    Flowify problems
    extensions
    70 Posts 25 Posters 47.6k Views 25 Watching
    • Y Offline
      yashmishra
      @cotty said:
      You need a quad mesh to be able to map it to the flat surface... but there will more work to do to make it a "nice" solid...
      [attachment=1:1tgwd386]<!-- ia1 -->untitled2.JPG<!-- ia1 -->[/attachment:1tgwd386]
      could you please explain in detail why a quad mesh is required?
      • cottyC Offline
        cotty
        Because it's a requirement in the second sentence of the plugin description?
        "The extension bends geometry along quad surfaces."
        my SketchUp gallery
          You can't project something with Flowify on a complete sphere 3D!
          But yes if you make a little triming somewhere like that!
          You have now a "quad" surface! πŸ˜‰
            paritoshaj
            Idk why its not working but its not working, i have finals tomorrow need to do roof trusses please help
            source geometry must contain raw faces.skp
            • cottyC Offline
              cotty
              After exploding the pyramids in the source geometry group, it's working...
              my SketchUp gallery
                arkiduckling
                hi I have an issue also with flowify, it is not working and I dont know if it is because of my mistakes or plugin's issue because when i checked my extension manager, there's a text in the flowify says UNSIGNED. May I know what does it mean and if that was the reason why i couldnt work with flowify πŸ˜„)) thank you
                • cottyC Offline
                  cotty
                  It's not the reason πŸ˜‰
                  you can upload the model and we will have a look at it...
                  my SketchUp gallery
                    @arkiduckling said:
                    ...there's a text in the flowify says UNSIGNED.
                    Signed or unsigned has no bearing on the functionality of the extension.
                    As Cotty, suggests, share your .skp file so we can see what you are working with and what steps you need to take to sort it out.
                      ravindulk94
                      @optimaforever said:
                      I have a strange behaviour too...
                      The flowify command generates a huge model, with an array of sectional faces.
                      [attachment=2:17yhee20]<!-- ia2 -->flowify A.JPG<!-- ia2 -->[/attachment:17yhee20]
                      First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
                      [attachment=1:17yhee20]<!-- ia1 -->flowify B.JPG<!-- ia1 -->[/attachment:17yhee20]
                      The resulting groups from the flowify command
                      I succeeded all the other meshes with the same method but here I've got a bug...
                      [attachment=0:17yhee20]<!-- ia0 -->flowify bug.skp<!-- ia0 -->[/attachment:17yhee20]
                      did you find any solution for this error?
                        What version of SketchUp are you using? Your profile says 2021 Free/Make which is impossible.
                          MrKrabs
                          can someone help me out with flowify? I canΒ΄t get it to work properly
                          Flowify_problem.skp
                          • cottyC Offline
                            cotty
                            From the instructions...
                            Your target surface isn't suitable.
                            my SketchUp gallery
                              MrKrabs
                              is there any way to make it suitable?
                              • F Offline
                                francesgale
                                hello, first time using flowify, any idea what i should do with this error?
                                  SMatta79
                                  Hello, is there anyone available to help me fix a problem w Floify? I set up the groups correctly 1 main group w the 3 groups inside. when I hit impose grid the grid doesn't appear.
                                  Seamless+pattern+--+Cells.skp flowify test.skp
                                    I can help you if files are in format skp 6 to 2017 πŸ˜„
                                      SMatta79
                                      Hi Pilou, No unfortunately mine is a 2022 version 😞 How else can we do this?
                                        I suppose that you have choice when you make an exportation...(save as)
                                          Meanwhile back in 2022... πŸ˜›
                                          The Error message Flowify is outputting is telling you the problem. Your source and destination should share some level of topological similarities.
                                          • N Offline
                                            n hong
                                            Hi, i'm currently having trouble with Flowify.
                                            I'm trying to place wall studs on a curvature wall but this input error keeps popping up.
                                            I'll appreciate it if someone could help.
                                            INPUT ERROR
                                            • 2 / 4
