    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
      i forgot the file...
      barrel.skp
      • pbacotP
        Thanks for the barrel! Very nice but mine arrived all dirty and leaking some black stuff!
        • C
          Carto
          [attachment=0:2m18mrri]<!-- ia0 -->barrel.skp<!-- ia0 -->[/attachment:2m18mrri]
          Hello Rich,
          Did you use your new plugin (Wrap-R) to map the texture? BTW great model. Thanks.
          Regards
          • BoxB
            Just a simple example once again of how working with these tools can make for some really neat meshes.
            • cottyC
              cotty
              A quick evening doodle...
              my SketchUp gallery
                Nice! That actually looks like a nice model to test OpenSubdiv UV mapping handling with. Do you mind sharing the model?
                • N
                  nlipovac
                  How is it coming along, any sneak peek? 😎
                    It's been slow over the summer. Currently on vacation. Things will spin up in a few weeks. πŸ˜„
                    • cottyC
                      cotty
                      Of course no problem...
                      subd_knife.skp
                      my SketchUp gallery
                        [edg3d:q5l0hefm]0BS0SdGtKkVqlg4[/edg3d:q5l0hefm]
                        • N
                          nlipovac
                          @rich o brien said:
                          [attachment=0:lutopfq9]<!-- ia0 -->grab_22_09_2016_001.png<!-- ia0 -->[/attachment:lutopfq9]
                          [edg3d:lutopfq9]0BS0SdGtKkVqlg4[/edg3d:lutopfq9]
                          Looks great! πŸ€“
                          Texturing inside Substance Designer?
                          • HieruH
                            Hieru
                            Quick question.
                            What happens if you share a SubD model (without converting to plain mesh) and someone without SubD opens it? Do they just get the control mesh?
                            www.davidhier.co.uk
                              Yea, it'll appear like any other SketchUp group/component.
                              • K
                                kaas
                                If I could ask the experts; I'm totally new to subD. Trying it out for making furniture.
                                Started making the frame for a Stack Stove Cubi. Whats the best strategy for the indicated areas? The easy way is to just continue the lines from the horizontal frame onto the leg. But I'm trying to keep the polycount as low as possible as well.
                                Any suggestions?
                                stackCubi_leg.skp
                                • HornOxxH
                                  HornOxx
                                  Hi Kaas
                                  I would recommend TigΒ΄s Split Tools which generate quads at the connection points like sketched below.
                                  http://sketchucation.com/forums/viewtopic.php?t=43376
                                  https://www.youtube.com/watch?v=hcGGcLndeTE
                                  never trust a skinny cook
                                  • HieruH
                                    Hieru
                                    Thanks Thomas πŸ‘
                                    www.davidhier.co.uk
                                    • HieruH
                                      Hieru
                                      @Kaas
                                      Sometimes you can bend over backwards to keep loops to a minimum (see examples either side of central control meshes)...
                                      ...only to find that there isn't that much difference in the poly count:
                                      In this instance you might even find that using RoundCorners is the most economic and efficient way to model this form.
                                      Corner.skp
                                      www.davidhier.co.uk
                                      • K
                                        kaas
                                        @HorNoxx; thanks for the suggestion. I already found and use that gem by TIG.
                                        @Hieru; thanks for the effort and insight. It confirms my idea that subD in some cases might lead to more faces than conventional methods like roundcorner or native tools. Still learning though and lots of fun.
                                        stackStove_cubi_test1.skp
                                        • HieruH
                                          Hieru
                                          Happy to help πŸ‘ . I'll take a look at your model tomorrow, but from the looks of things your workflow is coming along nicely (certainly more advanced than when I was starting out).
                                          One thing I will add is that sometimes the extra geometry is worth it e.g. for UV mapping or selling models in different formats.
                                          On the topic of UV mapping, I suspect that my left-hand control mesh might be the better approach for mapping. Hopefully someone who knows more about UV unwrapping will be able to confirm or refute this.
                                          www.davidhier.co.uk
                                          • K
                                            kaas
                                            I was thinking about the mapping as well. there is some stretching visible so need to fix those. Its lots of fun. Artisan experience from few years ago helps a lot - its knife tool as well.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 83
                                            • 84
                                            • 31 / 84
