    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • O Offline
      optimaforever
      @thomthom said:
      Btw, do you have some quad that are not fully QuadFace quads? I see some unexpected uneven edges in the back there:
      [attachment=0:1mfg7n1x]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:1mfg7n1x]
      This is the same strange behaviour I got last year with some meshes. Dunno why, but it seems that some vertices react as a 1.0 crease when subdivided although they are 0 when checked with the crease tool.
      I usually delete the problematic edges and redraw the geometry from scratch when that happens.
      • tuna1957T Offline
        tuna1957
        More late night fooling about / practice. Seem obsessed with what I can make out of copies of one piece. Made the piece on the left, copy _ array twelve times. Exploded and regrouped. Cleaned up the internal bits with Solid Inspector. Decided to flare the top a little more, as always Vertex tools makes it easy. There you have another crazy vase.
        • HornOxxH Offline
          HornOxx
          @tuna1957 said:
          ...Seem obsessed with what I can make out of copies of one piece...
          πŸ˜† πŸ˜† be careful - there is such a high addiction factor πŸ˜† again a so nice (not fooling!) practice πŸ‘ !
          (in the throat(?) above you end up with a triangle - I still do not really understand correctly whether triangles are no longer an obstacle in this kind of workflow, which they were at the beginning of SubD)
          never trust a skinny cook
          • BoxB Offline
            Next you'll start twisting them, then all is lost.
            You'll have to start on the twelve steps and put your faith in a higher power...
            • HornOxxH Offline
              HornOxx
              @box said:
              Next you'll start twisting them...and put your faith in a higher power...
              πŸ˜† πŸ˜† wunderbar !!
              • tuna1957T Offline
                tuna1957
                Thanks Box , HornOxx.
                HornOxx, you asked about triangles..... After I exploded the twelve pieces I erased and redrew the flat bottom inside and out so they were all quads. The pairs of triangles at the top just bellow the rim I could eliminate by " soft, smooth, no cast shadows" but I lost to much definition of the crease that way. Leaving them as triangles kept a better look to the vertical grooves. It seems you can cheat on the quads a little sometimes and still get a nice result.
                • HornOxxH Offline
                  HornOxx
                  thanks for these Infos - yes, you are geting a better shape so πŸ‘
                  This Green-Blue look is this quadface tools live mesh analysis feature - I always forget about this good feature πŸ˜‰
                  • tuna1957T Offline
                    tuna1957
                    HornOxx, your correct the green, purple colors are from Quadface tools analyze function. I forget about it myself sometimes πŸ˜† .
                      @optimaforever said:
                      [attachment=0:gkjocs9z]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:gkjocs9z]
                      If you send me one of these models I can have a look into what is going on.
                      • tuna1957T Offline
                        tuna1957
                        Some more of my weird Vertex tools and SubD stuff. Twisted up the piece on the left, did some copy - array business. Add a few more bits and pieces and I ended up with a hanging lamp. SubD on the twisty bits and bottom trim ring the rest native SU.....
                          Not by me! πŸ˜‰
                          • BoxB Offline
                            A couple of sinks I knocked up as an example.
                            Simple
                            https://i.imgur.com/cVYgeHu.gif
                            Somewhat more complex
                            https://i.imgur.com/vgEyLkv.gif
                              No thickness ? πŸ˜‰
                              • HornOxxH Offline
                                HornOxx
                                @pilou said:
                                No thickness ? πŸ˜‰
                                πŸ˜„ πŸ˜„ I think thickness doesn't make sense where it's not to be seen. but did you notice that Box even models the water overflow correctly? 😲 πŸ˜„ πŸ‘
                                  Yes of course, it was for find a little default on these voluptuous design beauties! πŸ˜‰
                                  The cool thing about Subdivision modeling it's that is always a surprise before the final object! β˜€
                                  • HornOxxH Offline
                                    HornOxx
                                    Yes, each time 😎
                                    • McGyverM Offline
                                      McGyver
                                      In the video pilou posted, does anyone know what plugin the person is using that has an icon which looks like sword?
                                      https://www.daz3d.com/forums/uploads/FileUpload/b6/4800459b5aa5f69873cb7086cc0730.jpeg
                                      Sorry about the crappy screen capture... and thanks for any info.
                                      Visit My ShareCG Freebie Gallery
                                      • HornOxxH Offline
                                        HornOxx
                                        Hi - it could Artisan Subdivide and Smooth (but I'm not sure, however)
                                          dedmin
                                          Zorro2 - https://www.youtube.com/watch?v=Z7uAMfs4T8s
                                          • McGyverM Offline
                                            McGyver
                                            Thank you both!
                                            It was Zorro 2... I did not know that was what that tool did... too bad, I could have used that a bunch of times.
                                            Thanks again.
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 82
                                            • 83
                                            • 75 / 83
