    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      pizixie
      πŸ‘
      @ly871108 said:
      I have translated it into CHINESE,perfectly.I tried my best to be with it.THANK YOU!
      Here is the CHINESE version of 1.6D:
        dedmin
        See the video.
        Video_2014-03-28_200608.wmv
          matthew.robert
          Is there any way to convert multiple welded lines (contours for example) to segmented lines with set segment lengths? I have used Bezier Spline in the past to get better "From Contour" results by converting contour lines one at a time to lines made with consistent segment lengths. This works considerably better than the "simplify contours" plugin that still creates snow drifts all over the place.
          EDIT, kinda related... here is a video I created showing how to use the Polyfit LISP (from polyface.de) in Autocad to ultimately get a more efficient model to do a From Contour in SketchUp.
          http://youtu.be/6bQtJhDn_lc?t=3m40s
          (Easier to see in HD directly on Youtube, also jump to the 3:40 mark to see the polyfit part.)
          I've done a similar thing using BezierSpline with the Polyline Divider option, but I need to weld and apply the tool to each contour line rather than all at once with the Polyfit LISP.
          -- matt
            MarinerSketch
            Awesome plugin.
            Is there any option or method to make a spline's ends to be tangent to a straight line?
            • robertWanR Offline
              robertWan
              (www.screencast.com)
              Robert
              • SkeeterdS Offline
                Skeeterd
                Wonderful plugin! Is there a way to keep a tool persistent like in the tools on surface plugin?
                  tellkurt
                  How would I install the plugin for Sketchup 2014 ?
                  • fredo6F Offline
                    The strongly suggested method is that you first install the Sketchucation PluginStore tool, so that you can easily and safely install any plugin.
                    Then, you can auto-install Bezierspline and all other plugins in one click.
                      mamagroene
                      so, I just installed the plugin, but as soon as I try to use it with sketch up (my version is sketchup pro 2014, the toolbar that appears is just empty. I hope you understand my problem as I'm not a native english speaker. we tried pretty much everything to make it work, but we simply can't. I hope you can help!
                        How did you install it ?
                        Sounds like some files are missing...
                        Please reinstall it using the PluginStore's AutoInstall tool, OR if you have the RBZ, then use it with v2014's Preferences > Extensions > Install... button...
                        Also note that many of Fredo's tools need LibFredo - also install the latest version of that [also available at the PluginStore...].
                        Restart after the installing to ensure everything is synchronized...
                          antonio.calvo
                          Hello Fredo, thank you for your plugin. Is fantastic and works great. Any way of making it persistent to glue to surface/or group/or edge..? Maybe be with a key stroke? Thank you so much again.
                          • W Offline
                            witjazz
                            thanks
                            • Y Offline
                              yaseerr
                              like it thank you
                              • fredo6F Offline
                                NEW RELEASE 1.7a - 19 Oct 2014
                                This release is required for SU 2014 when your username contains non-ascii characters
                                Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
                                Download new release at main post
                                • W Offline
                                  WebBeau
                                  Thanks a lot
                                  • E Offline
                                    Esense3d
                                    Hello Fredo
                                    I would like to translate this plugin on all German but can not find language files
                                    Bezier spline is only partially translated
                                    Fredo I now have this new address
                                    Roland F Swiss
                                    • fredo6F Offline
                                      @esense3d said:
                                      Hello Fredo
                                      Roland F Swiss
                                      Thanks for this proposal.
                                      BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
                                      Anyway, the current version already includes a German translation.
                                      • E Offline
                                        Esense3d
                                        Hello Fredo
                                        I See but it is not Full Translated
                                        Just Parts of it
                                        I also have your other plugins translated fully ie including the main folder
                                        and other
                                        Therefore, any icons etcetera in German
                                        If you want I send you these versions as rbz versions to
                                        If you do not mind I would publish in the German part please
                                        Roland F.
                                        • fredo6F Offline
                                          NEW RELEASE 1.7b - 22 Mar 2015
                                          This release removes noisy traces at startup of Sketchup
                                          • fredo6F Offline
                                            NEW RELEASE 1.7c - 23 Mar 2015
                                            This release removes noisy traces at startup of Sketchup - second trial
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
