    Measurment text in black area
    24 Posts 5 Posters 5.6k Views 5 Watching
    • robertWanR
      robertWan
      I've noticed that it only happens with measurements which are aligned to dimension line.
      Robert
        Yes !
        A break through...
        I too confirm that only if the dim-text is 'aligned', then the HLR PDF shows a black rectangle.
        Without the HLR setting they all print OK !
        • robertWanR
          robertWan
          So it is a bug? In SU2014 same.
          How is it in SU2015?
          Robert
            I don't see it in 2015.
              I see it in v2015.
                I wonder why I don't have any issue on my machine with this.
                • C
                  Charlie__V
                  @tig said:
                  I see it in v2015.
                  +1
                  Camera set to Parallel Projection....default views (top/front/right..etc) gives expected results.
                  Perspective views not so much.
                  Charlie
                  SUv15
                  MS Win7 64 Bit
                  • K
                    kaas
                    maybe its due to different gfx cards / gfx card settings / OS versions / ...?
                    • C
                      Charlie__V
                      Could still be Print Driver........I am using Adobe Acrobat ProXI.
                      Charlie
                        Charlie
                        So maybe the issue is more with print drivers? I don't have a printer connected to my PC and the default "printer" is set as One Note.
                          I get it when using PDF995, which I think uses some 'ghostscript' arcanery...
                          • C
                            Charlie__V
                            Charlie
                            My WAG......Printing w/HLR yields a partially vector based file....no? (lines are vector...& text appears to be raster....to me anyway)
                            I tested this using windows XPS writer.......which I am pretty sure saves as a .jpg or similar image file. (all raster)
                            I do not have any other print driver installed to test further.
                            Charlie
                            PS:
                            XPS Writer does not black out the text.
                            MS_XPS_Writer_HLR
                            • C
                              Charlie__V
                              Just following up........I looked to the Trimble SU........Knowledge center.......(search) HLR.
                              As I suspected.......the HLR print (output) option is vector based output.
                              So...somewhere......somehow.....the black dimension boxes are cause/effect of......??
                              SU dimension text fails to convert/display as vector?
                              User "success" in printing to HLR (w/o blacked out dimension text) .....most likely does not contain any vector based attributes. (IOW: print driver is really printing as .jpg/or other "image" file)
                              I do not have an answer/solution.......but to say the HLR print option......when used with a vector capable print driver.......will unfortunately create the blacked out text/dims. as depicted above.
                              Best,
                              C
                              Trimble_SU_Print_To_HLR
                              • 2 / 2
