    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    595 Posts 119 Posters 2.2m Views 119 Watching
    • fredo6F Offline
      In the current version, there is a bug when you capture the Rotation movement, but the transformation is actually created correctly.
        When you pick the pivot, the reference component containing the pivot is highlighted in orange. If you wish a pivot at top of model, then right click and select the option.
        Better indeed! πŸ˜„
        • F Offline
          Falstaff
          The camera tracking is not working for me - in particular object selection and playback. I am running on a MAC. Video attached.
          Camera_test_small.mov
          • ntxdaveN Offline
            ntxdave
            This is my first render with Animator using Twilight Render 2.5.
            I used the lowest quality settings because of the render time. This one took about 1.5 hours. When I looked at a higher quality setting, the render time was MUCH longer.
            At least it is a start.
            Press F1...thank me later
            • fredo6F Offline
              New Release: Animator - v1.0y - 11 Jul 16
              This is a maintenance release fixing bugs in
              • Tracking cameras
              • edition of rotation with orbiting
              See main post for RBZ files
              • fredo6F Offline
                There seems to be a bug when playing it.
                Could you please open the Ruby console and see what it is.
                EDIT: don't bother. I think I fixed it in v1.0y
                • F Offline
                  faust07
                  @ntxdave: Did you try the twilight render settings 4) Animation 01. Low+ObjectAnimation or 02. Medium+...? The usually give much smoother and faster animation results. I can't test it because I have only twilight hobby.
                  • ntxdaveN Offline
                    ntxdave
                    I am trying another one now. I am trying the Animation 00 Preview Object Animation. That is going to take around 7hrs. We will see how that goes. When I looked at Easy 01 Low+ it I got the feedback that it would be a LONG time.
                    On the Twilight Render Forum, I go feedback that they are working on some presets that are the settings they used to produce the forklift sample they posted.
                    I am trying to remain optimistic that they/we will find a solution that produces some satisfactory results (both quality & time).
                    I just upgraded my license from Hobby to Pro specifically for this reason so I want to help (if I am capable πŸ˜‰ ) to find a solution that melds Animator and Twilight Render successfully.
                    • F Offline
                      faust07
                      As a late Beta-tester - I must say: great!
                      Very well thought out. Very comprehensive feature set.
                      Very stable and easy to handle. Detailed Video Tutorials.
                      It is recommended to study the video before or better parallel to the first Animation.
                      And the timeline is the hit - Incredible work has gone into the user interface.
                      So far, only a few small questions and comments:
                      • Positioner: How can I delete or overwrite Positions?
                      • Generation of videos: Is it possible to define start and end position with frame numbers? (In addition to the time indication)
                      • Tracking camera: In my understanding, it seems more like a following camera (the camera moves with the target).
                      • Rendering: Export to Indigo (RT) would be cool...
                      Here a small first example. The formula for the rotation of wheels is a good help especially in curves...
                      AnimatorTest_02.skp
                        The black YouTube embeds are an issue related to Chrome Browsers.
                        • fredo6F Offline
                          New Release: Animator - v1.1a - 15 Aug 16
                          This is a maintenance release fixing bugs with small evolutions
                          • New Circular method for interpolating cameras, closer to what Sketchup does between Scene (see video below)
                          • History covers all actions and is common to all films and clips
                          • fredo6F Offline
                            New Release: Animator - v1.1b - 16 Aug 16
                            This version 1.1b fixes a major bug affecting Repeat and Pursue options and also address a bug in History.
                            • fredo6F Offline
                              New Release: Animator - v1.1c - 12 Sep 16
                              This release introduce the concept of Kinematic Constraints, which basically is a declaration of a kinematic relationship between objects.
                              It also fixes numerous bug and includes some cosmetic adjustments.
                              • fredo6F Offline
                                New Release: Animator - v1.1e - 08 Oct 16
                                This release is candidate to be the first one of the public beta program.
                                It introduces a new Visual effect, Visual Extents, which forces the camera to frame the whole model or a selection of objects.
                                It also fixes bugs and includes some cosmetic adjustments.
                                  Cool! 😎
                                  No animation on a path ?
                                  http://sketchucation.com/forums/download/file.php?id=134909
                                    Ahem.... πŸ˜‰
                                    • V Offline
                                      valaki1
                                      Wow! It's out
                                        M3one
                                        I can't find the Animator plug-in on the extension warehouse. On the first post sais that it is on the pluginstore but I don't know what that is. Please can you help me?
                                        By the way, I did find the LibFredo6 on the extension warehouse.
                                        Thanks!!
                                          M3one
                                          @m3one said:
                                          Thanks!!
                                          I answer myself, the pluginstore is on this web πŸ‘Š
                                          I just installed both, the animator and the libfredo6, the problem is that I didn't find the same version letter (Animator is v1.2a and LibFredo6 is 7.2d) but I think they work.
                                          It seems that this project is abandoned.. it's a real pity, I think is a real powerful tool.
                                            I don't know where to start....
                                            Why is not having the same letter a problem?
                                            And why is an Extension that's 3 weeks old abandoned?
                                            • 29
                                            • 30
                                            • 3 / 30
