    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F
      Actually, the X2 is not good. Take the 7.0x3.
      • chriC
        chri
        hi Fredo
        the new release don't works for me
        When i click on the icon ... nothing !
        (i use SKETCHUP PRO 2014 AND WINDOWS XP )
        Chri
        • chriC
          chri
          @fredo6 said:
          chri,
          Can you open the Ruby console to see what is going on
          message in Ruby console
          Error: #<NoMethodError: undefined method `definition' for #Sketchup::Group:0x968a150>
          • chriC
            chri
            It works for me
            Thanks Fredo
            Chri
              AmbientOcclusionEx v1.9.5.
              TheaRender v1.5 (from Animator and in Batch from Thea)
              SketchFX Ex v1.0.6
              Twilight Render %(#FF0000)[Pro v3.5]
              It's Twilight Render Pro v2.5! ๐Ÿ˜‰ (and I suppose also Hobby Version ? )
              What is the process for use it with Twilight Render ?
              • chriC
                chri
                Hi Fredo
                I have a problem to ROTATE.
                Please , have a look on the next GIF ( clic to anim )
                Chri
                • ntxdaveN
                  ntxdave
                  SketchFX Ex v1.0.6
                  It is my understanding that only the Pro version can be used with Animator. We will have to wait and see when they post the link today.
                  Press F1...thank me later
                    Idem! Seems there is blend of rotation / Object / General!
                    • fredo6F
                      @chri said:
                      Hi Fredo
                      Chri
                      Thanks for signaling. Fixed.
                      • fredo6F
                        SketchFX Ex v1.0.6
                        I think this is just for Pro version.
                        • fredo6F
                          [attachment=0:yeoqnx06]<!-- ia0 -->GIF_idem.gif<!-- ia0 -->[/attachment:yeoqnx06]
                          Is there a bug there?
                          • ntxdaveN
                            ntxdave
                            I have been rebuilding my Pendulum animation (preparing for Twilight Render) and I have not seen a problem. I thought I did once but went back and redid my sequence and all worked well for me.
                              Yes same than Chris!
                              Rotation must be from a point outside the object, but result gives from a point inside the object! ๐Ÿ˜ฎ
                              • ntxdaveN
                                ntxdave
                                OK - I understand. My rotations were from inside the object.
                                • fredo6F
                                  When you pick the pivot, the reference component containing the pivot is highlighted in orange. If you wish a pivot at top of model, then right click and select the option.
                                  • chriC
                                    chri
                                    OK
                                    Thanks Fredo
                                    • fredo6F
                                      In the current version, there is a bug when you capture the Rotation movement, but the transformation is actually created correctly.
                                        Better indeed! ๐Ÿ˜„
                                        • F
                                          Falstaff
                                          The camera tracking is not working for me - in particular object selection and playback. I am running on a MAC. Video attached.
                                          Camera_test_small.mov
                                          • ntxdaveN
                                            ntxdave
                                            This is my first render with Animator using Twilight Render 2.5.
                                            I used the lowest quality settings because of the render time. This one took about 1.5 hours. When I looked at a higher quality setting, the render time was MUCH longer.
                                            At least it is a start.
                                            • 29
                                            • 30
                                            • 2 / 30
