    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • deaneauD
      deaneau
      @Box really good. my question is: you are a basket maker or architecture? i see both. a basket and a building πŸ˜„
      OT: your boxgif is so funny πŸ˜„ πŸ˜„ πŸ˜„
        [edg3d:30l4sz9z]KOsfTsGvmvZe0VW[/edg3d:30l4sz9z]
          i forgot the file...
          barrel.skp
          • pbacotP
            Thanks for the barrel! Very nice but mine arrived all dirty and leaking some black stuff!
            • C
              Carto
              [attachment=0:2m18mrri]<!-- ia0 -->barrel.skp<!-- ia0 -->[/attachment:2m18mrri]
              Hello Rich,
              Did you use your new plugin (Wrap-R) to map the texture? BTW great model. Thanks.
              Regards
              • BoxB
                Just a simple example once again of how working with these tools can make for some really neat meshes.
                • cottyC
                  cotty
                  A quick evening doodle...
                  my SketchUp gallery
                    Nice! That actually looks like a nice model to test OpenSubdiv UV mapping handling with. Do you mind sharing the model?
                    • N
                      nlipovac
                      How is it coming along, any sneak peek? 😎
                        It's been slow over the summer. Currently on vacation. Things will spin up in a few weeks. πŸ˜„
                        • cottyC
                          cotty
                          Of course no problem...
                          subd_knife.skp
                          my SketchUp gallery
                            [edg3d:q5l0hefm]0BS0SdGtKkVqlg4[/edg3d:q5l0hefm]
                            • N
                              nlipovac
                              @rich o brien said:
                              [attachment=0:lutopfq9]<!-- ia0 -->grab_22_09_2016_001.png<!-- ia0 -->[/attachment:lutopfq9]
                              [edg3d:lutopfq9]0BS0SdGtKkVqlg4[/edg3d:lutopfq9]
                              Looks great! πŸ€“
                              Texturing inside Substance Designer?
                              • HieruH
                                Hieru
                                Quick question.
                                What happens if you share a SubD model (without converting to plain mesh) and someone without SubD opens it? Do they just get the control mesh?
                                www.davidhier.co.uk
                                  Yea, it'll appear like any other SketchUp group/component.
                                  • K
                                    kaas
                                    If I could ask the experts; I'm totally new to subD. Trying it out for making furniture.
                                    Started making the frame for a Stack Stove Cubi. Whats the best strategy for the indicated areas? The easy way is to just continue the lines from the horizontal frame onto the leg. But I'm trying to keep the polycount as low as possible as well.
                                    Any suggestions?
                                    stackCubi_leg.skp
                                    • HornOxxH
                                      HornOxx
                                      Hi Kaas
                                      I would recommend TigΒ΄s Split Tools which generate quads at the connection points like sketched below.
                                      http://sketchucation.com/forums/viewtopic.php?t=43376
                                      https://www.youtube.com/watch?v=hcGGcLndeTE
                                      never trust a skinny cook
                                      • HieruH
                                        Hieru
                                        Thanks Thomas πŸ‘
                                        www.davidhier.co.uk
                                        • HieruH
                                          Hieru
                                          @Kaas
                                          Sometimes you can bend over backwards to keep loops to a minimum (see examples either side of central control meshes)...
                                          ...only to find that there isn't that much difference in the poly count:
                                          In this instance you might even find that using RoundCorners is the most economic and efficient way to model this form.
                                          Corner.skp
                                          www.davidhier.co.uk
                                          • K
                                            kaas
                                            @HorNoxx; thanks for the suggestion. I already found and use that gem by TIG.
                                            @Hieru; thanks for the effort and insight. It confirms my idea that subD in some cases might lead to more faces than conventional methods like roundcorner or native tools. Still learning though and lots of fun.
                                            stackStove_cubi_test1.skp
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 83
                                            • 84
                                            • 31 / 84
