    Flowify problems
    extensions
    70 Posts 25 Posters 50.2k Views 25 Watching
      ravindulk94
      @optimaforever said:
      I have a strange behaviour too...
      The flowify command generates a huge model, with an array of sectional faces.
      [attachment=2:17yhee20]<!-- ia2 -->flowify A.JPG<!-- ia2 -->[/attachment:17yhee20]
      First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
      [attachment=1:17yhee20]<!-- ia1 -->flowify B.JPG<!-- ia1 -->[/attachment:17yhee20]
      The resulting groups from the flowify command
      I succeeded all the other meshes with the same method but here I've got a bug...
      [attachment=0:17yhee20]<!-- ia0 -->flowify bug.skp<!-- ia0 -->[/attachment:17yhee20]
      did you find any solution for this error?
        What version of SketchUp are you using? Your profile says 2021 Free/Make which is impossible.
          MrKrabs
          can someone help me out with flowify? I canยดt get it to work properly
          Flowify_problem.skp
          • cottyC
            cotty
            From the instructions...
            Your target surface isn't suitable.
            my SketchUp gallery
              MrKrabs
              is there any way to make it suitable?
              • F
                francesgale
                hello, first time using flowify, any idea what i should do with this error?
                  SMatta79
                  Hello, is there anyone available to help me fix a problem w Floify? I set up the groups correctly 1 main group w the 3 groups inside. when I hit impose grid the grid doesn't appear.
                  Seamless+pattern+--+Cells.skp flowify test.skp
                    I can help you if files are in format skp 6 to 2017 ๐Ÿ˜„
                      SMatta79
                      Hi Pilou, No unfortunately mine is a 2022 version ๐Ÿ˜ž How else can we do this?
                        I suppose that you have choice when you make an exportation...(save as)
                          Meanwhile back in 2022... ๐Ÿ˜›
                          The Error message Flowify is outputting is telling you the problem. Your source and destination should share some level of topological similarities.
                          • N
                            n hong
                            Hi, i'm currently having trouble with Flowify.
                            I'm trying to place wall studs on a curvature wall but this input error keeps popping up.
                            I'll appreciate it if someone could help.
                            INPUT ERROR
                            • tuna1957T
                              tuna1957
                              n hong, Flowify might not be the best tool for what you want to do. Iโ€™m not a Flowify expert but my tests end up distorting the shape of the wall studs. Your might be better off using something like โ€œCopy Along Curveโ€ by Anton S.
                                mingjawaz
                                Can someone help me to solve this flowify problem. Why i cant use the flowify even i have followed the steps of group things
                                ๐Ÿ˜ž
                                Sketchup 2020
                                  The projection plane is either an empty rectangular face or a flat custom made quad grid with the same topology as the target surface.
                                  Your target mesh is not Quad Grid.
                                  https://i.imgur.com/5ohQlT1.png
                                  You've some work to do
                                    meerhumzakhan Newcomers
                                    HELP!!!! I have done following steps and got the error in the end.
                                    1=group
                                    2=group
                                    3=group
                                    1+2+3=group (let's call it "X")
                                    imposed grid=Ok
                                    4=group
                                    4+X=group
                                    ====> flowify====> not enough input error
                                      The source and target need same topology and the support should be aligned as shown above
                                        I lied...
                                        ...you can go like this too
                                        So something in your setup is not right. Could be nesting order or topology...
                                        • panixiaP
                                          panixia
                                          @Rich The text in your example is pure genius ๐Ÿคฃ
                                            I believe it's not 4 + X = group
                                            but 4 + X = Select! ๐Ÿ˜‰
                                            Then call Flowify! ๐Ÿค“
                                            • 3 / 4
