    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • W Offline
      WebBeau
      Thanks a lot
      • E Offline
        Esense3d
        Hello Fredo
        I would like to translate this plugin on all German but can not find language files
        Bezier spline is only partially translated
        Fredo I now have this new address
        Roland F Swiss
        • fredo6F Offline
          @esense3d said:
          Hello Fredo
          Roland F Swiss
          Thanks for this proposal.
          BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
          Anyway, the current version already includes a German translation.
          • E Offline
            Esense3d
            Hello Fredo
            I See but it is not Full Translated
            Just Parts of it
            I also have your other plugins translated fully ie including the main folder
            and other
            Therefore, any icons etcetera in German
            If you want I send you these versions as rbz versions to
            If you do not mind I would publish in the German part please
            Roland F.
            • fredo6F Offline
              NEW RELEASE 1.7b - 22 Mar 2015
              This release removes noisy traces at startup of Sketchup
              Download new release at main post
              • fredo6F Offline
                NEW RELEASE 1.7c - 23 Mar 2015
                This release removes noisy traces at startup of Sketchup - second trial
                  rdcraighead
                  This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
                  • G Online
                    Gábor
                    What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
                    • Rich O BrienR Online
                      It's free.
                      • MsketcherM Offline
                        Msketcher
                        I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
                        • N Offline
                          NZSnowman
                          Just downloaded. Can not wait to try. Looks great!
                          • I Offline
                            iris1211
                            why I can't download it....
                              I can only guess it's because you didn't follow any of the links in the first post of this thread.
                              Since several options are provided, surely you can get it from one of them.
                                dbrenders
                                Hi Fredo I'm a big fan and user of your plugins, i have them all in my must have plugins list. 😄 .
                                These days I've been working with bz curves for doing wires and cables etc... and i found a bit dificult some time to place contol points in the right way due to the snapping . Also when trying to reposition or edit the points was bit diffuclt to adjust in an accurate way.
                                Do you think it would be possible to have in future versions handles or any kind of gizmo thing, ( as thomthom uses in the bz surfaces) for this tools, would be very helpful and much appreciated. Thank you very much in advance .
                                Best
                                David
                                Enviat des del meu SM-P600 usant Tapatalk
                                • fredo6F Offline
                                  Best
                                  David
                                  You can use arrow and Ctrl-Arrows to get some inferences along axes.
                                  But otherwise, the best is to try to use Construction points.
                                  I'll try to make it easier in a next version.
                                  • N Offline
                                    numerobis
                                    A spline behavior like in ACAD would be nice. 😉
                                    I think they are more harmonic or fluent. Here is a direct comparison:
                                    http://abload.de/img/splinetesth9sgw.jpg
                                    • fredo6F Offline
                                      Which method did you use in your example: CubicBezier, Catmull, FSpline?
                                      • N Offline
                                        numerobis
                                        Catmull. What is FSpline? With CubicBezier you mean the B-Spline, right?
                                        • fredo6F Offline
                                          Catmull, Cubic Bezier and FSpline pass by the Control Points (BSpline does not).
                                          Fred
                                          • N Offline
                                            numerobis
                                            Ahhh... i thought the Cubic Bezier and F-Spline would be simple "curves" just looking at their picto and because they are placed between spirals and polylines... 😳
                                            Thanks for pointing this out 💚 The F-Spline works great! 😎
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
