    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      mamagroene
      so, I just installed the plugin, but as soon as I try to use it with sketch up (my version is sketchup pro 2014, the toolbar that appears is just empty. I hope you understand my problem as I'm not a native english speaker. we tried pretty much everything to make it work, but we simply can't. I hope you can help!
        How did you install it ?
        Sounds like some files are missing...
        Please reinstall it using the PluginStore's AutoInstall tool, OR if you have the RBZ, then use it with v2014's Preferences > Extensions > Install... button...
        Also note that many of Fredo's tools need LibFredo - also install the latest version of that [also available at the PluginStore...].
        Restart after the installing to ensure everything is synchronized...
          antonio.calvo
          Hello Fredo, thank you for your plugin. Is fantastic and works great. Any way of making it persistent to glue to surface/or group/or edge..? Maybe be with a key stroke? Thank you so much again.
          • W Offline
            witjazz
            thanks
            • Y Offline
              yaseerr
              like it thank you
              • fredo6F Offline
                NEW RELEASE 1.7a - 19 Oct 2014
                This release is required for SU 2014 when your username contains non-ascii characters
                Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
                Download new release at main post
                • W Offline
                  WebBeau
                  Thanks a lot
                  • E Offline
                    Esense3d
                    Hello Fredo
                    I would like to translate this plugin on all German but can not find language files
                    Bezier spline is only partially translated
                    Fredo I now have this new address
                    Roland F Swiss
                    • fredo6F Offline
                      @esense3d said:
                      Hello Fredo
                      Roland F Swiss
                      Thanks for this proposal.
                      BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
                      Anyway, the current version already includes a German translation.
                      • E Offline
                        Esense3d
                        Hello Fredo
                        I See but it is not Full Translated
                        Just Parts of it
                        I also have your other plugins translated fully ie including the main folder
                        and other
                        Therefore, any icons etcetera in German
                        If you want I send you these versions as rbz versions to
                        If you do not mind I would publish in the German part please
                        Roland F.
                        • fredo6F Offline
                          NEW RELEASE 1.7b - 22 Mar 2015
                          This release removes noisy traces at startup of Sketchup
                          • fredo6F Offline
                            NEW RELEASE 1.7c - 23 Mar 2015
                            This release removes noisy traces at startup of Sketchup - second trial
                              rdcraighead
                              This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
                                Gábor
                                What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
                                  It's free.
                                  • MsketcherM Offline
                                    Msketcher
                                    I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
                                    • N Offline
                                      NZSnowman
                                      Just downloaded. Can not wait to try. Looks great!
                                      • I Offline
                                        iris1211
                                        why I can't download it....
                                          I can only guess it's because you didn't follow any of the links in the first post of this thread.
                                          Since several options are provided, surely you can get it from one of them.
                                            dbrenders
                                            Hi Fredo I'm a big fan and user of your plugins, i have them all in my must have plugins list. 😄 .
                                            These days I've been working with bz curves for doing wires and cables etc... and i found a bit dificult some time to place contol points in the right way due to the snapping . Also when trying to reposition or edit the points was bit diffuclt to adjust in an accurate way.
                                            Do you think it would be possible to have in future versions handles or any kind of gizmo thing, ( as thomthom uses in the bz surfaces) for this tools, would be very helpful and much appreciated. Thank you very much in advance .
                                            Best
                                            David
                                            Enviat des del meu SM-P600 usant Tapatalk
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
