Ferrari F2004
@panixia said:
For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
Can you expand on this?
Amazing work ! I admit that the quadface tools+vertextools+subD workflow
is something that I sometimes miss in Fusion360, as it allows some complex
sculpting with ease, and this f2004 is a wonderful demonstration !!!How can you retrieve the second tile you made in wrapR?
can it save several tiles for one mesh? or you need an workaround?
UDIM workflow is possible in substance painter but I never thought of
doing that with a sketchup-generated mesh.
This is new for me, youโre a genius ! -
Here we go.. My best attempt to explain it.
The basic concept is that you export from a single-material model and then reload in another model with two separate materials.
No, it's not, but you select the faces for the second tile, create a new unique material for them and assign to it the textures from uv tile 2.
That simply works because sketchup teoretically has actually both uv sets repeating overlapped (exactly like the psycoTemplate texture in the vid), but because you assigned each texture to the proper material/faces, you are sort of trolling the system, so it works.
The difference with "official" UDIM workflow is that you are not able to manage this with a single material based on the texture set's naming convention only, but you have instead to manualy re-create (and reassign on the mesh) individual materials for each texture set.
Some Wrap-R views. For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
I also added some minor props in the empty spaces left in the body double-unwrap
(used the same trick to add minor props to other single-tile texture sets).I've also found a neat trick to unwrap flat strips of poligons in Wrap-r with a little aid of Thrupaint.
Look at the tire tread and rim
Wow !! Simply superb job.
Will argue the point of โgreatestโ F1 car thoughโฆ. The Jim Clark Lotus 25 has my vote.
It's unbelievable! How is that possible?
Amazing work!!!
A few days ago I was wondering if it was possible to use SketchUp + Substance Painter.
What format do you export in SketchUp to open in Substance? obj?
When opening in Substance, is the mapping automatically recognized without problems? -
I found a tutorial:
panixia, is that how you do it?
@danielreple said:
I found a tutorial:
Sorry for responding so late, but I was on vacation for a couple of days..
Yes, I used a similar tecnique.
The main difference is that I use the obj exporter from Quadface Tools which preserves quads (you can see the quads in the Substance wireframe).
And yes, if you have good UV's Substance will respect them.
You also have an option for auto-unwrap in Substance, but obviously if you are able to unwrap manually you have a lot more optimization in terms of texel density/wasted space.
Here's a tutorial I put togheter a year ago.
It's a bit outdated because now I use another faster trick to straigtehen flat strips of polygons when needed. But the basic workflow is there.
For this model I used pretty much the same technique, the only difference is that the Ferrari has a lot more elements, texture sets and details. -
Well, I'm italian so.. you know.. Ferrari is religion, and the f2004 is the holy grail for us..
But that classic Lotus was a beast of a car indeed.
In my opinion, both of them are waaaaaaay better than theese bad looking, bad sounding, soul-less cars that we have nowadays.
Absolutely inspirational and as professional as can be. BRAVO!!!
I posted some still renders at this link..
amazing and beautiful. Thanks for sharing the process! Some things I may never do, but wish I understood the general approach better.
This is such a magnificent, well executed, beautiful work of discipline, passion, experience and a great use of tools. And what you are sharing in public today?! OUTSTANDING!
Congratulations!!! Well done Marcello!
Thank you for sharing this process and your phenomenal results! I am in awe at the beautiful model you have created. Bravo!
could you sell the model please?
No.
A fashion designer Instagrammed his shoes on top of his Ferrari, and Ferrari is threatening to sue
Ferrari reportedly sent a letter to fashion designer Philipp Plein threatening to sue him over Instagram posts that depicted his brand of shoes on top of his personal Ferraris.
The Verge (www.theverge.com)
With your input, this post could be even better ๐
