    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
      AmbientOcclusionEx v1.9.5.
      TheaRender v1.5 (from Animator and in Batch from Thea)
      SketchFX Ex v1.0.6
      Twilight Render %(#FF0000)[Pro v3.5]
      It's Twilight Render Pro v2.5! ๐Ÿ˜‰ (and I suppose also Hobby Version ? )
      What is the process for use it with Twilight Render ?
      • chriC
        chri
        Hi Fredo
        I have a problem to ROTATE.
        Please , have a look on the next GIF ( clic to anim )
        Chri
        • ntxdaveN
          ntxdave
          SketchFX Ex v1.0.6
          It is my understanding that only the Pro version can be used with Animator. We will have to wait and see when they post the link today.
          Press F1...thank me later
            Idem! Seems there is blend of rotation / Object / General!
            • fredo6F
              @chri said:
              Hi Fredo
              Chri
              Thanks for signaling. Fixed.
              • fredo6F
                SketchFX Ex v1.0.6
                I think this is just for Pro version.
                • fredo6F
                  [attachment=0:yeoqnx06]<!-- ia0 -->GIF_idem.gif<!-- ia0 -->[/attachment:yeoqnx06]
                  Is there a bug there?
                  • ntxdaveN
                    ntxdave
                    I have been rebuilding my Pendulum animation (preparing for Twilight Render) and I have not seen a problem. I thought I did once but went back and redid my sequence and all worked well for me.
                      Yes same than Chris!
                      Rotation must be from a point outside the object, but result gives from a point inside the object! ๐Ÿ˜ฎ
                      • ntxdaveN
                        ntxdave
                        OK - I understand. My rotations were from inside the object.
                        • fredo6F
                          When you pick the pivot, the reference component containing the pivot is highlighted in orange. If you wish a pivot at top of model, then right click and select the option.
                          • chriC
                            chri
                            OK
                            Thanks Fredo
                            • fredo6F
                              In the current version, there is a bug when you capture the Rotation movement, but the transformation is actually created correctly.
                                Better indeed! ๐Ÿ˜„
                                • F
                                  Falstaff
                                  The camera tracking is not working for me - in particular object selection and playback. I am running on a MAC. Video attached.
                                  Camera_test_small.mov
                                  • ntxdaveN
                                    ntxdave
                                    This is my first render with Animator using Twilight Render 2.5.
                                    I used the lowest quality settings because of the render time. This one took about 1.5 hours. When I looked at a higher quality setting, the render time was MUCH longer.
                                    At least it is a start.
                                    • fredo6F
                                      New Release: Animator - v1.0y - 11 Jul 16
                                      This is a maintenance release fixing bugs in
                                      • Tracking cameras
                                      • edition of rotation with orbiting
                                      See main post for RBZ files
                                      • fredo6F
                                        There seems to be a bug when playing it.
                                        Could you please open the Ruby console and see what it is.
                                        EDIT: don't bother. I think I fixed it in v1.0y
                                        • F
                                          faust07
                                          @ntxdave: Did you try the twilight render settings 4) Animation 01. Low+ObjectAnimation or 02. Medium+...? The usually give much smoother and faster animation results. I can't test it because I have only twilight hobby.
                                          • ntxdaveN
                                            ntxdave
                                            I am trying another one now. I am trying the Animation 00 Preview Object Animation. That is going to take around 7hrs. We will see how that goes. When I looked at Easy 01 Low+ it I got the feedback that it would be a LONG time.
                                            On the Twilight Render Forum, I go feedback that they are working on some presets that are the settings they used to produce the forklift sample they posted.
                                            I am trying to remain optimistic that they/we will find a solution that produces some satisfactory results (both quality & time).
                                            I just upgraded my license from Hobby to Pro specifically for this reason so I want to help (if I am capable ๐Ÿ˜‰ ) to find a solution that melds Animator and Twilight Render successfully.
                                            • 29
                                            • 30
                                            • 3 / 30
