    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • cottyC
      cotty
      Some recent SubD examples...
      my SketchUp gallery
      • HornOxxH
        HornOxx
        πŸ‘ πŸ‘ love these all! One example is more beautiful than the other - And I notice, that, as always before, the marvelous representation of wood (first picture) is a mark of your renders...
        Thanks for sharing!
        never trust a skinny cook
        • utilerU
          utiler
          Beautiful work as always, Cotty! Do you mind me asking what render program you're using? Very crisp.
          Just Curious...
          • cottyC
            cotty
            Thank you, those are rendered with Indigo Renderer.
            my SketchUp gallery
            • tuna1957T
              tuna1957
              A little late night messing about..... Made the little curved piece down front, follow me then Vertex tools to get the twist... Now what ???? Copy around and you get a kind of crazy flower shaped fruit bowl !
              • HornOxxH
                HornOxx
                πŸ˜„ love this "messing" πŸ‘
                (btw "Messing" in German is the metal alloy brass πŸ˜„ πŸ˜„)
                • tuna1957T
                  tuna1957
                  @hornoxx said:
                  πŸ™‚ love this "messing" πŸ‘
                  Thanks HornOxx. Curious would "fooling about" translate better πŸ˜‰
                  • O
                    optimaforever
                    @thomthom said:
                    Btw, do you have some quad that are not fully QuadFace quads? I see some unexpected uneven edges in the back there:
                    [attachment=0:1mfg7n1x]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:1mfg7n1x]
                    This is the same strange behaviour I got last year with some meshes. Dunno why, but it seems that some vertices react as a 1.0 crease when subdivided although they are 0 when checked with the crease tool.
                    I usually delete the problematic edges and redraw the geometry from scratch when that happens.
                    • tuna1957T
                      tuna1957
                      More late night fooling about / practice. Seem obsessed with what I can make out of copies of one piece. Made the piece on the left, copy _ array twelve times. Exploded and regrouped. Cleaned up the internal bits with Solid Inspector. Decided to flare the top a little more, as always Vertex tools makes it easy. There you have another crazy vase.
                      • HornOxxH
                        HornOxx
                        @tuna1957 said:
                        ...Seem obsessed with what I can make out of copies of one piece...
                        πŸ˜† πŸ˜† be careful - there is such a high addiction factor πŸ˜† again a so nice (not fooling!) practice πŸ‘ !
                        (in the throat(?) above you end up with a triangle - I still do not really understand correctly whether triangles are no longer an obstacle in this kind of workflow, which they were at the beginning of SubD)
                        • BoxB
                          Next you'll start twisting them, then all is lost.
                          You'll have to start on the twelve steps and put your faith in a higher power...
                          • HornOxxH
                            HornOxx
                            @box said:
                            Next you'll start twisting them...and put your faith in a higher power...
                            πŸ˜† πŸ˜† wunderbar !!
                            • tuna1957T
                              tuna1957
                              Thanks Box , HornOxx.
                              HornOxx, you asked about triangles..... After I exploded the twelve pieces I erased and redrew the flat bottom inside and out so they were all quads. The pairs of triangles at the top just bellow the rim I could eliminate by " soft, smooth, no cast shadows" but I lost to much definition of the crease that way. Leaving them as triangles kept a better look to the vertical grooves. It seems you can cheat on the quads a little sometimes and still get a nice result.
                              • HornOxxH
                                HornOxx
                                thanks for these Infos - yes, you are geting a better shape so πŸ‘
                                This Green-Blue look is this quadface tools live mesh analysis feature - I always forget about this good feature πŸ˜‰
                                • tuna1957T
                                  tuna1957
                                  HornOxx, your correct the green, purple colors are from Quadface tools analyze function. I forget about it myself sometimes πŸ˜† .
                                    @optimaforever said:
                                    [attachment=0:gkjocs9z]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:gkjocs9z]
                                    If you send me one of these models I can have a look into what is going on.
                                    • tuna1957T
                                      tuna1957
                                      Some more of my weird Vertex tools and SubD stuff. Twisted up the piece on the left, did some copy - array business. Add a few more bits and pieces and I ended up with a hanging lamp. SubD on the twisty bits and bottom trim ring the rest native SU.....
                                        Not by me! πŸ˜‰
                                        • BoxB
                                          A couple of sinks I knocked up as an example.
                                          Simple
                                          https://i.imgur.com/cVYgeHu.gif
                                          Somewhat more complex
                                          https://i.imgur.com/vgEyLkv.gif
                                            No thickness ? πŸ˜‰
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 83
                                            • 84
                                            • 65 / 84
