates' for nil:NilClass> c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:478:in spline_simple_construct'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:247:in spline_junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:617:in notify_edge_picked' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:539:in call'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:539:in notify_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:582:in terminate_current_selection'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:279:in execute_validate' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:269:in execute_from_palette'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:217:in notify_from_palette' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in call'
                                            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in block in init_palette' ...
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 64 / 66
