    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.3k Views 170 Watching
      Armeios
      Hello Anton, thanks for your great work.
      Do you plan the possibility of assigning internal pressure to an object?
      For example to simulate an inflatable?
      • urgenU
        urgen
        ...MARVELOUS designer in sketchup? ๐Ÿ˜Ž ...brilliant! ๐Ÿ‘
        --pupil forever...------
        • HornOxxH
          HornOxx
          ...Iโ€™m afraid this is going to be Another Addiction Thing again ๐Ÿ˜†
          never trust a skinny cook
            Anton_S
            Currently, you can apply fake pressure by controlling the scale slider in ClothWorks UI.
            • soloS
              In the future, will it be possible to integrate this with MS physics? Say I want to fill a bag with objects or drop items onto a net kinda thing?
              • F
                faust07
                Enthusiastic Yes... ๐Ÿ˜Ž
                  Anton_S
                  I wrote my own physics engine for ClothWorks works. MSPhysics uses NewtonDynamics, which doesn't support cloth or soft bodies at the moment. Though, I will definitely include rigid dynamic bodies into this.
                  • C
                    cowboyathome
                    This plugin is amazing and easy to use!
                    Round Tablecloth
                    Vinyl Flooring
                      Anton_S
                      Amazing results!
                      • BoxB
                        Ooops, I think I made my cargo net just a bit too flexible!
                        • soloS
                          Using a png based image on a subdivided plane or pure geometry?
                          • BoxB
                            It's pure geometry Pete, I think if it was a png on a plane the ball wouldn't be able to slip through.
                            Edit: Here you can see the chainlink fence texture on a plane doesn't let the ball slip through.
                            • HornOxxH
                              HornOxx
                              @box said:
                              It's pure geometry Pete,...
                              ...this is so awsome again ๐Ÿ‘ ๐Ÿ˜ฎ ๐Ÿ‘
                                @hieru said:
                                Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
                                I can't seem to get smooth results with SubD as it generates extra geometry and everything appears tessellated. Notice all the dimples with hidden lines turned off.
                                ClothWorks is not generating QFT quads. Convert the Clothworks mesh to Quads.
                                • HieruH
                                  Hieru
                                  DuvetTest.skp
                                  www.davidhier.co.uk
                                  • HieruH
                                    Hieru
                                    QFT doesn't like that at all...tons of duplicate and reverse faces plus surface weirdness.
                                    www.davidhier.co.uk
                                      How are you converting from ClothWorks to QFT?
                                      • HieruH
                                        Hieru
                                        I was using Convert Wireframe To Quads....that was my mistake. Convert Triangulated Mesh To Quads does the trick. I got there in the end - thanks for pointing me in the right direction Rich.
                                        www.davidhier.co.uk
                                          An easier way to use SUbD to subdivide the plane and explode to apply SUbD. Then convert that QFT compliant mesh to a cloth.
                                          Make sure Boundary Corners is set to Sharp in the SUbD dialog.
                                          • HieruH
                                            Hieru
                                            I'll give that a go, thanks.
                                            Looking good so far, but I need to dig into the manual so that I can appreciate the full potential.
                                            www.davidhier.co.uk
                                            • 36
                                            • 37
                                            • 4 / 37
