    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • E Offline
      Esense3d
      Hello Fredo
      I See but it is not Full Translated
      Just Parts of it
      I also have your other plugins translated fully ie including the main folder
      and other
      Therefore, any icons etcetera in German
      If you want I send you these versions as rbz versions to
      If you do not mind I would publish in the German part please
      Roland F.
      • fredo6F Offline
        NEW RELEASE 1.7b - 22 Mar 2015
        This release removes noisy traces at startup of Sketchup
        Download new release at main post
        • fredo6F Offline
          NEW RELEASE 1.7c - 23 Mar 2015
          This release removes noisy traces at startup of Sketchup - second trial
            rdcraighead
            This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
            • G Online
              Gábor
              What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
              • Rich O BrienR Online
                It's free.
                • MsketcherM Offline
                  Msketcher
                  I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
                  • N Offline
                    NZSnowman
                    Just downloaded. Can not wait to try. Looks great!
                    • I Offline
                      iris1211
                      why I can't download it....
                        I can only guess it's because you didn't follow any of the links in the first post of this thread.
                        Since several options are provided, surely you can get it from one of them.
                          dbrenders
                          Hi Fredo I'm a big fan and user of your plugins, i have them all in my must have plugins list. 😄 .
                          These days I've been working with bz curves for doing wires and cables etc... and i found a bit dificult some time to place contol points in the right way due to the snapping . Also when trying to reposition or edit the points was bit diffuclt to adjust in an accurate way.
                          Do you think it would be possible to have in future versions handles or any kind of gizmo thing, ( as thomthom uses in the bz surfaces) for this tools, would be very helpful and much appreciated. Thank you very much in advance .
                          Best
                          David
                          Enviat des del meu SM-P600 usant Tapatalk
                          • fredo6F Offline
                            Best
                            David
                            You can use arrow and Ctrl-Arrows to get some inferences along axes.
                            But otherwise, the best is to try to use Construction points.
                            I'll try to make it easier in a next version.
                            • N Offline
                              numerobis
                              A spline behavior like in ACAD would be nice. 😉
                              I think they are more harmonic or fluent. Here is a direct comparison:
                              http://abload.de/img/splinetesth9sgw.jpg
                              • fredo6F Offline
                                Which method did you use in your example: CubicBezier, Catmull, FSpline?
                                • N Offline
                                  numerobis
                                  Catmull. What is FSpline? With CubicBezier you mean the B-Spline, right?
                                  • fredo6F Offline
                                    Catmull, Cubic Bezier and FSpline pass by the Control Points (BSpline does not).
                                    Fred
                                    • N Offline
                                      numerobis
                                      Ahhh... i thought the Cubic Bezier and F-Spline would be simple "curves" just looking at their picto and because they are placed between spirals and polylines... 😳
                                      Thanks for pointing this out 💚 The F-Spline works great! 😎
                                      • Bob JamesB Offline
                                        Bob James
                                        Note: All PDF files are also available from the menu "Draw > BezierSpline curves > Documentation..."
                                        All the spline tools work fine, but the Documentation feature does not work. I've used Autoinstall with the SCF Plugin Store tool to be sure I have the latest version, but nothing happens when I click on "Documentation"
                                        • fredo6F Offline
                                          You have to download the PDF doc separately and put it in the SU Plugins folder or the BZ_17 subfolder.
                                          This is essentially for a matter of size that the doc file is not included in the script pacakage.
                                            Bob James
                                            Thank you.
                                            The phraseology of
                                            "The doc is slightly outdated, but gives an overview of the essential features. All PDF files are also available from the menu "Draw > BezierSpline curves > Documentation..."
                                            implied that they were "also" contained within the extension.
                                            It's an excellent idea to have direct access to the documents for the more complex extensions that one does not use frequently: I wish all extension authors would do the same.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
