    Flowify problems
    extensions
    70 Posts 25 Posters 47.6k Views 25 Watching
      paritoshaj
      Idk why its not working but its not working, i have finals tomorrow need to do roof trusses please help
      source geometry must contain raw faces.skp
      • cottyC Offline
        cotty
        After exploding the pyramids in the source geometry group, it's working...
        my SketchUp gallery
          arkiduckling
          hi I have an issue also with flowify, it is not working and I dont know if it is because of my mistakes or plugin's issue because when i checked my extension manager, there's a text in the flowify says UNSIGNED. May I know what does it mean and if that was the reason why i couldnt work with flowify ๐Ÿ˜„)) thank you
          • cottyC Offline
            cotty
            It's not the reason ๐Ÿ˜‰
            you can upload the model and we will have a look at it...
            my SketchUp gallery
              @arkiduckling said:
              ...there's a text in the flowify says UNSIGNED.
              Signed or unsigned has no bearing on the functionality of the extension.
              As Cotty, suggests, share your .skp file so we can see what you are working with and what steps you need to take to sort it out.
                ravindulk94
                @optimaforever said:
                I have a strange behaviour too...
                The flowify command generates a huge model, with an array of sectional faces.
                [attachment=2:17yhee20]<!-- ia2 -->flowify A.JPG<!-- ia2 -->[/attachment:17yhee20]
                First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
                [attachment=1:17yhee20]<!-- ia1 -->flowify B.JPG<!-- ia1 -->[/attachment:17yhee20]
                The resulting groups from the flowify command
                I succeeded all the other meshes with the same method but here I've got a bug...
                [attachment=0:17yhee20]<!-- ia0 -->flowify bug.skp<!-- ia0 -->[/attachment:17yhee20]
                did you find any solution for this error?
                  What version of SketchUp are you using? Your profile says 2021 Free/Make which is impossible.
                    MrKrabs
                    can someone help me out with flowify? I canยดt get it to work properly
                    Flowify_problem.skp
                    • cottyC Offline
                      cotty
                      From the instructions...
                      Your target surface isn't suitable.
                      my SketchUp gallery
                        MrKrabs
                        is there any way to make it suitable?
                        • F Offline
                          francesgale
                          hello, first time using flowify, any idea what i should do with this error?
                            SMatta79
                            Hello, is there anyone available to help me fix a problem w Floify? I set up the groups correctly 1 main group w the 3 groups inside. when I hit impose grid the grid doesn't appear.
                            Seamless+pattern+--+Cells.skp flowify test.skp
                              I can help you if files are in format skp 6 to 2017 ๐Ÿ˜„
                                SMatta79
                                Hi Pilou, No unfortunately mine is a 2022 version ๐Ÿ˜ž How else can we do this?
                                  I suppose that you have choice when you make an exportation...(save as)
                                    Meanwhile back in 2022... ๐Ÿ˜›
                                    The Error message Flowify is outputting is telling you the problem. Your source and destination should share some level of topological similarities.
                                    • N Offline
                                      n hong
                                      Hi, i'm currently having trouble with Flowify.
                                      I'm trying to place wall studs on a curvature wall but this input error keeps popping up.
                                      I'll appreciate it if someone could help.
                                      INPUT ERROR
                                      • tuna1957T Offline
                                        tuna1957
                                        n hong, Flowify might not be the best tool for what you want to do. Iโ€™m not a Flowify expert but my tests end up distorting the shape of the wall studs. Your might be better off using something like โ€œCopy Along Curveโ€ by Anton S.
                                          mingjawaz
                                          Can someone help me to solve this flowify problem. Why i cant use the flowify even i have followed the steps of group things
                                          ๐Ÿ˜ž
                                          Sketchup 2020
                                            The projection plane is either an empty rectangular face or a flat custom made quad grid with the same topology as the target surface.
                                            Your target mesh is not Quad Grid.
                                            https://i.imgur.com/5ohQlT1.png
                                            You've some work to do
                                            • 3 / 4
