    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 857.0k Views 165 Watching
    • BoxB Offline
      Love the fact it is compatible with JPP and SUbD.
      https://i.imgur.com/xljnTl1.gif
        And FFD
          Armeios
          Hello Anton, thanks for your great work.
          Do you plan the possibility of assigning internal pressure to an object?
          For example to simulate an inflatable?
          • urgenU Offline
            urgen
            ...MARVELOUS designer in sketchup? ๐Ÿ˜Ž ...brilliant! ๐Ÿ‘
            --pupil forever...------
            • HornOxxH Offline
              HornOxx
              ...Iโ€™m afraid this is going to be Another Addiction Thing again ๐Ÿ˜†
              never trust a skinny cook
                Anton_S
                Currently, you can apply fake pressure by controlling the scale slider in ClothWorks UI.
                • soloS Offline
                  In the future, will it be possible to integrate this with MS physics? Say I want to fill a bag with objects or drop items onto a net kinda thing?
                  • F Offline
                    faust07
                    Enthusiastic Yes... ๐Ÿ˜Ž
                      Anton_S
                      I wrote my own physics engine for ClothWorks works. MSPhysics uses NewtonDynamics, which doesn't support cloth or soft bodies at the moment. Though, I will definitely include rigid dynamic bodies into this.
                        cowboyathome
                        This plugin is amazing and easy to use!
                        Round Tablecloth
                        Vinyl Flooring
                          Anton_S
                          Amazing results!
                          • BoxB Offline
                            Ooops, I think I made my cargo net just a bit too flexible!
                            • soloS Offline
                              Using a png based image on a subdivided plane or pure geometry?
                              • BoxB Offline
                                It's pure geometry Pete, I think if it was a png on a plane the ball wouldn't be able to slip through.
                                Edit: Here you can see the chainlink fence texture on a plane doesn't let the ball slip through.
                                • HornOxxH Offline
                                  HornOxx
                                  @box said:
                                  It's pure geometry Pete,...
                                  ...this is so awsome again ๐Ÿ‘ ๐Ÿ˜ฎ ๐Ÿ‘
                                    @hieru said:
                                    Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
                                    I can't seem to get smooth results with SubD as it generates extra geometry and everything appears tessellated. Notice all the dimples with hidden lines turned off.
                                    ClothWorks is not generating QFT quads. Convert the Clothworks mesh to Quads.
                                    • HieruH Offline
                                      Hieru
                                      DuvetTest.skp
                                      www.davidhier.co.uk
                                      • HieruH Offline
                                        Hieru
                                        QFT doesn't like that at all...tons of duplicate and reverse faces plus surface weirdness.
                                        www.davidhier.co.uk
                                          How are you converting from ClothWorks to QFT?
                                          • HieruH Offline
                                            Hieru
                                            I was using Convert Wireframe To Quads....that was my mistake. Convert Triangulated Mesh To Quads does the trick. I got there in the end - thanks for pointing me in the right direction Rich.
                                            www.davidhier.co.uk
                                            • 35
                                            • 36
                                            • 4 / 36
