    Ferrari F2004
    50 Posts 21 Posters 22.9k Views 21 Watching
    • boofredlayB
      boofredlay
      https://i.pinimg.com/564x/b1/13/6c/b1136c912e6cfa93b3e1463db47bb508.jpg
      • Bryan KB
        One of the greatest cars in history.
        And this has to be one of the finest 3D models I've ever seen and a fitting tribute. Wow! 👍
        • ntxdaveN
          ntxdave
          DITTO!
          Press F1...thank me later
            @panixia said:
            For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
            Can you expand on this?
            • O
              optimaforever
              Amazing work ! I admit that the quadface tools+vertextools+subD workflow
              is something that I sometimes miss in Fusion360, as it allows some complex
              sculpting with ease, and this f2004 is a wonderful demonstration !!!
              How can you retrieve the second tile you made in wrapR?
              can it save several tiles for one mesh? or you need an workaround?
              UDIM workflow is possible in substance painter but I never thought of
              doing that with a sketchup-generated mesh.
              This is new for me, you’re a genius !
              • panixiaP
                panixia
                Adesso arriva. 😉
                • panixiaP
                  panixia
                  Here we go.. My best attempt to explain it.
                  The basic concept is that you export from a single-material model and then reload in another model with two separate materials. 👍
                  • panixiaP
                    panixia
                    No, it's not, but you select the faces for the second tile, create a new unique material for them and assign to it the textures from uv tile 2.
                    That simply works because sketchup teoretically has actually both uv sets repeating overlapped (exactly like the psycoTemplate texture in the vid), but because you assigned each texture to the proper material/faces, you are sort of trolling the system, so it works.
                    The difference with "official" UDIM workflow is that you are not able to manage this with a single material based on the texture set's naming convention only, but you have instead to manualy re-create (and reassign on the mesh) individual materials for each texture set.
                    • panixiaP
                      panixia
                      Some Wrap-R views. For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
                      I also added some minor props in the empty spaces left in the body double-unwrap
                      (used the same trick to add minor props to other single-tile texture sets).
                      I've also found a neat trick to unwrap flat strips of poligons in Wrap-r with a little aid of Thrupaint.
                      Look at the tire tread and rim 😎
                      • tuna1957T
                        tuna1957
                        Wow !! Simply superb job. 👍 👍 Will argue the point of “greatest” F1 car though…. The Jim Clark Lotus 25 has my vote. 😉
                        • alvisA
                          alvis
                          It's unbelievable! How is that possible?
                          • danielrepleD
                            danielreple
                            Amazing work!!!
                            A few days ago I was wondering if it was possible to use SketchUp + Substance Painter.
                            What format do you export in SketchUp to open in Substance? obj?
                            When opening in Substance, is the mapping automatically recognized without problems?
                            https://sketchupbrasil.com/
                            • danielrepleD
                              danielreple
                              I found a tutorial:
                              panixia, is that how you do it?
                                • panixiaP
                                  panixia
                                  @danielreple said:
                                  I found a tutorial:
                                  Sorry for responding so late, but I was on vacation for a couple of days.. ☀
                                  Yes, I used a similar tecnique.
                                  The main difference is that I use the obj exporter from Quadface Tools which preserves quads (you can see the quads in the Substance wireframe).
                                  And yes, if you have good UV's Substance will respect them.
                                  You also have an option for auto-unwrap in Substance, but obviously if you are able to unwrap manually you have a lot more optimization in terms of texel density/wasted space.
                                  Here's a tutorial I put togheter a year ago.
                                  It's a bit outdated because now I use another faster trick to straigtehen flat strips of polygons when needed. But the basic workflow is there.
                                  For this model I used pretty much the same technique, the only difference is that the Ferrari has a lot more elements, texture sets and details.
                                  • panixiaP
                                    panixia
                                    Well, I'm italian so.. you know.. Ferrari is religion, and the f2004 is the holy grail for us.. 💚
                                    But that classic Lotus was a beast of a car indeed.
                                    In my opinion, both of them are waaaaaaay better than theese bad looking, bad sounding, soul-less cars that we have nowadays. 😕
                                    • duanekempD
                                      duanekemp
                                      Absolutely inspirational and as professional as can be. BRAVO!!!
                                      Duane Kemp
                                      Kemp Productions
                                      Puidoux, Switzerland
                                      Gallery:
                                      https://duanekemp.artstation.com/
                                      • panixiaP
                                        panixia
                                        I posted some still renders at this link..
                                        Facebook
                                        (www.facebook.com)
                                        panixiaP 1 Reply Last reply
                                        • pbacotP
                                          amazing and beautiful. Thanks for sharing the process! Some things I may never do, but wish I understood the general approach better.
                                          • duanekempD
                                            duanekemp
                                            This is such a magnificent, well executed, beautiful work of discipline, passion, experience and a great use of tools. And what you are sharing in public today?! OUTSTANDING!
                                            Congratulations!!! Well done Marcello!
                                            Duane Kemp
                                            Kemp Productions
                                            Gallery:
                                            • 2 / 3
