    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • tuna1957T
      tuna1957
      @hornoxx said:
      πŸ™‚ love this "messing" πŸ‘
      (btw "Messing" in German is the metal alloy brass πŸ˜„ πŸ˜„)
      Thanks HornOxx. Curious would "fooling about" translate better πŸ˜‰
      • O
        optimaforever
        @thomthom said:
        Btw, do you have some quad that are not fully QuadFace quads? I see some unexpected uneven edges in the back there:
        [attachment=0:1mfg7n1x]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:1mfg7n1x]
        This is the same strange behaviour I got last year with some meshes. Dunno why, but it seems that some vertices react as a 1.0 crease when subdivided although they are 0 when checked with the crease tool.
        I usually delete the problematic edges and redraw the geometry from scratch when that happens.
        • tuna1957T
          tuna1957
          More late night fooling about / practice. Seem obsessed with what I can make out of copies of one piece. Made the piece on the left, copy _ array twelve times. Exploded and regrouped. Cleaned up the internal bits with Solid Inspector. Decided to flare the top a little more, as always Vertex tools makes it easy. There you have another crazy vase.
          • HornOxxH
            HornOxx
            @tuna1957 said:
            ...Seem obsessed with what I can make out of copies of one piece...
            πŸ˜† πŸ˜† be careful - there is such a high addiction factor πŸ˜† again a so nice (not fooling!) practice πŸ‘ !
            (in the throat(?) above you end up with a triangle - I still do not really understand correctly whether triangles are no longer an obstacle in this kind of workflow, which they were at the beginning of SubD)
            never trust a skinny cook
            • BoxB
              Next you'll start twisting them, then all is lost.
              You'll have to start on the twelve steps and put your faith in a higher power...
              • HornOxxH
                HornOxx
                @box said:
                Next you'll start twisting them...and put your faith in a higher power...
                πŸ˜† πŸ˜† wunderbar !!
                • tuna1957T
                  tuna1957
                  Thanks Box , HornOxx.
                  HornOxx, you asked about triangles..... After I exploded the twelve pieces I erased and redrew the flat bottom inside and out so they were all quads. The pairs of triangles at the top just bellow the rim I could eliminate by " soft, smooth, no cast shadows" but I lost to much definition of the crease that way. Leaving them as triangles kept a better look to the vertical grooves. It seems you can cheat on the quads a little sometimes and still get a nice result.
                  • HornOxxH
                    HornOxx
                    thanks for these Infos - yes, you are geting a better shape so πŸ‘
                    This Green-Blue look is this quadface tools live mesh analysis feature - I always forget about this good feature πŸ˜‰
                    • tuna1957T
                      tuna1957
                      HornOxx, your correct the green, purple colors are from Quadface tools analyze function. I forget about it myself sometimes πŸ˜† .
                        @optimaforever said:
                        [attachment=0:gkjocs9z]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:gkjocs9z]
                        If you send me one of these models I can have a look into what is going on.
                        • tuna1957T
                          tuna1957
                          Some more of my weird Vertex tools and SubD stuff. Twisted up the piece on the left, did some copy - array business. Add a few more bits and pieces and I ended up with a hanging lamp. SubD on the twisty bits and bottom trim ring the rest native SU.....
                            Not by me! πŸ˜‰
                            • BoxB
                              A couple of sinks I knocked up as an example.
                              Simple
                              https://i.imgur.com/cVYgeHu.gif
                              Somewhat more complex
                              https://i.imgur.com/vgEyLkv.gif
                                No thickness ? πŸ˜‰
                                • HornOxxH
                                  HornOxx
                                  @pilou said:
                                  No thickness ? πŸ˜‰
                                  πŸ˜„ πŸ˜„ I think thickness doesn't make sense where it's not to be seen. but did you notice that Box even models the water overflow correctly? 😲 πŸ˜„ πŸ‘
                                    Yes of course, it was for find a little default on these voluptuous design beauties! πŸ˜‰
                                    The cool thing about Subdivision modeling it's that is always a surprise before the final object! β˜€
                                    • HornOxxH
                                      HornOxx
                                      Yes, each time 😎
                                      • McGyverM
                                        McGyver
                                        In the video pilou posted, does anyone know what plugin the person is using that has an icon which looks like sword?
                                        https://www.daz3d.com/forums/uploads/FileUpload/b6/4800459b5aa5f69873cb7086cc0730.jpeg
                                        Sorry about the crappy screen capture... and thanks for any info.
                                        Visit My ShareCG Freebie Gallery
                                        • HornOxxH
                                          HornOxx
                                          Hi - it could Artisan Subdivide and Smooth (but I'm not sure, however)
                                            dedmin
                                            Zorro2 - https://www.youtube.com/watch?v=Z7uAMfs4T8s
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 83
                                            • 84
                                            • 65 / 84
