    Ferrari F2004
    50 Posts 21 Posters 20.1k Views 21 Watching
    • O Offline
      optimaforever
      Amazing work ! I admit that the quadface tools+vertextools+subD workflow
      is something that I sometimes miss in Fusion360, as it allows some complex
      sculpting with ease, and this f2004 is a wonderful demonstration !!!
      How can you retrieve the second tile you made in wrapR?
      can it save several tiles for one mesh? or you need an workaround?
      UDIM workflow is possible in substance painter but I never thought of
      doing that with a sketchup-generated mesh.
      This is new for me, youโ€™re a genius !
      • panixiaP Offline
        panixia
        @rich o brien said:
        @panixia said:
        For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
        Can you expand on this?
        Adesso arriva. ๐Ÿ˜‰
        • panixiaP Offline
          panixia
          Here we go.. My best attempt to explain it.
          The basic concept is that you export from a single-material model and then reload in another model with two separate materials. ๐Ÿ‘
          • panixiaP Offline
            panixia
            No, it's not, but you select the faces for the second tile, create a new unique material for them and assign to it the textures from uv tile 2.
            That simply works because sketchup teoretically has actually both uv sets repeating overlapped (exactly like the psycoTemplate texture in the vid), but because you assigned each texture to the proper material/faces, you are sort of trolling the system, so it works.
            The difference with "official" UDIM workflow is that you are not able to manage this with a single material based on the texture set's naming convention only, but you have instead to manualy re-create (and reassign on the mesh) individual materials for each texture set.
            • panixiaP Offline
              panixia
              Some Wrap-R views. For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
              I also added some minor props in the empty spaces left in the body double-unwrap
              (used the same trick to add minor props to other single-tile texture sets).
              I've also found a neat trick to unwrap flat strips of poligons in Wrap-r with a little aid of Thrupaint.
              Look at the tire tread and rim ๐Ÿ˜Ž
              • tuna1957T Offline
                tuna1957
                Wow !! Simply superb job. ๐Ÿ‘ ๐Ÿ‘ Will argue the point of โ€œgreatestโ€ F1 car thoughโ€ฆ. The Jim Clark Lotus 25 has my vote. ๐Ÿ˜‰
                • alvisA Offline
                  alvis
                  It's unbelievable! How is that possible?
                  • danielrepleD Offline
                    danielreple
                    Amazing work!!!
                    A few days ago I was wondering if it was possible to use SketchUp + Substance Painter.
                    What format do you export in SketchUp to open in Substance? obj?
                    When opening in Substance, is the mapping automatically recognized without problems?
                    https://sketchupbrasil.com/
                      danielreple
                      I found a tutorial:
                      panixia, is that how you do it?
                        ๐Ÿ‘Š
                        • panixiaP Offline
                          panixia
                          @danielreple said:
                          I found a tutorial:
                          Sorry for responding so late, but I was on vacation for a couple of days.. โ˜€
                          Yes, I used a similar tecnique.
                          The main difference is that I use the obj exporter from Quadface Tools which preserves quads (you can see the quads in the Substance wireframe).
                          And yes, if you have good UV's Substance will respect them.
                          You also have an option for auto-unwrap in Substance, but obviously if you are able to unwrap manually you have a lot more optimization in terms of texel density/wasted space.
                          Here's a tutorial I put togheter a year ago.
                          It's a bit outdated because now I use another faster trick to straigtehen flat strips of polygons when needed. But the basic workflow is there.
                          For this model I used pretty much the same technique, the only difference is that the Ferrari has a lot more elements, texture sets and details.
                          • panixiaP Offline
                            panixia
                            Well, I'm italian so.. you know.. Ferrari is religion, and the f2004 is the holy grail for us.. ๐Ÿ’š
                            But that classic Lotus was a beast of a car indeed.
                            In my opinion, both of them are waaaaaaay better than theese bad looking, bad sounding, soul-less cars that we have nowadays. ๐Ÿ˜•
                            • duanekempD Offline
                              duanekemp
                              Absolutely inspirational and as professional as can be. BRAVO!!!
                              Duane Kemp
                              Kemp Productions
                              Puidoux, Switzerland
                              Gallery:
                              https://duanekemp.artstation.com/
                              • panixiaP Offline
                                panixia
                                I posted some still renders at this link..
                                https://www.facebook.com/sautparktrails/posts/4291186340928420?notif_id=1631717260751626&notif_t=feedback_reaction_generic&ref=notif
                                panixiaP 1 Reply Last reply Reply Quote 0
                                • pbacotP Offline
                                  amazing and beautiful. Thanks for sharing the process! Some things I may never do, but wish I understood the general approach better.
                                    duanekemp
                                    This is such a magnificent, well executed, beautiful work of discipline, passion, experience and a great use of tools. And what you are sharing in public today?! OUTSTANDING!
                                    Congratulations!!! Well done Marcello!
                                    Duane Kemp
                                    Kemp Productions
                                    Gallery:
                                    • andybotA Offline
                                      andybot
                                      Thank you for sharing this process and your phenomenal results! I am in awe at the beautiful model you have created. Bravo!
                                      • E Offline
                                        ericksl1991
                                        could you sell the model please?
                                        • panixiaP Offline
                                          panixia
                                          No. ๐Ÿคฃ
                                          https://www.theverge.com/2019/8/2/20752067/instagram-ferrari-philipp-plein-lawsuit-threat
                                          https://www.solidsmack.com/cad-design-news/bmw-group-sues-turbosquid-for-selling-3d-models-of-their-car-designs/
                                          • panixiaP Offline
                                            panixia
                                            Thanx ๐Ÿ˜„
                                            • 2 / 3
