    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 857.0k Views 165 Watching
    • jujuJ Offline
      juju
      @pepetrucci said:
      Awesome!! This is indeed one of the best plugins for sketch i've seen so far. It's incredible how much has my workflow changed (and i think everyone's) in the last couple of years with subd, qftools, skatter, vertextools, wrapr.... and now this!!
      I know this is OT, but don't forget SKALP!
      • PepetrucciP Offline
        Pepetrucci
        Of course of course! So many great plugins out there ๐Ÿ˜†
          kenancakir
          It took about a minute to calculate because of the hedgehog model, but works..
          • BoxB Offline
            Love the fact it is compatible with JPP and SUbD.
            https://i.imgur.com/xljnTl1.gif
              And FFD
                Armeios
                Hello Anton, thanks for your great work.
                Do you plan the possibility of assigning internal pressure to an object?
                For example to simulate an inflatable?
                • urgenU Offline
                  urgen
                  ...MARVELOUS designer in sketchup? ๐Ÿ˜Ž ...brilliant! ๐Ÿ‘
                  --pupil forever...------
                  • HornOxxH Offline
                    HornOxx
                    ...Iโ€™m afraid this is going to be Another Addiction Thing again ๐Ÿ˜†
                    never trust a skinny cook
                      Anton_S
                      Currently, you can apply fake pressure by controlling the scale slider in ClothWorks UI.
                      • soloS Offline
                        In the future, will it be possible to integrate this with MS physics? Say I want to fill a bag with objects or drop items onto a net kinda thing?
                        • F Offline
                          faust07
                          Enthusiastic Yes... ๐Ÿ˜Ž
                            Anton_S
                            I wrote my own physics engine for ClothWorks works. MSPhysics uses NewtonDynamics, which doesn't support cloth or soft bodies at the moment. Though, I will definitely include rigid dynamic bodies into this.
                              cowboyathome
                              This plugin is amazing and easy to use!
                              Round Tablecloth
                              Vinyl Flooring
                                Anton_S
                                Amazing results!
                                • BoxB Offline
                                  Ooops, I think I made my cargo net just a bit too flexible!
                                  • soloS Offline
                                    Using a png based image on a subdivided plane or pure geometry?
                                    • BoxB Offline
                                      It's pure geometry Pete, I think if it was a png on a plane the ball wouldn't be able to slip through.
                                      Edit: Here you can see the chainlink fence texture on a plane doesn't let the ball slip through.
                                      • HornOxxH Offline
                                        HornOxx
                                        @box said:
                                        It's pure geometry Pete,...
                                        ...this is so awsome again ๐Ÿ‘ ๐Ÿ˜ฎ ๐Ÿ‘
                                          @hieru said:
                                          Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
                                          I can't seem to get smooth results with SubD as it generates extra geometry and everything appears tessellated. Notice all the dimples with hidden lines turned off.
                                          ClothWorks is not generating QFT quads. Convert the Clothworks mesh to Quads.
                                          • HieruH Offline
                                            Hieru
                                            DuvetTest.skp
                                            www.davidhier.co.uk
                                            • 35
                                            • 36
                                            • 4 / 36
