    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
      Anton_S
      I wrote my own physics engine for ClothWorks works. MSPhysics uses NewtonDynamics, which doesn't support cloth or soft bodies at the moment. Though, I will definitely include rigid dynamic bodies into this.
      • C
        cowboyathome
        This plugin is amazing and easy to use!
        Round Tablecloth
        Vinyl Flooring
          Anton_S
          Amazing results!
          • BoxB
            Ooops, I think I made my cargo net just a bit too flexible!
            • soloS
              Using a png based image on a subdivided plane or pure geometry?
              • BoxB
                It's pure geometry Pete, I think if it was a png on a plane the ball wouldn't be able to slip through.
                Edit: Here you can see the chainlink fence texture on a plane doesn't let the ball slip through.
                • HornOxxH
                  HornOxx
                  @box said:
                  It's pure geometry Pete,...
                  ...this is so awsome again ๐Ÿ‘ ๐Ÿ˜ฎ ๐Ÿ‘
                  never trust a skinny cook
                    @hieru said:
                    Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
                    I can't seem to get smooth results with SubD as it generates extra geometry and everything appears tessellated. Notice all the dimples with hidden lines turned off.
                    ClothWorks is not generating QFT quads. Convert the Clothworks mesh to Quads.
                    • HieruH
                      Hieru
                      DuvetTest.skp
                      www.davidhier.co.uk
                      • HieruH
                        Hieru
                        QFT doesn't like that at all...tons of duplicate and reverse faces plus surface weirdness.
                        www.davidhier.co.uk
                          How are you converting from ClothWorks to QFT?
                          • HieruH
                            Hieru
                            I was using Convert Wireframe To Quads....that was my mistake. Convert Triangulated Mesh To Quads does the trick. I got there in the end - thanks for pointing me in the right direction Rich.
                            www.davidhier.co.uk
                              An easier way to use SUbD to subdivide the plane and explode to apply SUbD. Then convert that QFT compliant mesh to a cloth.
                              Make sure Boundary Corners is set to Sharp in the SUbD dialog.
                              • HieruH
                                Hieru
                                I'll give that a go, thanks.
                                Looking good so far, but I need to dig into the manual so that I can appreciate the full potential.
                                www.davidhier.co.uk
                                • jo-keJ
                                  jo-ke
                                  thank you for that beautyfull plugin
                                  http://www.zz7.de
                                  • soloS
                                    I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
                                      It alreadt support draping lines. Read the tutorial in the manual.
                                      • jo-keJ
                                        jo-ke
                                        I have problems with textures. what did I wrong?
                                        http://www.zz7.de
                                        • BoxB
                                          Make sure the texture is applied to the faces not the group.
                                          • jujuJ
                                            juju
                                            I saw that "Rope Fall" is also subscription these days, very inspiring...
                                            • 35
                                            • 36
                                            • 5 / 36
