    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • HornOxxH Offline
      HornOxx
      @box said:
      Next you'll start twisting them...and put your faith in a higher power...
      πŸ˜† πŸ˜† wunderbar !!
      never trust a skinny cook
      • tuna1957T Offline
        tuna1957
        Thanks Box , HornOxx.
        HornOxx, you asked about triangles..... After I exploded the twelve pieces I erased and redrew the flat bottom inside and out so they were all quads. The pairs of triangles at the top just bellow the rim I could eliminate by " soft, smooth, no cast shadows" but I lost to much definition of the crease that way. Leaving them as triangles kept a better look to the vertical grooves. It seems you can cheat on the quads a little sometimes and still get a nice result.
        • HornOxxH Offline
          HornOxx
          thanks for these Infos - yes, you are geting a better shape so πŸ‘
          This Green-Blue look is this quadface tools live mesh analysis feature - I always forget about this good feature πŸ˜‰
          • tuna1957T Offline
            tuna1957
            HornOxx, your correct the green, purple colors are from Quadface tools analyze function. I forget about it myself sometimes πŸ˜† .
              @optimaforever said:
              @thomthom said:
              Btw, do you have some quad that are not fully QuadFace quads? I see some unexpected uneven edges in the back there:
              [attachment=0:gkjocs9z]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:gkjocs9z]
              This is the same strange behaviour I got last year with some meshes. Dunno why, but it seems that some vertices react as a 1.0 crease when subdivided although they are 0 when checked with the crease tool.
              I usually delete the problematic edges and redraw the geometry from scratch when that happens.
              If you send me one of these models I can have a look into what is going on.
              • tuna1957T Offline
                tuna1957
                Some more of my weird Vertex tools and SubD stuff. Twisted up the piece on the left, did some copy - array business. Add a few more bits and pieces and I ended up with a hanging lamp. SubD on the twisty bits and bottom trim ring the rest native SU.....
                  Not by me! πŸ˜‰
                  • BoxB Offline
                    A couple of sinks I knocked up as an example.
                    Simple
                    https://i.imgur.com/cVYgeHu.gif
                    Somewhat more complex
                    https://i.imgur.com/vgEyLkv.gif
                      No thickness ? πŸ˜‰
                      • HornOxxH Offline
                        HornOxx
                        @pilou said:
                        No thickness ? πŸ˜‰
                        πŸ˜„ πŸ˜„ I think thickness doesn't make sense where it's not to be seen. but did you notice that Box even models the water overflow correctly? 😲 πŸ˜„ πŸ‘
                          Yes of course, it was for find a little default on these voluptuous design beauties! πŸ˜‰
                          The cool thing about Subdivision modeling it's that is always a surprise before the final object! β˜€
                          • HornOxxH Offline
                            HornOxx
                            Yes, each time 😎
                            • McGyverM Offline
                              McGyver
                              In the video pilou posted, does anyone know what plugin the person is using that has an icon which looks like sword?
                              https://www.daz3d.com/forums/uploads/FileUpload/b6/4800459b5aa5f69873cb7086cc0730.jpeg
                              Sorry about the crappy screen capture... and thanks for any info.
                              Visit My ShareCG Freebie Gallery
                              • HornOxxH Offline
                                HornOxx
                                Hi - it could Artisan Subdivide and Smooth (but I'm not sure, however)
                                  dedmin
                                  Zorro2 - https://www.youtube.com/watch?v=Z7uAMfs4T8s
                                  • McGyverM Offline
                                    McGyver
                                    Thank you both!
                                    It was Zorro 2... I did not know that was what that tool did... too bad, I could have used that a bunch of times.
                                    Thanks again.
                                    • tuna1957T Offline
                                      tuna1957
                                      Been fooling about off and on trying to come up with a reasonably decent "human" type figure. Getting close. Still trying to figure out the best approach for head and hands. Started with blocking in half of the monster and then copied and flipped to get both sides. Progress ! πŸ˜†
                                        Not by me! πŸ˜‰
                                        • alsomarA Offline
                                          alsomar Extension Creator
                                          Hi everyone! Here's a recent exercise I made with SketchUp 2019, SUbD, VertexTools and QuadFace Tools. It's the head of a corinthian column. I used Thea for SketchUp v2 for the rendered pic.
                                          Alejandro Soriano Visuals Β· All my links
                                          • HornOxxH Offline
                                            HornOxx
                                            U-Boot Typ VII
                                            Hi, just a little sunday afternoon exercise again, entirely modeled with SubD and all of itΒ΄s associated quad tools. (the idea was to play a little bit with the shape of the old German submarine "Type VII" / rendered in Enscape)
                                            https://3dwarehouse.sketchup.com/model/4ee76836-331b-49cd-88bd-c44e10b389e3/U-Boot-Type-VII-NEO
                                            (edit 09-14-2019: added an AO-render, rendered with Shaderlight, combined with a SU line overlay)
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 82
                                            • 83
                                            • 76 / 83
