    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • ntxdaveN
      ntxdave
      @pilou said:
      AmbientOcclusionEx v1.9.5.
      TheaRender v1.5 (from Animator and in Batch from Thea)
      SketchFX Ex v1.0.6
      Twilight Render %(#FF0000)[Pro v3.5]
      It's Twilight Render Pro v2.5! ๐Ÿ˜‰ (and I suppose also Hobby Version ? )
      What is the process for use it with Twilight Render ?
      It is my understanding that only the Pro version can be used with Animator. We will have to wait and see when they post the link today.
      Press F1...thank me later
        Idem! Seems there is blend of rotation / Object / General!
        • fredo6F
          @chri said:
          Hi Fredo
          I have a problem to ROTATE.
          Please , have a look on the next GIF ( clic to anim )
          Chri
          Thanks for signaling. Fixed.
          • fredo6F
            SketchFX Ex v1.0.6
            I think this is just for Pro version.
            • fredo6F
              [attachment=0:yeoqnx06]<!-- ia0 -->GIF_idem.gif<!-- ia0 -->[/attachment:yeoqnx06]
              Is there a bug there?
              • ntxdaveN
                ntxdave
                I have been rebuilding my Pendulum animation (preparing for Twilight Render) and I have not seen a problem. I thought I did once but went back and redid my sequence and all worked well for me.
                  Yes same than Chris!
                  Rotation must be from a point outside the object, but result gives from a point inside the object! ๐Ÿ˜ฎ
                  • ntxdaveN
                    ntxdave
                    OK - I understand. My rotations were from inside the object.
                    • fredo6F
                      When you pick the pivot, the reference component containing the pivot is highlighted in orange. If you wish a pivot at top of model, then right click and select the option.
                      • chriC
                        chri
                        OK
                        Thanks Fredo
                        • fredo6F
                          In the current version, there is a bug when you capture the Rotation movement, but the transformation is actually created correctly.
                            Better indeed! ๐Ÿ˜„
                            • F
                              Falstaff
                              The camera tracking is not working for me - in particular object selection and playback. I am running on a MAC. Video attached.
                              Camera_test_small.mov
                              • ntxdaveN
                                ntxdave
                                This is my first render with Animator using Twilight Render 2.5.
                                I used the lowest quality settings because of the render time. This one took about 1.5 hours. When I looked at a higher quality setting, the render time was MUCH longer.
                                At least it is a start.
                                • fredo6F
                                  New Release: Animator - v1.0y - 11 Jul 16
                                  This is a maintenance release fixing bugs in
                                  • Tracking cameras
                                  • edition of rotation with orbiting
                                  See main post for RBZ files
                                  • fredo6F
                                    There seems to be a bug when playing it.
                                    Could you please open the Ruby console and see what it is.
                                    EDIT: don't bother. I think I fixed it in v1.0y
                                    • F
                                      faust07
                                      @ntxdave: Did you try the twilight render settings 4) Animation 01. Low+ObjectAnimation or 02. Medium+...? The usually give much smoother and faster animation results. I can't test it because I have only twilight hobby.
                                      • ntxdaveN
                                        ntxdave
                                        I am trying another one now. I am trying the Animation 00 Preview Object Animation. That is going to take around 7hrs. We will see how that goes. When I looked at Easy 01 Low+ it I got the feedback that it would be a LONG time.
                                        On the Twilight Render Forum, I go feedback that they are working on some presets that are the settings they used to produce the forklift sample they posted.
                                        I am trying to remain optimistic that they/we will find a solution that produces some satisfactory results (both quality & time).
                                        I just upgraded my license from Hobby to Pro specifically for this reason so I want to help (if I am capable ๐Ÿ˜‰ ) to find a solution that melds Animator and Twilight Render successfully.
                                        • F
                                          faust07
                                          As a late Beta-tester - I must say: great!
                                          Very well thought out. Very comprehensive feature set.
                                          Very stable and easy to handle. Detailed Video Tutorials.
                                          It is recommended to study the video before or better parallel to the first Animation.
                                          And the timeline is the hit - Incredible work has gone into the user interface.
                                          So far, only a few small questions and comments:
                                          • Positioner: How can I delete or overwrite Positions?
                                          • Generation of videos: Is it possible to define start and end position with frame numbers? (In addition to the time indication)
                                          • Tracking camera: In my understanding, it seems more like a following camera (the camera moves with the target).
                                          • Rendering: Export to Indigo (RT) would be cool...
                                          Here a small first example. The formula for the rotation of wheels is a good help especially in curves...
                                          AnimatorTest_02.skp
                                            The black YouTube embeds are an issue related to Chrome Browsers.
                                            • 29
                                            • 30
                                            • 3 / 30
