    Flowify problems
    extensions
    70 Posts 25 Posters 47.6k Views 25 Watching
      MrKrabs
      can someone help me out with flowify? I can´t get it to work properly
      Flowify_problem.skp
      • cottyC Offline
        cotty
        From the instructions...
        Your target surface isn't suitable.
        my SketchUp gallery
          MrKrabs
          is there any way to make it suitable?
          • F Offline
            francesgale
            hello, first time using flowify, any idea what i should do with this error?
              SMatta79
              Hello, is there anyone available to help me fix a problem w Floify? I set up the groups correctly 1 main group w the 3 groups inside. when I hit impose grid the grid doesn't appear.
              Seamless+pattern+--+Cells.skp flowify test.skp
                I can help you if files are in format skp 6 to 2017 😄
                  SMatta79
                  Hi Pilou, No unfortunately mine is a 2022 version 😞 How else can we do this?
                    I suppose that you have choice when you make an exportation...(save as)
                      Meanwhile back in 2022... 😛
                      The Error message Flowify is outputting is telling you the problem. Your source and destination should share some level of topological similarities.
                      • N Offline
                        n hong
                        Hi, i'm currently having trouble with Flowify.
                        I'm trying to place wall studs on a curvature wall but this input error keeps popping up.
                        I'll appreciate it if someone could help.
                        INPUT ERROR
                        • tuna1957T Offline
                          tuna1957
                          n hong, Flowify might not be the best tool for what you want to do. I’m not a Flowify expert but my tests end up distorting the shape of the wall studs. Your might be better off using something like “Copy Along Curve” by Anton S.
                            mingjawaz
                            Can someone help me to solve this flowify problem. Why i cant use the flowify even i have followed the steps of group things
                            Sketchup 2020
                              The projection plane is either an empty rectangular face or a flat custom made quad grid with the same topology as the target surface.
                              Your target mesh is not Quad Grid.
                              https://i.imgur.com/5ohQlT1.png
                              You've some work to do
                                meerhumzakhan Newcomers
                                HELP!!!! I have done following steps and got the error in the end.
                                1=group
                                2=group
                                3=group
                                1+2+3=group (let's call it "X")
                                imposed grid=Ok
                                4=group
                                4+X=group
                                ====> flowify====> not enough input error
                                  The source and target need same topology and the support should be aligned as shown above
                                    I lied...
                                    ...you can go like this too
                                    So something in your setup is not right. Could be nesting order or topology...
                                    • panixiaP Offline
                                      panixia
                                      @Rich The text in your example is pure genius 🤣
                                        I believe it's not 4 + X = group
                                        but 4 + X = Select! 😉
                                        Then call Flowify! 🤓
                                          RemsRivera123 Newcomers
                                          Hey everyone!
                                          I’m having some trouble with Flowify and hoping someone can help me out. I’ve set up my groups as follows:
                                          A – The curve
                                          B – The length of the curve
                                          C – The pathway
                                          D – The group I want to flow
                                          But when I select everything and try to apply Flowify, it doesn’t actually "flow"—instead, it just resizes to a much bigger scale. Any idea what might be going wrong?
                                          Thanks in advance! Appreciate any help!
                                          PS. I attached a video showing my problem
                                          SKP Flowify Problem.mp4
                                            Can you share a file? @RemsRivera123
                                            It’s quicker solve if there’s something to see
                                            R 1 Reply Last reply Reply Quote 0
                                            • 3 / 4
