    Flowify problems
    extensions
    70 Posts 25 Posters 48.2k Views 25 Watching
      @ravindulk94 said:
      did you find any solution for this error?
      What version of SketchUp are you using? Your profile says 2021 Free/Make which is impossible.
        MrKrabs
        can someone help me out with flowify? I can´t get it to work properly
        Flowify_problem.skp
        • cottyC
          cotty
          From the instructions...
          Your target surface isn't suitable.
          my SketchUp gallery
            MrKrabs
            is there any way to make it suitable?
            • F
              francesgale
              hello, first time using flowify, any idea what i should do with this error?
                SMatta79
                Hello, is there anyone available to help me fix a problem w Floify? I set up the groups correctly 1 main group w the 3 groups inside. when I hit impose grid the grid doesn't appear.
                Seamless+pattern+--+Cells.skp flowify test.skp
                  I can help you if files are in format skp 6 to 2017 😄
                    SMatta79
                    Hi Pilou, No unfortunately mine is a 2022 version 😞 How else can we do this?
                      I suppose that you have choice when you make an exportation...(save as)
                        Meanwhile back in 2022... 😛
                        The Error message Flowify is outputting is telling you the problem. Your source and destination should share some level of topological similarities.
                        • N
                          n hong
                          Hi, i'm currently having trouble with Flowify.
                          I'm trying to place wall studs on a curvature wall but this input error keeps popping up.
                          I'll appreciate it if someone could help.
                          INPUT ERROR
                          • tuna1957T
                            tuna1957
                            n hong, Flowify might not be the best tool for what you want to do. I’m not a Flowify expert but my tests end up distorting the shape of the wall studs. Your might be better off using something like “Copy Along Curve” by Anton S.
                              mingjawaz
                              Can someone help me to solve this flowify problem. Why i cant use the flowify even i have followed the steps of group things
                              Sketchup 2020
                                The projection plane is either an empty rectangular face or a flat custom made quad grid with the same topology as the target surface.
                                Your target mesh is not Quad Grid.
                                https://i.imgur.com/5ohQlT1.png
                                You've some work to do
                                  meerhumzakhan Newcomers
                                  HELP!!!! I have done following steps and got the error in the end.
                                  1=group
                                  2=group
                                  3=group
                                  1+2+3=group (let's call it "X")
                                  imposed grid=Ok
                                  4=group
                                  4+X=group
                                  ====> flowify====> not enough input error
                                    The source and target need same topology and the support should be aligned as shown above
                                      I lied...
                                      ...you can go like this too
                                      So something in your setup is not right. Could be nesting order or topology...
                                      • panixiaP
                                        panixia
                                        @Rich The text in your example is pure genius 🤣
                                          I believe it's not 4 + X = group
                                          but 4 + X = Select! 😉
                                          Then call Flowify! 🤓
                                            RemsRivera123 Newcomers
                                            Hey everyone!
                                            I’m having some trouble with Flowify and hoping someone can help me out. I’ve set up my groups as follows:
                                            A – The curve
                                            B – The length of the curve
                                            C – The pathway
                                            D – The group I want to flow
                                            But when I select everything and try to apply Flowify, it doesn’t actually "flow"—instead, it just resizes to a much bigger scale. Any idea what might be going wrong?
                                            Thanks in advance! Appreciate any help!
                                            PS. I attached a video showing my problem
                                            SKP Flowify Problem.mp4
                                            • 3 / 4
