    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • fredo6F
      @rv1974 said:
      Tested right now. Works perfectly, many many thanks!
      Or take v4.4d...
      I made it work even if you perform several push pull operations within the same JPP session.
      • fredo6F
        NEW RELEASE: JointPushPull Interactive v4.4d - 20 Feb 19
        JointPushPull Interactive 4.4d select the offset faces of pre-selected faces at exit. See post just above.
        JointPushPull 4.4b requires LibFredo6 8.7m or above
        See plugin home page of JointPushPull for Download of JointPushPull.
        Main Post of the JointPushPull thread on this forum
          rv1974
          Fredo, when FollowPushPull is used on chamfer face, is there way to get somehow an exact 'chamfer 0' state?
            SpookyChick1013
            Massively useful plugins as always Fredo. Had the following error found when attempting round pushpull. Here's the log dump.
            Thanks in advance!
            Date: 19-Mar-19 09:41:55
            An error occurred in Round Push Pull
            Error in generation of the geometry
            undefined method `collect' for nil:NilClass
            jointpushpull4geometry.rbe: 1450 -- geometry_rounding_mesh
            jointpushpull4geometry.rbe: 1283 -- block in geometry_create_roundings
            jointpushpull4geometry.rbe: 1282 -- each
            jointpushpull4geometry.rbe: 1282 -- geometry_create_roundings
            jointpushpull4geometry.rbe: 267 -- geometry_robot_prepare_mesh
            jointpushpull4geometry.rbe: 211 -- robot_call_action
            jointpushpull4geometry.rbe: 182 -- geometry_robot_exec
            jointpushpull4geometry.rbe: 165 -- geometry_robot
            jointpushpull4geometry.rbe: 80 -- block in geometry_execute
            lib6operation.rbe: 365 -- call
            lib6operation.rbe: 365 -- step_geometry
            lib6operation.rbe: 413 -- start_execution
            jointpushpull4geometry.rbe: 80 -- geometry_execute
            jointpushpull4tool.rbe: 1034 -- go_preview_or_geom
            jointpushpull4tool.rbe: 812 -- dragging_stop
            https://kuromatsudriveyards.com
            Fo-su to tomo ni aran koto o...
            • fredo6F
              You don't seem to have the latest version of JPP (it should be v4.4d).
              Could you update it and advise. Thanks.
                SpookyChick1013
                What? Wooops! You're right. I try to keep things updated, but somehow that one slipped past me.
                I'll let you know once I've had a chance to test things. Thanks Fredo!
                Update"Installed teh new version, made sure everything was updated, no conflicting versions, and presto, the same error.
                %(#40BFFF)[Date: 22-Mar-19 11:54:25
                jointpushpullgeometry.rbe: 1529 -- geometry_rounding_mesh
                jointpushpullgeometry.rbe: 1362 -- block in geometry_create_roundings
                jointpushpullgeometry.rbe: 1361 -- each
                jointpushpullgeometry.rbe: 1361 -- geometry_create_roundings
                jointpushpullgeometry.rbe: 269 -- geometry_robot_prepare_mesh
                jointpushpullgeometry.rbe: 212 -- robot_call_action
                jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                jointpushpullgeometry.rbe: 166 -- geometry_robot
                jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                jointpushpullgeometry.rbe: 81 -- geometry_execute
                jointpushpulltool.rbe: 1119 -- go_preview_or_geom
                jointpushpulltool.rbe: 845 -- dragging_stop]
                It happens whether I use the VCB or not. What I'm trying to do is Round PushPull the faces highlighted in the enclosed sreeen snip
                If you need the model, let me know where to send it and I will do so.
                Cathryn
                • H
                  HeyJujube
                  J'ai de gros problèmes avec ce plugin (mode vecteur) sous SketchUp Pro 2019 (Mac 10.14). Problème connu ?
                  Merci
                  • fredo6F
                    Merci
                    Difficile de juger sans le modele. Et, franchement, l'image ne me permet de savoir de quoi il s'agit.
                    • H
                      HeyJujube
                      N'importe quel modèle, ici une simple colonne inclinée pour l'exemple.
                      La face part dans tous les sens, se déforme, "explose".
                      J'ai toujours utilisé le plugin, mais récemment passage à SU 2019 sous Mac.
                      Merci
                      • fredo6F
                        Merci
                        it looks like the Vector direction is on the plane of the face.
                        Could you either lock an axis direction with the arrows, or find a proper direction and lock it (Shift).
                        • T
                          theVonZipper
                          Thanks Fredo for the fantastic plugins. I use 'Divide faces' often and of course Joint Push Pull. Just wondering, is there a way for Push Pull Interactive to inherit layers from the faces they are affecting as the Classic version did?
                            Faces and edges should always be created on and remain on Layer 0. See Controlling Visibility with Layers.
                            • E
                              Einstein
                              Hi!
                              I have an idea for a small feature upgrade.
                              Actually, two ideas ^^
                              1. Possibility to apply positive + negative offset in one go, so you can thicken a surface on both sides immediately
                              2. Extrude faces to point, like in Rhino. It would be almost analogic operation to scaling about a point which can be performed via ThomThom's Rotate and Scale. However, you'd then have to manually connect border edges of source and result meshes. Rhino has a tool which does everything in one step. I attach an illustration for it.
                              What do you think about it?
                              • fredo6F
                                This is doable, though not trivial, because I have two generate two faces for each original face. It would also require an additional option, maybe triggered by a modifier; the only left is ALT (on Windows)
                                @einstein said:
                                1. Extrude faces to point, like in Rhino. It would be almost analogic operation to scaling about a point which can be performed via ThomThom's Rotate and Scale. However, you'd then have to manually connect border edges of source and result meshes. Rhino has a tool which does everything in one step. I attach an illustration for it.
                                This would be a new tool actually. I need to think about it, but a priori an interesting idea.
                                • E
                                  Einstein
                                  Could you please increase extreme angle values for Molding in the next release? Now it's +- 60, which is a serious limitation in some cases. I'd suggest 89 or even 90 - this would practically create a flat offset (nice!). Certainly, faces would overlap but that could be fixed manually.
                                  • fredo6F
                                    If the angle is too large, then you are almost sure to get overlaps and mess up the extrusion.
                                    Here is what I get with the set of letters, each one of width roughly 0.5 m. I had to reduce the offset of extrusion to 0.001 m (that is, 1mm) to get a molding at 85 deg. without overlap.
                                    With an offset of 1cm, the extrusion gets seriously messy
                                    I can increase it to 89 degrees. At 90, you reach math limit, since there is NO extrusion, and JPP does not like it. So, I'll probably pick 85 degrees, to make it a multiple of the 5 deg increment in a next release.
                                    • E
                                      Einstein
                                      Thank you 😄
                                      • fredo6F
                                        NEW RELEASE: JointPushPull Interactive v4.4e - 02 Jun 19
                                        JointPushPull Interactive 4.4e is a minor release including an increase of the maximum angle for Molding (now 85 degrees).
                                        JointPushPull 4.4e requires LibFredo6 8.7m or above
                                        • E
                                          Einstein
                                          Thank you, for me it's a major release 😄
                                            jonnys777
                                            Morning all,
                                            I'm getting the follow error trying to thicken some terrain on the z-axis;
                                            Date: 20-Jun-19 08:06:15
                                            An error occurred in Vector Push Pull
                                            Could not compute valid matrix from points
                                            body_lib6g6.rbe: 4568 -- position_material
                                            body_lib6g6.rbe: 4568 -- reverse_face_with_uv
                                            jointpushpullgeometry.rbe: 556 -- block in geometry_handle_finishing
                                            jointpushpullgeometry.rbe: 556 -- each
                                            jointpushpullgeometry.rbe: 556 -- geometry_handle_finishing
                                            jointpushpullgeometry.rbe: 376 -- geometry_robot_handle_finishing
                                            jointpushpullgeometry.rbe: 222 -- robot_call_action
                                            lib6operation.rbe: 370 -- call
                                            lib6operation.rbe: 370 -- step_geometry
                                            lib6operation.rbe: 305 -- block in yield?
                                            SketchUp: 1 -- call
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 30
                                            • 31
                                            • 20 / 31
