    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 740.2k Views 163 Watching
      Anton_S
      @marvsweden said:
      Purchased. It's going to be exciting using it.
      I'm on Mac/SU2018 and the toggle UI window/button doesn't work. It shows up once but if I toggle it by hitting the button it never shows up again until i shut down and restart SU.
      Thanks for an important report! I will fix this by as soon as tomorrow (if possible).
        marvsweden
        Sure, no problem. Looking forward to using it.
        • PepetrucciP Offline
          Pepetrucci
          Awesome!! This is indeed one of the best plugins for sketch i've seen so far. It's incredible how much has my workflow changed (and i think everyone's) in the last couple of years with subd, qftools, skatter, vertextools, wrapr.... and now this!!
          Thanks so much for making sketchup even more fun!
          Here my first attempt with clothworks, the export frames option is veeery cool!
          https://media.giphy.com/media/d5E1Lofnq4ZUTr79Gp/giphy.gif
          • jujuJ Offline
            juju
            I know this is OT, but don't forget SKALP!
              Pepetrucci
              Of course of course! So many great plugins out there πŸ˜†
                kenancakir
                It took about a minute to calculate because of the hedgehog model, but works..
                • BoxB Offline
                  Love the fact it is compatible with JPP and SUbD.
                  https://i.imgur.com/xljnTl1.gif
                    And FFD
                      Armeios
                      Hello Anton, thanks for your great work.
                      Do you plan the possibility of assigning internal pressure to an object?
                      For example to simulate an inflatable?
                      • urgenU Offline
                        urgen
                        ...MARVELOUS designer in sketchup? 😎 ...brilliant! πŸ‘
                        --pupil forever...------
                        • HornOxxH Offline
                          HornOxx
                          ...I’m afraid this is going to be Another Addiction Thing again πŸ˜†
                          never trust a skinny cook
                            Anton_S
                            Currently, you can apply fake pressure by controlling the scale slider in ClothWorks UI.
                            • soloS Offline
                              In the future, will it be possible to integrate this with MS physics? Say I want to fill a bag with objects or drop items onto a net kinda thing?
                              • F Offline
                                faust07
                                Enthusiastic Yes... 😎
                                  Anton_S
                                  I wrote my own physics engine for ClothWorks works. MSPhysics uses NewtonDynamics, which doesn't support cloth or soft bodies at the moment. Though, I will definitely include rigid dynamic bodies into this.
                                    cowboyathome
                                    This plugin is amazing and easy to use!
                                    Round Tablecloth
                                    Vinyl Flooring
                                      Anton_S
                                      Amazing results!
                                      • BoxB Offline
                                        Ooops, I think I made my cargo net just a bit too flexible!
                                        • soloS Offline
                                          Using a png based image on a subdivided plane or pure geometry?
                                          • BoxB Offline
                                            It's pure geometry Pete, I think if it was a png on a plane the ball wouldn't be able to slip through.
                                            Edit: Here you can see the chainlink fence texture on a plane doesn't let the ball slip through.
                                            • 35
                                            • 36
                                            • 4 / 36
