    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • L
      Leon aa
      Hi, first of all I really like this plugin and I have been using it for some time now. Somehow the face selection via surface stopped working for me. The plugin only selects by face if I set it to surface.
      • fredo6F
        Weird... May be you could
        • open the Ruby console before launching JPP to check if there are errors
        • post your model, or show a short video of the problem
        • L
          Leon aa
          I opened the Ruby console and then started the plugin, but there was no text in the console, so I think there's no problem there.
          I don't think that there's a problem with my model. I tried it on different models and it wasn't working either.
          Maybe there is a problem with LibFredo? I updated it last week and I haven't noticed any problem before. I tried reinstalling LibFredo and JPP, but it didn't fix anything.
          Here is how it looks in SketchUp, no error message, just not working as intended:
          https://lh3.googleusercontent.com/NYDBJXLT7sezAN-zo_IWJP4Acbj1OvDfYPJvVighSo7VZrWpVmUxxoeWVA990Dxz8BI-6V330jSpyn6ypOa98Ujt99LBn8Y9rk_L97MnKP60EQEeJEheowtRaqAukt8UFB6SAZ4xxJS8NBj_zAQZCcyT3Xo7gL9wa5FCGfd7Xc84DC6Bf6U0Si2rEBsl2QuwGAo_64YTmEvYjTE_q5QEMuRUrPFCPfJQH0u6vpgR9VuXjKDGKhZ7p2RELTMbT5pDB6EWPkdTs9TjZojeYQLyOLNlzNQiQv_T8a5Ije2KSUVas20TLmR0ONbOddARvr0GTu4ahaEkzqQW0vJzds3Jj6TwHpEwtmK77mWOJ1LtSEgi6-PVkWKGE7vDJ_vb2b3F7ig6o3WSAYYK994rumkb_sYyUnmQuP27MJ7osJiqfe2F-bM86idQ_EyYoPdMkYAORvNl1MIuART3NueFMFl8Th8HPh8Ks7vFv-mDh1XCF2PkEe5Um1DEXA8EtPCEN92ptFvv74acnZydPcK3shIGSN-KXZ1YEnn-TvzS7ubzbvPzx0D7hTaOwY3hzvtBa4-tnqUK3w2JQtxkWuEqRVnPGGTs80kpCDuImAy1gxJ_cgvl7V5HFq0v7PMVOTiDTWap9cKHspvmr4W7VsYxJ_4QOmaJZ_12LCjx68g8dAodSWiApzAsCQhOnn58Va5Guy2jNZZHSttnLAKJlAvXn2QYkjC_=w1563-h839-no
          • fredo6F
            In Sketchup, surface is defined by a set of faces whose common edges are soft (so not smooth).
            Can you check in your model.
            Also, what happens when you turn off "Hidden Geometry" ?
            • E
              Einstein
              Round Push Pull with minimum number of rounding segments = 1, that would be nice πŸ˜„ (Now it's 2)
                rv1974
                Fredo, would it be possible to add 'afterward selection department' to JPP?
                Say 3 check boxes that rule which category will stay selected: initial faces, offset faces, or connecting faces.
                • fredo6F
                  I am not sure I understand. The selection scope option is kept across JPP sessions and even Sketchup sessions.
                    rv1974
                    Say you have state 0, then run JPP and immediately after execution (on exit) you'd have (wishful thinking) 3 states.
                    The goal is ability to group selection and assign diffrent material or make some geniuos manipulations (independently).
                    • fredo6F
                      OK. I get what you want to get.
                      Doable indeed, but this is another option in a GUI which some consider already 'bloated'!!
                      Currently, JPP keeps the selection on the faces which have been selected.
                        rv1974
                        @fredo6 said:
                        ...Currently, JPP keeps the selection on the faces which have been selected.
                        OK. Could you please change this setting it to the offsetones? It would solve all my request without UI bloating. You see, I can Cnrl+C initial faces before JPP execution, and then just paste original faces after JPP is done. This simple hack restores original selection.
                        • fredo6F
                          The native SketchUp Push Pull does the following
                          • if and only if a face is pre-selected before launching the PP tool...
                          • ...its offset fasce is hard-selected when you finished the push pull.
                            This means that if you wish to push-pull another face right after within the same Push-Pull session, you have to press Escape to deselect.
                          Is this behavior you want to reproduce with JPP?
                            rv1974
                            This is the way I imagine:
                            1. Preselect
                            2. Run JPP
                            3. Hit Enter to exit
                            4. Offset faces stay selected
                            It's very similar to the principle described in Pilou gifs here:
                            http://sketchucation.com/forums/viewtopic.php?f=323&t=1523&start=30
                            but in our case we deal with faces, not lines
                            P.S. By 'offset faces' I mean case #1 (see my picture above ^^^)
                            • fredo6F
                              @rv1974
                              Can you have a look at JPP v4.4c.
                              It selects the offset faces of preselected faces (if any) at exit. This assumes indeed that you perform only one Push Pull operation and then exit.
                                rv1974
                                Tested right now. Works perfectly, many many thanks! I'll post tomorrow some micro explanation how distribute materials in conjunction with JPP.
                                • fredo6F
                                  Or take v4.4d...
                                  I made it work even if you perform several push pull operations within the same JPP session.
                                  • fredo6F
                                    NEW RELEASE: JointPushPull Interactive v4.4d - 20 Feb 19
                                    JointPushPull Interactive 4.4d select the offset faces of pre-selected faces at exit. See post just above.
                                    JointPushPull 4.4b requires LibFredo6 8.7m or above
                                    See plugin home page of JointPushPull for Download of JointPushPull.
                                    Main Post of the JointPushPull thread on this forum
                                      rv1974
                                      Fredo, when FollowPushPull is used on chamfer face, is there way to get somehow an exact 'chamfer 0' state?
                                        SpookyChick1013
                                        Massively useful plugins as always Fredo. Had the following error found when attempting round pushpull. Here's the log dump.
                                        Thanks in advance!
                                        Date: 19-Mar-19 09:41:55
                                        An error occurred in Round Push Pull
                                        Error in generation of the geometry
                                        undefined method `collect' for nil:NilClass
                                        jointpushpull4geometry.rbe: 1450 -- geometry_rounding_mesh
                                        jointpushpull4geometry.rbe: 1283 -- block in geometry_create_roundings
                                        jointpushpull4geometry.rbe: 1282 -- each
                                        jointpushpull4geometry.rbe: 1282 -- geometry_create_roundings
                                        jointpushpull4geometry.rbe: 267 -- geometry_robot_prepare_mesh
                                        jointpushpull4geometry.rbe: 211 -- robot_call_action
                                        jointpushpull4geometry.rbe: 182 -- geometry_robot_exec
                                        jointpushpull4geometry.rbe: 165 -- geometry_robot
                                        jointpushpull4geometry.rbe: 80 -- block in geometry_execute
                                        lib6operation.rbe: 365 -- call
                                        lib6operation.rbe: 365 -- step_geometry
                                        lib6operation.rbe: 413 -- start_execution
                                        jointpushpull4geometry.rbe: 80 -- geometry_execute
                                        jointpushpull4tool.rbe: 1034 -- go_preview_or_geom
                                        jointpushpull4tool.rbe: 812 -- dragging_stop
                                        https://kuromatsudriveyards.com
                                        Fo-su to tomo ni aran koto o...
                                        • fredo6F
                                          You don't seem to have the latest version of JPP (it should be v4.4d).
                                          Could you update it and advise. Thanks.
                                            SpookyChick1013
                                            What? Wooops! You're right. I try to keep things updated, but somehow that one slipped past me.
                                            I'll let you know once I've had a chance to test things. Thanks Fredo!
                                            Update"Installed teh new version, made sure everything was updated, no conflicting versions, and presto, the same error.
                                            %(#40BFFF)[Date: 22-Mar-19 11:54:25
                                            jointpushpullgeometry.rbe: 1529 -- geometry_rounding_mesh
                                            jointpushpullgeometry.rbe: 1362 -- block in geometry_create_roundings
                                            jointpushpullgeometry.rbe: 1361 -- each
                                            jointpushpullgeometry.rbe: 1361 -- geometry_create_roundings
                                            jointpushpullgeometry.rbe: 269 -- geometry_robot_prepare_mesh
                                            jointpushpullgeometry.rbe: 212 -- robot_call_action
                                            jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                                            jointpushpullgeometry.rbe: 166 -- geometry_robot
                                            jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                                            jointpushpullgeometry.rbe: 81 -- geometry_execute
                                            jointpushpulltool.rbe: 1119 -- go_preview_or_geom
                                            jointpushpulltool.rbe: 845 -- dragging_stop]
                                            It happens whether I use the VCB or not. What I'm trying to do is Round PushPull the faces highlighted in the enclosed sreeen snip
                                            If you need the model, let me know where to send it and I will do so.
                                            Cathryn
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 30
                                            • 31
                                            • 20 / 31
